- To Bore Or Not To Bore????
- HELP!!! Air Dog Pressure
- Torque Specs On After Market Tranny's
- ADR and smarty
- Hey 2nd Gen 24V Cummins Guys .. What's Your Next Bomb?
- My Opinions On The Smarty
- I Think My Adrenaline Just Crapped Out On Me
- Thinking Turbo Upgrade
- Smarty S03
- Edge Ez Dodge 5.9L Cummins 98-02 Installation Guide
- FASS Install Instructions Dodge Cummins Truck 1998.5-2004
- 1998-2002 Dodge Cummins Edge Comp install Instructions
- 47RE 94-98 12v and 98-up 24v Transmission Fluid Cooling Tips
- Super Chips stacked with a Comp Box
- Super Cool Downpipe
- Fass Pressure
- Whole Injectors Vs Nozzles
- Superchips Flashpaq...
- How Much HP/TQ Can My 5 Speed Handle?
- Timing Isn't Everything!
- Suncoast Trans
- Helix Camshafts
- VP Monster Pump Internals
- Older Blue Box Chip
- New Heavy Duty Headlight Harness
- Quadzilla Adrenaline
- Best combo for mileage in a 01Cummins??
- BD vs AirDog
- Silver Bullet Turbo
- Got An Annoying Noise Out Of The Motor!
- FASS 150 ?
- Quadzilla
- Popped Another Head Gasket
- Thoughts On This Turbo?
- Smarty S03
- Towing W/ Adrenaline
- Ordered Toyo tires and Kore leveling kit and shocks
- Adrenaline 1/4 Mile Test
- 1060 HP VP44
- Exhaust Brake
- Running High Boost
- Adrenaline Tunes
- Need Opinion
- Monster VP Stage II
- Got My Truck Back
- Bigger Injectors
- Lighting It Up
- Diamond Eye 4" Video Install
- Smarty Updates
- Reman Juice
- BD Boost Fooler
- P0253 Question
- Blew Up 3rd Gear
- Edge Comp Updates And Drag Upgrade Questions
- Air Dog 150
- RAM Air Kit Worth It??
- Dual Lift Pump Install
- Center Console Idea
- BHAF Heat Shield
- Break 800??
- 5" downpipe
- Adrenaline Goes Dead
- Isspro Gauges
- Loudest Exhaust?
- Okay Guys Which One To Go With
- Home Made Twins
- Juice Attitude
- VP44
- Smoke Switch?
- Adrenaline With Pulse
- Air Intake Silicone Boot
- Fass Or Airdog
- Converter Staying Locked And Stalls Truck
- Airtex
- Twins
- Stage 2 Hot Rod VP44
- Quadzilla
- Cummins Shift Knobs
- Steering Box Options
- Valve Body
- Aftermarket Automatic Transmission Question
- Edje Juice Programmer
- Non Wastegated HX35
- Snow W/M pyro lead?
- HX35 and injector size for performance and towing??
- Here's The Plan....
- CFM+ To do or not to do
- To ppump or not to ppump,that is the question
- Another Question For The Airdog Guys
- Anyone Had A 4" And 5" Exhaust That They Can Compare?
- Plastic Boost Tube
- Is It Time For A Bigger Turbo?
- Fuel Catalyst
- Mad Questions
- TST Competition Choke
- Airdog And VP-44 Fitting
- Gotta HX52 Comin' In The Mail...
- Going Down To A Leveling Kit
- Stacking Chips
- Adrenaline Install Question
- DT Profab Adjustable Trac Bar. Anyone Run It?
- Adrenaline Has No Fuel Pressure Gauge!?! And Silverline Exhaust Questions.
- Whats Easier On Airdog Install
- Hot Rod VP Vs Stock
- HP Estimate
- Joy Rides - Ticket To Ride
- Injector Recommendations For Someone Who Should Already Know!
- Pillar Pod Woes
- Quadzilla Adrenaline Gauge Hook Ups
- New ATS
- Pressure Regulator With Holley Black?
- RV275s>DDP+75hp?
- Adrenaline Updates
- Turbo/Smarty Question
- Who's Running What
- New Adrenaline Tune
- Super B Turbo Charger Install
- Converter
- Anyone Running An Aftermarket Intake Horn?
- Pulse Monitor For Adrenaline
- May Have The Fix For Big Sticks In An AUTO Bucking
- Edge Comp/Smarty Smoke
- Twins!
- Air Dog Install With Pics
- Program Stuck In ECM?
- Boost Elbow??? 2001.5 Edge Juice W/ Attitude
- Adreneline ? Questions?
- Replaced The Head Now It Won't Fire Argggggghhhh
- Newbie Tuner
- Upper And Lower Control Arms
- Adrenaline With Manual Tranny
- Got My Profit Sharing Check From Work Today....
- Smarty Adrenaline ?
- Air Dog Install Questions
- Smarty News
- Best Fuel Mileage Setting On Edge COMP
- Need To Find Some Gauges
- 5 Inch Straight Pipe VS 5 Inch + Muffler
- Trans Threads
- Smarty And Edge EZ Stack Question
- Starting The Bombs
- Injectors
- CUMMINS 3rd Gen Head On 2nd Gen VP Block
- 5 Hours Later ... 24V Rebomb
- My Drag Comp Pulls Harder On 1x1 Than 5x5?
- EDGE JUICE W/ Attitude Question
- Front End Rebuild
- Adrenaline
- Quadzilla Adrenaline In Route
- Boost Fooler Adjustable Elbow ?
- Adrenaline Comp
- Banks Power PDA For 2nd Gens
- Doing Some Changes To My Truck
- Adrenaline VS Juice w/ Attitude
- Adrenaline Installed
- Adrenaline Is Here
- How Do I Get Smoke?
- GOT MY QUAD!
- Turbo Options
- How Much HP?
- Quad Shipping Yay!
- Hard Start After Lift Pump Install...??
- Get Rid Of TST PM3 For FMS ?
- Banks, High Ram Question...
- Ohh No It's A Fog Lamp Question Again
- FASS And No Fuel Heater???
- Edge Comp Udates Available
- Edge Comp Smoke?
- Edge Comp And MAP Sensor....
- Jake Brake
- I Need A VP44 That Flows More Fuel
- Quad Adrenaline...Check This Out!!!!
- Quad XZT+ Updates Are Now Ready!!!
- Stacking Chips Or Programers ?
- 2WD Body Lift?
- Quad Adrenaline
- High Ram Intake Question...
- AirDog150 Users...What Kind Of FP Are You Seeing?
- Questions For Some Of You All.
- Who Is Currently Running Edge COMP/Smarty Stack...
- Should I Keep The ROKK Tech
- Boost Questions....
- Getting Closer!
- Need New Seats
- Upgrading My Fuel System On The Cheap!!!
- Pusher Pump On A 12Valve???
- REAL Fast
- Fass 150 Pics Needed...
- Edge Juice
- How High Will My EGT Be?
- AirDog 150 Installed
- VP44's And Lift Pumps
- Pulled The Trigger
- Trannys
- Clutch And Trans Questions...
- Steppin' Up The Fuel System
- AirDog Install
- Tapped My Comp Again...
- TST Competition
- Got The New Toys Comin
- Hot Juice
- Blew Out The Head Gasket
- TWINS Teaser Photos...
- AirDog 150 Is Here!
- Dodge Cummins Programmer ?'s
- Injector Sizes
- Edge EZ
- New Turbo And Other Toys In
- Got The Twins In
- Quadzilla Chip Questions
- BD RAD wiring?
- Calling All Engine Builders
- Bd Twins VS Rips Twins
- Tuners
- Ol Red Does 807hp Fuel Only - Monster VP
- Timing???'s
- Getting A New Turbo SOON, But Is It The Right One?
- OIL Fill Cap / Breather Vent Mod
- Front Suspension Parts
- Stock Turbo
- Smarty
- Belt Drive Lift Pump
- WHAT IS A GOOD PRICE FOR A USED EZ??
- CHEAP FUEL SYSTEM UPGRADES
- Quadzilla
- Tail Light Upgrade
- DIY Bypass Oil Filter
- J - Hook??
- S300
- Whats The Difference Between A SO vp44 And A HO?
- Installing The FASS?
- How to Update Smarty / Smarty Upgrade 1998-2002
- Gauge Install Tips
- Correct Location For Pyro
- Reasonable Injection Pumps
- Turbo With 100hp Injectors
- MAP....Manifold Air Pressure
- BOSCH VP44 INJECTION PUMP AND LIFT PUMP FAILURES EXPLAINED
- NEED ADVICE
- Gauges
- Walbro Kit Owners Question.
- Upgrade The OEM Lift Pump
- Dynoed Truck
- Oil Breather Vent BOMB
- Injectors
- TWINS Info....?
- 40/3B high EGTs
- Crappy Performance Out Of Silver Bullet
- How much boost
- Air Dog
