- Whistle at turbo.
- White smoke at startup with new pmd and #9 resistor
- injection pump ? need help asap
- Front end issues
- no wait to start light no start
- 01 F-250 7.3L fuel gauge inop
- mase
- U joint or rear end
- help with my 6.5td please
- 6.5 nightmare
- 95 cummins alternator into 90 wiring
- blown seal at bottom of steering box
- 97 5.9 12 valve not as snappy after removing pump for tappet cover leak
- 2000 F350 7.3L died wont start
- 6.2 cracked heads
- broke truck
- Duplicolor with Kevlar problems
- 2002 cummins 24 valve won't start
- 98 24v Cum changed fuel filter now wont start
- 97 f350 7.3 turbo diesel
- Suggestions needed
- F250 running rough ???
- 01 cummins lift pump issues
- 2002 Ford F250 W/7.3 bucking problems
- 2008 Cummins Turbo Upgrade-Need Help!
- 94 IDI will idle but not stay running while driving
- 2002 Chevy daily driver won't start.
- 2001 5.9 cummins luggy then over rev
- 6.5 TD Lost All power/electrical
- 01 cummins injection pump PLEASE HELP
- Charging problems
- 5.9 transmission issue?
- 1999 E350-7.3
- new southbend slave cylinder no pedal
- 99 7.3 turbo won't boost
- strange squeling noise lower passenger side
- 1995 Cummins Major oil leak
- popping in front end when in 4 wheel drive?
- 98 Chevy 6.5 throttle problem
- airdog fuel leak
- 2002 Dodge 2500 Cummins Fuel pressure issues
- Engine
- STARTS BUT WON'T STAY RUNNING
- air dog
- 6.5l Injector Pump Problem
- 95 k2500 multiple issues
- Truck won't start!!!!!!!!
- 97 f250 losing power
- 95 7.3 wont start need help
- Fuel Leak
- 01 3500 cummins won't start
- GMC suburban 1999 6.5l won't start
- 06 F-450 6.0 Cranks, but wont start
- No power
- 2010 dodge cummins engine problem
- Need Help!
- 2001 cummins wont start
- Po237 Super boost input voltage low Throttle response intermit
- front axel u-jiont HELP!!!!!!!!
- No fuel ? 5.9 24 v 1998 ram 2500
- Need help, 95 Cummins knock
- wont crank
- 2003 f250 6.0L...
- IDM Needed for troubleshooting
- 02 cummins thought was ecu porb its not help
- cummins engine angle
- 5.9 cummins making a whistling noise
- 03 ford f250 electrical problem
- cummins, new batteries, dont run right?
- 01 7.3l major issue
- Electrical troubleshooting
- 2001 24v cummins 2500
- fuel pump issues
- white smoke
- 97 cummins 12v help
- Truck stays running when finally turns off lights flicker
- 06 5.9 / 48RE starts off in second gear
- 01 Cummins, rough idle, stall under throttle
- help
- Need O-Ring for a HX40...
- 2000 7.3 electrical? wont start
- 97 5.9 cummins 12 valve tappet cover leak
- powerstroke low icp and injector cackle
- 98 gmc 6.5l p0238 code
- Ford 6.0 start up issue
- new details
- tcc solenoid
- White smoke and no power
- Electrical issues
- DODGE 5.9 L CUMMINS WON'T START
- LLY White Smoke
- Lmm duramax po843 trans issue
- Ghost ignition problem
- so frustrated, need advice!!
- 1994 ford 7.3 idi factory turbo vin k
- 97 12v running on 5 holes !!
- cummins problem
- Transmission prnd cable replacement ?
- 04 f250 lack of power, whistling, no heat, EOT's abnormal, already studded/egr delete
- 2005 f350 6.0 broke down on freeway
- Fuel line blown. Help!!!!
- Drive or tow
- Help Truck wont start after rebuild!!!
- EOT EOC with SCT
- 97 Cummins won't stay charged
- Replacing EGR is there anything else I should replace?
- No start cummins
- Afe wastegate
- 5.9 24 v 1998 Ram without fuel
- No sensor ground in Data Link Connector
- Military Member in Distress trying to get home for Christmas
- Part ID
- Cummins NTC 300 Big Cam
- I'm in trouble...I stripped the hex head in my dodge 47rh band adjustment
- tranny swap
- 93 6.2l vin j Blown head gasket
- 1995
- 2005 liberty CRD Rad. Fan Relays
- Trying to get home from work! please help!
- Won't turn over
- Cant get in gear
- noise/vibration/weird sound
- 2001 7.3 hard start won't stay running
- truck wont start
- 2000 24v no start
- I need my 6.5 to come alive
- Lift pumps
- 1994.5 powerstroke No smoke, No start
- 2001 dodge cummins 24v
- help
- Blown stock turbo
- 03 Ford 6.0 No start
- Feels Like Fuel
- 2003 Dodge Ram 3500 5.9 Cummins Problems
- 2002 powerstroke shut down
- Bang and no rwd.
- 2002 F-250 hpop 7.3
- 2003 F-250 hpop 7.3
- 96 F250 doing strange stuff
- seeping Trans fluid
- Reman or Repair? 7.3L with Gas in Engine
- 1984 6.9l fuel problems
- 2000 F250 - Vacuum cleaner sound ?
- 2007 F350 6.0 diesel-white smoke
- 48re trashed! help
- help!!! turbo prob
- 2003 3500 4x4 Died on the road, Hasn't started since.
- need help
- Transfer Case
- 04 6.0L excursion, engine cuts out
- 95 GMC 6.5 Turbo Diesel stalls
- Truck shaking from stop need help!
- Pulley squeaking and its driving me crazy!
- 03 cummings start problem
- Help I believe there's a short! 04 F-250
- 03 7.3 runs rough
- 1993 7.3 IDI won't start
- 1993 ford f250 diesel
- 03 Dodge Brake light issue
- Will not go past 2200rpm, popping and white smoke..
- FLUID COMING OUT CRANKCASE OIL VENT TUBE DURAMAX LB7
- How to break a Cummins 6BTA Lift Pump?
- 2006 wont shift to 2nd
- 97 f-350 with right bank of cylinders down
- no acceleration, sputters
- LB7 DURAMAX WONT START NEED HELP
- 6.2 wont start
- 03 F350 6.0 Help - not starting
- 7.3 crank no start
- Roscod
- low hpop pressure
- Lose of MPGs
- New to Diesel trucks, hard to start.
- Is this bad?
- Transmission Problems with a 4WD 7.3 Automatic
- 5.9 idle keeps climbing at idle
- golf mk2 gtd problem
- 96 PSD RUNS ROUGH. NEED HELP!
- 99 cummins problem
- 1989 f250 losing prime while running
- Jetted jetta
- FUEL PUMP REMOVAL
- engine running away
- Need help fast -- brake problems!
- electrical?
- 2005 6.0 Rev sounds
- 08 6.4 will idle,but wont run. LOOKING FOR HELP ASAP
- 92 6.5 3500hd severe problems
- 08 6.7 Cummins Pulling 18,000 Brakes Aint workin
- 04 Chevy Kodiak Duramax c4500 dies while driving
- help with an injection system
- 95 Suburban no high
- Edge comp install.
- oil pressure sending unit location
- upper rad hose stay hard even after sitting overnight
- any help here?
- Low Boost pressure, high exhaust temp, poor fuel mileage?
- 01 24v throwing codes
- Ford BJ Dana 60 help!
- stalling
- Cummins 5.9 liter 6BTA Marine problems
- Excessive Smokes and Exhaust popping.
- Any good diesel mechanics in CT?
- Very loud engine knock!!!
- smarty ssr defuel
- 96 dodge ram transfer case problems
- oil filter housing
- vp died....can i go ho pump to so
- Help, towing issues
- Torque Converter Lock Up Not Working
- Pillar guages wont work!
- Fordson Dexta Ran Away, Now What?
- HHelp-blowing blueish smoke-no power,5.9,01'
- 02 cummins wont start
- DPF Problems
- Can't get the starter to engage!
- Water in Diesel
- 4r100 slippage.
- Help!!!!!
- Need help fast!! Stranded at Walmart in fire lane...
- Gauge Cluster Problems
- Cold start advance
- 01 cummins small miss
- Programming issues
- 6.9 p1689
- Emergency camber ?
- 6.9 liter burning oil
- deisel in oil help
- 99 7.3 Powerstroke Strange Issue, Please Help
- P0098 Code and oil pressure loss at idle
- Rattle/ Grinding noise at idle and low RPM
- Codes Rough Idle No Power Cyl's 4-6 and
- AC quit working
- injection pump
- 05 6.6 fuel in oil
- 2008 will not shift past 4th after screwing up update on mini max
- Help!!
- 01 cummins loping and jerking..
- stc replacement problem
- Need help near Kearney/Lexington
- 99 cummins fuel tank module leak
- 86 Chevy p30 6.2...
- turbo failure
- 97 psd lots of codes
- I need an engine serial number
- dump bed kit removal
- Need advice-DPF
- idle high
- what causes turbos to have oil all over the place
- 97 ram 3500 parking brake tensioner?
