PDA
View Full Version : 6.7 Liter Dodge Cummins 07.5-12
Pages : 1 2 3 [4] 5 6 7
  1. 2012 Dodge 3500 Max Tow Option
  2. stock manifold!
  3. 2012 6.7HO cummins 3500 question
  4. inspections with an uncorked 2012 cummins?
  5. Turbo flange studs.....
  6. Can i use regular diesel on 2010 dodge ram cummins?
  7. Steering shock
  8. 6.7 project update
  9. A TRUE "JAKE" BRAKE for the 6.7 (engine compression brake)
  10. Transfer case shifts itself?
  11. Tranny slippage
  12. 6.7 project
  13. best tuner for 6.7 cummins
  14. ram 2500
  15. reset the service reminder
  16. 2010 cummins
  17. 2009 6.7 transmission upgrade
  18. 07 6.7 needs help
  19. 2009 dodge 2500 with a speed manual won't shift
  20. 6.7 Fuel filter change?
  21. looking at a 6.7
  22. Need reccommendations please guys
  23. New 2012 still on order
  24. strange exhaust/turbo sound
  25. Bumper
  26. first cummins owner
  27. truck wont run help
  28. Death Wobble
  29. Error Codes?
  30. Exhaust - I'm Lost..
  31. Help me with my new to me 08 6.7L ram!
  32. Looking for a new truck
  33. Help!! 08 dodge 6.7 cummins problems.
  34. Bad Day for my 2012 Cummins with 5000 miles
  35. Regen and filters
  36. fuel filter?
  37. Max tow package..
  38. What is this?
  39. 07.5 -09 6.7L vs. 06-07 5.9l Which would you buy?
  40. 08 6.7
  41. Shift Knob
  42. Big Guy
  43. p1130
  44. 08 6.7 knocking any ideas
  45. Possible coolant leak
  46. exhaust brake staying on??
  47. help me please 2012 cummins
  48. P2564,
  49. Help with headlight bulb replacement!!!!!
  50. What diameter is the exhaust pipe right where the stock muffler attaches on an 08 6.7
  51. known trouble
  52. No start
  53. Whistle bad???
  54. alt went out
  55. rear axle pinion offset on an 08 2500 ??
  56. WTH!!!! 6.7 Dissappointment!!!!!!
  57. Slight ticking sound
  58. Bye bye to my 6.7
  59. 25.6 miles per gallon
  60. Disabling pilot injection
  61. BIG ???????????
  62. 2500/3500 Flip Mirrors
  63. Mighty Diesel
  64. Sprinter Turbo question
  65. 6.7 Valve adjustment
  66. Lucas Oil Treatment
  67. Picked her up today new 2012
  68. truck changs?
  69. pulling the last of my hair out
  70. quick question
  71. 5" to 5" stainless tip
  72. TPMS
  73. Silncer Ring in turbo
  74. rolling coal
  75. Turbo whistle gone
  76. oil...
  77. Bluetech question
  78. deletes
  79. 2012 Exhaust?
  80. Opinion on clutch
  81. fuel filter
  82. lucas fuel treatment
  83. 2012 HO Question and all 6.7 Owners ???????
  84. INJECTORS- which size
  85. deletes done
  86. Ordering New, Manul or Auto Trany?
  87. 68rfe trans
  88. Storing a truck
  89. 5th gear
  90. 1st one ton cummin
  91. Shutting down differently???
  92. Swapping to synthetic oil
  93. 09 6.7 with auto
  94. Air or Fuel???
  95. Regeneration questions.
  96. light load button
  97. 6.7L Cummins DPF question
  98. First time diesel owner
  99. P113C and U010C DTC's...Any help out there?
  100. thermocouple fried.help
  101. Fuel Filter: Buyer Beware!!!
  102. 6.7 emissions help in north carolina please
  103. Fuel in Oil
  104. aftermarket rim sizing? ??
  105. incase somebody is wondering
  106. sun roof leaking
  107. trans gauge install
  108. Springs or spacer for leveling?
  109. boost gauge install? ?
  110. H&S New Update Boost Fooler
  111. Too much oil
  112. 6.7 tranis
  113. 6.7 missing help
  114. new to the 6.7s
  115. Attn Snow Plowers:
  116. Air filter #'s
  117. having issues
  118. Dodge Grill replacement
  119. dpf full need help
  120. headlights/interior lights flickering
  121. hell yeah
  122. throttle postioner
  123. brakes
  124. PVC valve ?
  125. smarty jr67
  126. EFILive
  127. Steering box stabilizer
  128. Idling
  129. Dually Pics!!!!!!!!
  130. Tranny temp gauge "test port" or likes?
  131. Program
  132. 6.7 cummins question
  133. Lift or level?
  134. 2K OIL CHANGE????
  135. 2010 tuner
  136. h&s xrt
  137. Eliminating rev limiter
  138. Post Pics of 2010+ Lifted duallys
  139. Keep it Stock or Do Deletes
  140. 6.7L straight exhaust
  141. turbo question
  142. smarty jr me question
  143. head gasket or egr cooler
  144. Newbie
  145. Clutch HELP
  146. EGR delete without check engine light?
  147. 6.7 cummins turbo question
  148. Head lamp swap
  149. off road diesel
  150. Fluttering sound from under hood
  151. Newbie to site, purchased 2008 6.7 diesel
  152. egr valve
  153. Best Intake
  154. Need MODS ASAP cheap
  155. engine cut out under acceleration
  156. Check engine light
  157. Question about gauges.
  158. Question Has Anybody done this
  159. question on auto tranny
  160. Price quote?
  161. Anybody With 2012s
  162. what next?
  163. Smarty Jr with G56 Transmission
  164. New CuMMiNz!!!!!!!!!!!!!!!!!!!
  165. twins on 6.7, anyone else done it with 5 inch
  166. smoke switch
  167. silincer ring
  168. U-Joints 2010 1 Ton
  169. Checking in & looking for some advice
  170. Transfer case brace/crossmember
  171. Airdog customer service problem
  172. p2262
  173. No smoke coming out of exhaust
  174. looking at an 07.5 6.7...what to look for
  175. Tranny Problem
  176. EGR delete
  177. 08 6.7 auto trans issues
  178. 08' 6.7 auto trans trouble code p0700
  179. looking for my first diesel
  180. How do You do it.
  181. After market tie Rod?
  182. Tire Pressure Monitoring System light coming on
  183. Exhaust brake/deletes question
  184. 6.7L Cummins Need Your Oppinion
  185. Cold Mornings
  186. Cummins DPF
  187. choke down
  188. EGR/Cooler delete
  189. When to Stud
  190. EDGE race installed, white smoke coming out of exhaust
  191. clutch is going south
  192. Do I want a new Cummins
  193. Catalyst Full Service Required
  194. need help, install in the morning!!
  195. new to 6.7
  196. Overhead Console Issues
  197. Oil Drain Part Number
  198. Help need DPF air lines (Long one)
  199. downpipe and dpf removal
  200. Radio and overhead message center
  201. HELP-J35 recall/performance questions
  202. is this all i need to do?
  203. Cummins turbo "whistle"
  204. fuel filter
  205. Air ride seats
  206. 2011 6.7 problem
  207. Dpf & erg questions
  208. Boost ??
  209. 07 CUMMINS EXHAUST QUESTIONS
  210. turbo upgrade on 6.7
  211. biggest tire
  212. Big Brakes for my 2008 2500
  213. EGR question (block off plate)
  214. Swapping from DRW to SRW
  215. considering a 6.7
  216. anyone in arizona
  217. Run Exhaust Brake To Save Turbo?
  218. tic tic tic on cold start
  219. buy back letter from Chrysler
  220. Smarty Help
  221. HELP!!! fuel pressure relief valve
  222. Exhaust question
  223. Turbo Question
  224. new to the family of cummins
  225. Need Help with The Rear In my 2011 Cummins
  226. Visual Aid!
  227. P000F fuel overpressure activated
  228. Joined The Cummins Family
  229. 08 Dodge DPF Delete
  230. auto trans stuck
  231. New vgt upgrades
  232. new truck maybe
  233. Headstuds
  234. EGR cooler plates
  235. HP gains?
  236. 2011 Dodge 5500 EGR DPF Delete Need Help!
  237. pass tie rod
  238. serp. drive belt
  239. Ordering an intake
  240. Code P2563 Issues
  241. Water/meth or propane?
  242. New ram 3500
  243. Oilpan removal 2wd
  244. dpf delete
  245. Want your input
  246. 2010 6.7 - ETC light
  247. stumpped
  248. smarty on cab and chassis with aison auto.
  249. Update?
  250. Smarty ?
