- Advice wanted.
- Lifted truck with a gooseneck
- New 2010 Cummins..help finding some easy first B.O.M.B.S.
- Tool Box suggestions. What would you add for a long trip?
- how do u bypass low ac pressure switch on 6.7
- Code explanation please
- First Diesel
- fuel relief valve problems
- 6.7 airconditioning problem
- P2583 help
- O2 Sensor anywhere??
- 6 speed aut help
- dodge ram 6.7
- 08 6.7 MPG stock
- 2010 3500 DRW Questions
- how to smoke switch a 6.7
- Jerks...
- ford guy look at dodge
- mp-8
- Skid Plates?
- j35 flash
- Need 2010 3500 advice power and suspension
- Back-up beeper. Dealer item?
- Head gasket?
- wheel vibration
- Optional air box
- XRT vs black maxx
- 6.7 turbo on a 97 12v
- MP 8 ????
- Jim and I raced 6.7s today
- New Truck
- Emissions Recall J35
- AC problems
- 6.7 cummins ohd question
- 22.5" or 22"
- Some good read on the 2010 cummins
- p0137?
- new rear inner oil seals
- Autometer 5760 installation ?
- Valve Lash Adjustment
- Question about the 6.7
- Cooling Problems
- Money to burn.
- OBD dilemma
- Need help w a code???
- biggest tire on a dually
- 2007 - 2010 Dodge 6.7 Diesel Engine Vehicle Class Action Law Suit
- lookin at a 6.7
- cel with sims and dpf
- Cheap Tail Light Repair
- Over Head display
- Any ideas?
- whats the best level lift kit and the max size tire
- Cup Holder
- 6.7 Turbo on 5.9 ???
- 5.9/6.7 swap
- Stock 6.7 clutch slip?
- Post April 09 Only....
- truck broke down
- anybody blow up their engines ..???
- Code cracked in the 09's
- Turbo trouble ?
- belt tensioner
- any ideas???
- What Brand Oil For 6.7
- Coolant strangeness.
- new to the family
- Factory flip out towing mirror's
- Finally drove a 6.7 today
- 6.7L Stock Exhaust
- Check Engine Light?
- Two Guys Garage
- kenwood radio help
- Just a reminder of the upcoming Two Guys Garage which will feature the Cummins 6.7L
- 68RE question.
- Need advice on 6.7
- I need MPG
- 07 6.7 liter problems
- eb activating on acceleration
- towing with a megacab
- need help how to install engine block heater plug
- Mega rebuild kit??
- 2010 ram?
- Overhead dispaly "See Dealer Now" ????
- P2000 code
- P2000 Code
- Zues ecm
- Trany?
- 2010 Dodge
- Might Be More Expensive To Fill Up
- what is the differance between a 5500&3500 c/c
- Flashed
- oil intake side of turbo
- g56 and a 48 auto swap
- Dodge ram Tow truck.
- I did it.
- Smarty S6718ME now Power on Demand!
- Cummins 6.7 fuel rail pressure
- Head lights
- 6.7l Steering Problem
- fuel pressure
- MIL When Cold
- P0087
- Hissing brake pedal. Booster?
- Valve Rattle
- Engine break-in period
- cooler delete wastegate
- Idle Question ???
- fuel leak from the tank
- Clutch
- silencer ring
- tc lock up?
- auto or manual Dodge???
- 6.7 vs 6.6
- fuel filter question..
- injector tips
- type of oil????
- egr help
- Throw out bearing
- New 2010 Crew Cab and Mega - Due on showroom Floor in 3 to 5 weeks
- dodge paint job
- exhaust brake "dead spot"
- questions on mileage
- 6.7 warranty and factory info
- h2 Wheels ?
- Gauges or Monitor
- aftermarket intake horn?????
- New Truck
- Throttle position light
- 6.7 air conditioner charging / vacuum specs
- Block Heater
- cab lights
- Stickin it to dodge - Right in their wallet
- scheduled maintenance
- i need 6.7 silencer ring help now
- Delo 400 LE
- ok now im pissed....
- Who wants to sell some stuff?
- TSB 1802409 - no more Smarty - uh oh!!!
- o.k. P2262, is this the start of the nightmare?
- smoke
- what now??
- cp3 fuel pump
- New Truck
- 07 6.7l
- Low Tire Idiot Light
- 07 6.7l
- Fuel Question??
- DPF Regen Problem
- HELP!!
- What does this code mean???
- what do you think about this.....
- CEL on but no problems
- new oil filter from cummins
- Tampa, Florida Help
- "Service now" but no codes - any ideas
- new to DB and have a question
- How to get into the instrument Panel?
- what do these codes mean 1507,2579
- Removal of stock exhaust
- cracked transfer case
- cleaning the engine
- Relay Fan ???
- What is EGR & DPF ?
- 6.7 sluggish in od?
- 6.7L fuel economy
- 68RFE Finally bit the dust
- 2009 3500 Order?
- 6.7l
- wire color code for high beams
- Throwing Codes
- oxygen sensor
- EGR problem
- G56 Clutch......which one?
- EGR unplugged. Strange behavior.
- Surging Problem
- Need legal help
- turbo
- Parts Truck (ebay)
- CEL on my rig
- You guys are not gunna believe this
- CEL Code P2262
- Tell about these things!
- P0106 Manifold Absolute Pressure Sensor
- newbie looking at a new 6.7
- ball joints
- Another "I wrecked my truck today" thread
- New 6.7 ECM updates
- wrecked my truck today
- Leaky CP3?
- cooked turbo
- Was bored today
- cel p245a any sug??
- 4WD launch
- Mileage
- 6.7 computer programming
- Need advise
- I Have A Serious Steering Problem....
- Code Won't Clear
- bed drain holes and batteries
- clearing codes
- Engine oil
- Engine serial number for '08 6.7 w/automatic
- new 325/50/22 bfg's
- EGR unplug
- sponsors?
- Got the H36 Recall
- My dyno day today
- CEL Question
- 6.7 Help !!
- race tomorrow night
- 6.7 DPF regen.
- P242B????
- its a sad day
- Hey from s.c.
- New recall for 07.5 and up trucks
- what works?????
- EGT's
- 6.7 black smoke
- Any info on the Hydra Boost System on these new things
- 6.7 liter nightmare
- On the road and I need HELP PLEASE!!!
- CEL is back
- Quick video of the Exhaust with the DPF Delete
- P2509
- sitting on the seat frame
- Looking to buy an 08 6.7. Have some questions.
- 2009 CTD
- exhust brake problems??
- Ram in disguise!!!
- New Ride
- Purple fuel in the 6.7 ?
- Buying a new08 finally. Any help I can get
- Ok guys, I need advice on the cummins side of things :)
- Engine Oil Change
- Turbo Boost Failure
- What Year Was The First Year Of The 6.7L Cummins
- DPF and Understanding the Post-Injection Problem
- HOW TO CONTACT H AND S PERFORMANCE
- P0020, P0021???
- New Factory Injectors
- Looked At An 08' Today
- Thinking About Gettin A 6.7
- EGTs For 6.7s
- Off Road Diesel
- Catalyst???????
- New Truck Finally Arrived...
- Got Me A New 08 Megacab
- 6.7 Exhaust ?s
- Transmission Blues
