Log In
View Full Version : 12 Valve 2nd Gen Dodge Cummins 94-98
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29
  1. What to look for
  2. what gear ratio
  3. Building block and head
  4. HELP!! ESN
  5. fuel shutoff solenoid problem/slight miss???
  6. EGT
  7. awesome prices
  8. bad oil leak
  9. flatbed conversion
  10. 97 no fuel plate no gains
  11. Transmission making bad grinding noises
  12. Part number for oversize marine pistons
  13. not charging
  14. Oil Pressure Issue.
  15. Parking brake cable help!?
  16. Stuck High Idle Problem.
  17. 01 inertior in a 95??
  18. 96 trans issue
  19. emergency on 12v
  20. HELP, Might buy 98 12valve that used to be a V8
  21. bad ecm??
  22. scan gauge mpg tool
  23. Vacuum Pump Oil Supply Line--
  24. bosch 300 injectors
  25. Power steering pump prices... wtf?
  26. $2000 for used 12valve? just the engine
  27. installing cruise control on a 97
  28. 1992 with a p pump
  29. looking for a chart and need some assistance
  30. Fuel Pressure Decreases with Throttle...
  31. help trans issue!!
  32. Help! All Gauges Not Working!
  33. Weird oil pressure guage?
  34. 1997 12v In park loud clicking noise.
  35. Turbo wastegate
  36. need help with truck value
  37. #100 fuel plate
  38. #100 fuel plate
  39. Question about changing the steering box
  40. grid heater issues!
  41. Front end issues
  42. Which shift kit to put in 47rh?
  43. 96 Cummins Missing?
  44. water methanol injection
  45. low idle when cold??
  46. hard start/running rough
  47. Serious grid heater question!
  48. 98 12v
  49. Mods for MPG
  50. Annoying headlight issue
  51. Gauges
  52. help needed
  53. Grid heater
  54. ii 66/65/12
  55. 1996 2500 wiper delay problem
  56. priming procedure
  57. # 0 fuel plate
  58. Cummins Newb, tranny question
  59. turbo whistle
  60. Valve body or shift kit?
  61. front end vibration.
  62. Help me unlock the potential! Pleeease!
  63. KDP tab bolt important question
  64. Advice on a 6BT swap
  65. GEN dash light, Alt questions
  66. 47RH rebuild
  67. Smelling Diesel Fuel after High Speeds
  68. My new paintjob
  69. fuel plate removal question
  70. Fuel Filter Mount Question
  71. Tc locking
  72. weak vacuum
  73. Weird Problem
  74. can i use a fire ring kit like a o-ring kit
  75. fuse box diagram??
  76. some recent pics
  77. NV4500 question
  78. Transmission problems HELP!!!
  79. Trans Question
  80. Sticking P Pump Rack
  81. info that could be helpful to some
  82. Allison MT643?
  83. Turbo-Back Exhaust System?
  84. rollover
  85. V10 to cummins
  86. Injector Info
  87. heat vents stuck on defrost
  88. adjustable control arms
  89. Ticking lift pump
  90. fuel problems in my 98 12 valve
  91. 47RH band adjustment (not the usual)
  92. Fuel additive?
  93. dash illumination/headlight switch
  94. fuel shutoff
  95. Built 47re no o/d or tc lock up. Please help!!
  96. buying a 97 12v for a swap project,
  97. remove diesel from truck.
  98. Front turn signal bulb
  99. will a fuel plate lower my egt's?
  100. should i buy it??
  101. New guy with a question
  102. ULSD and 12-valve Cummins
  103. 12 v 5.9 manual to semiautomatic transmission conversion
  104. overflow valve
  105. Stereo swap
  106. Trans problem
  107. Fuel upgrades with stock auto 47RE
  108. Marking its territory pretty aggressively....
  109. hard start in mild to cold weather
  110. What is wrong with this trans? Auto is stalling engine!
  111. 47re won't downshift?!
  112. advice
  113. sports bumper
  114. turnover
  115. Lights turn off and on when hitting bumps
  116. what wires run this thing ??
  117. block heater ??????
  118. new rig.......couple questions
  119. light blue haze after warmup
  120. Help adjusting 3k GSK
  121. afc starwheel wont move
  122. sacramento ca
  123. NV 5600 slave issues
  124. Dash!!
  125. Tires Fitting
  126. new turbo?
  127. fuel canister
  128. Brakes
  129. Downpipe mounting question
  130. 12v build question
  131. INTAKE HEATER
  132. 96 2500 club cab 4x4 356k miles
  133. steering box stabilizer, which one is best?
  134. Too much air not enough fuel?
  135. Help on losing oil
  136. 96 dodge cummins 3500 or 06 f250 powerstroke
  137. Transmission options
  138. jake brake
  139. Anyone know how to get ahold of jim jessup?
  140. Hx40 for work stock
  141. crank seal hellpp!!
  142. Need ideas for a light build.
  143. my cummins build
  144. Engine cools off while idling...?
  145. Help on th cummins
  146. 12v Blowby? (already searched)
  147. 47re Problem - 3/4 shift hunting. Fixed it, but nervous. Need Advice....
  148. power up alt..
  149. Rust
  150. Diesel Leak Cause Tranmission slip?
  151. Adjusting 4k gov springs
  152. lubricity additive
  153. Help, Cold starting problems
  154. help!! buyin truck
  155. Strange problem. What could this be?
  156. fuel filter relotaction on the 12v?
  157. a little more power?
  158. pto?
  159. 1998 mirrors
  160. Building a 96 motor for 500 to 600 hp
  161. Identify 60 lb Exh Springs-Different size from stock?
  162. REVMAX????
  163. 2wd nv4500 to 4wd?
  164. Throttle Response???
  165. everything dims
  166. mirror help
  167. straight pipe
  168. coolant hose wont seal right
  169. Boost elbow advice
  170. Ext Cab mpgs
  171. trying to make my 12 valve smoke a bit
  172. oem aluminum dodge rims fit on 98?
  173. is this a good deal?
  174. help with making power and smoke without buying injectors or turb
  175. trading for a first gen?
  176. Best Power Combo NV4500
  177. My setup
  178. JUST NEED SUM HELP!!!
  179. weird 5 speed?
  180. Well.... Now I know...
  181. Rear main, clutch, and flywheel replacement write up
  182. lift pump
  183. 97 dodge 3500- need some good info
  184. Nozzle ?s
  185. Need help 1998 dodge ram 12 valve
  186. Overdrive not working
  187. Which wire is the horn wire?
  188. manual lockout bearing preload?
  189. v10 to 12 valve swap
  190. Don't you guys feel like beating the heck out of
  191. is it worth it
  192. New toy
  193. Converting a 97 12v automatic to 6 speed
  194. afe bladerunner turbo?
  195. So Effing Mad.
  196. 97 12valve tappet cover oil leak
  197. eletrical problem head light
  198. ram body swap
  199. 47rh rebuild
  200. clutch
  201. push plates
  202. what is all this
  203. pump help cant find anwer
  204. 4x4 problems
  205. transgo shift kit has me pullin out my hair!! HELP!!
  206. Dodge radio swap
  207. turbo upgrade?
  208. Converter not locking up?
  209. questions about the rear main seal
  210. electric problems
  211. injection pump solenoid shut off
  212. SOS HELP!!!!
  213. Auto trans speed off
  214. Need advice
  215. Quick question about my 12 valve's idle
  216. Low Power
  217. 22.5 with 3:55 gear bad or good idea??
  218. Lost power
  219. no lights
  220. Reverse Light Switch
  221. Autometer mechanical fuel pressure gauge
  222. no coolant temp
  223. 1995 175 hp question
  224. Grid Heaters?
  225. runaway
  226. Silent Night
  227. No fuel to the injection pump ???
  228. rough running then sputters and dies
  229. brand new alternator not charging batteries
  230. I think i need to rebuild my whole front end!
  231. NV4500 and 241DHD questions
  232. Delivery valves leaking
  233. afc tune
  234. got to be a way cummins lift HELP HELP!!
  235. EGT Problems
  236. What do I need to do? Built Tranny
  237. buying a new 12 valve
  238. guesses on hp?
  239. Sluggish????
  240. Im in trouble, I stripped the band adjusting screw 47rh
  241. cold weather sucks
  242. Rear cam plug question for 12 valve re build
  243. Lift pump install
  244. junk transmission
  245. unleaded gas fear
  246. No Power, Gutless
  247. Fuel Filter change.
  248. Leveling Kit
  249. still losing coolant
  250. Changed Solenoid now No Power
