Injector Info
Old Feb 11, 2013 | 08:58 PM
senotext's Avatar
Default Injector Info
So my truck mods are in the sig, problem is i can bury my 1600 degree pyrometer almost instantly, I dont really know much about the injectors, when I did my head studs I got them at the local injection shop , I was told they were 90 horse bosch RV injectors, i did notice that they were a 4 hole injector though. Just wondering if this could be my egt issue, I really didn't think I had enough fuel for the special not to clean up, my truck Smokes pretty good at WOT
Old Feb 11, 2013 | 09:28 PM
H.R.D's Avatar
What boost numbers are you showing?
Old Feb 11, 2013 | 10:10 PM
senotext's Avatar
right around 50 psi boost
Old Feb 11, 2013 | 11:58 PM
H.R.D's Avatar
Do you have your smoke screw all the way in? What psi do you have your starwheel set to for full fuel?
Old Feb 12, 2013 | 10:03 AM
senotext's Avatar
Havent messed with the smoke screw, but the afc is set to full fuel at 40 psi
Old Feb 12, 2013 | 11:51 AM
H.R.D's Avatar
Sounds like they are just really smokey injectors, they may not have the correct spray pattern to optimize atomization.
Old Feb 12, 2013 | 01:56 PM
jkidd's Avatar
4 hole injectors are going to be 155* spray... your pistons are 145*.
consider some quality injectors with the correct spray pattern, you have 4 hole marine injectors which do make power, but at teh expense of smoke and high egt.
Old Feb 12, 2013 | 02:41 PM
senotext's Avatar
So that might be why I cant get better than 14 mpg out of it, I knew i should have just got some good injectors
