info that could be helpful to some
Old Feb 12, 2013 | 06:47 PM
codycatract's Avatar
Default info that could be helpful to some
i have a 98 ram with the 2 fog light relays. this is for the fog lights to stay one with hi beam and still be functional with stock switch. i know the dodges with the single relay you can jumper the 2 big prongs. this is for you all with the 2 relays and i am posting this cuz i never really found any info for the double relay setup. the only way it worked for me is the relay number 2, (the closest to fender) pull relay and look at prongs, there will be little numbers by the base of them, jumper wire 3 and 4 witch is the bottom bigger one and the middle out of the row of 3. this makes it so fog lamps and hi beams work as well as factory switch to turn them off. leave fuse number one alone(closer to motor) hope this helps, and be sure to run a fuse in the jumper
Old Feb 13, 2013 | 09:35 AM
JBearSVT's Avatar
Your '98 has headlight relays? I thought not having them was why I keep melting headlight switches.
Dfro22
Aug 12, 2015 06:07 AM
Jet A Fuel
Aug 3, 2015 10:45 AM
klein444
Feb 27, 2015 01:53 PM
Dec 3, 2014 08:10 AM
760DAN
Oct 31, 2014 12:53 PM
