Building block and head
Old Mar 13, 2013 | 01:14 AM
SOS cummins 1's Avatar
Default Building block and head
Well long story short I bought a truck and am building a 12 valve for it. I'm wanting to get a stable 600-700 hp out of the motor. The block I got with the truck had gotten hot and had melted the #6 piston..I'm wondering what a rough estimate would be to get the whole block bored .20 over? I also got a head that I want some work done to but I'm not exactly sure what... Opinions?
Old Mar 13, 2013 | 01:31 AM
Cow tipper's Avatar
x haha
Old Mar 13, 2013 | 11:48 AM
ricet07's Avatar
If you did the disassembly and everything yourself and they just cut up the block it should only be a coule hundred. If you have them do the machine work and assemble the long block it should only run you around 4,500.
Old Mar 13, 2013 | 12:52 PM
Oh sweet I disassembled it and plan on building most of it myself. Do you have any suggestions on what todo with the head? I plan on 150lbs springs from industrial injection but I'm not sure what else should be done
Old Mar 13, 2013 | 05:27 PM
94 12valve's Avatar
port the exhaust side and bowl blend the intake and exhaust. Have your machine shop cut o ring's in either the block or the head and get them to cut your rockers down for head studs
PCTechman
Sep 13, 2015 12:15 PM
Adam65
Jan 9, 2015 11:50 PM
metal_miner
Diesel Engine Conversions
Dec 23, 2014 11:40 PM
Lee Chisholm
Dec 3, 2014 05:58 PM
Stox5225
Nov 29, 2014 04:21 PM
