01 inertior in a 95??
Old Mar 9, 2013 | 07:49 AM
Bigblue1's Avatar
Default 01 inertior in a 95??
So i have a 95 12v and my dash is falling apart really bad. Iv found an 01 parts truck and i can get the whole cab really cheap. Can the interior be switch into my 95 or is it different due to the donor cab being from a 24v truck? This is my first cummins so its all pretty new to me.
Old Mar 9, 2013 | 09:38 AM
ricet07's Avatar
Just dropping in because I am curious as well
Old Mar 10, 2013 | 06:17 AM
jwirth's Avatar
Not a 100% sure but I would say the interior would fit the bodies are the same. All the bolt holes, and clips may not all line up.
The seat frames from and reg cab to club or quad cabs are different. As for the dash look and see if the bolts along the windshield are in the same place and angle is the same as the 01 and there should be one bolt on each side by the kick panels. Not sure if your 95 has the two studs with nuts in the middle at the bottom dash by the ABS mod on the 01 or not.
I know the Cawl panel has holes in it so you can remove the back head bolts on the 01 does the 95?
