installing cruise control on a 97
Old Mar 5, 2013 | 08:31 PM
Mikey81's Avatar
Default installing cruise control on a 97
im just looking to install factory cruise control on my cummins. has anyone else done this if so which parts do you need i see the wiring is there. can i steal a cruise set up off a gasser.
thanks in advance
Old Mar 6, 2013 | 06:39 PM
mytrucksmokesmorethanme's Avatar
other than having to switch out a steering wheel, the only other thing I would worry about is the pcm, there will be two circuts for the vehicle speed control servo in connector 3 cavitys 3 and 4 tn/rd and lg/rd these are control circuts for the servo and if you don't have them in the harness this just became a much m ore exspensive job
other than that you will need a speed control servo pigtail connectors most likely and the steering wheel controls and of course hardware for the servo
very doable job
good luck
scott
Old Mar 7, 2013 | 05:44 AM
Mikey81's Avatar
thanks i have noticed most of the wiring all being there. i think the steering controls can be installed with just a new clock ring and the switches
Old Mar 7, 2013 | 05:59 PM
sounds like a gravy job then, I am going to be swapping a SLT extended cab onto my base model reg cab here in a few weeks, I think I will use the collum harness and do the same thing you are doing, plus a little more, if I run into any walls ill post here about it, I also think while I have the body off ill pull the motor and freshen it up and maybe a rebuild on the tranny too , who knows, I have a extra 241 HD transfer case I cannot decide weather to sell or keep for a spare
lets dooeeet
good luck man
scott
burndiesel
10
Feb 7, 2023 01:15 AM
JBearSVT
Jul 9, 2015 06:16 PM
jdnetx
Jul 2, 2015 07:38 AM
Oil Igniter
Nov 27, 2014 05:56 PM
Cliffordthe24v
Nov 6, 2014 12:19 PM
