Parking brake cable help!?
Old Mar 9, 2013 | 01:45 PM
Dallimjp's Avatar
Default Parking brake cable help!?
Hey guys I'm hoping you can help me out, I recently bought a 96 3/4 ton and the brake cables were cut by the previous owner. I have been to 3 scrapyards, called the dealer and auto zone looking for this brake cable. It would seam I have an odd setup it looks like this[IMG][/IMG]http://i830.photobucket.com/albums/zz229/dallimjp/20130307_103530.jpg any info would be appreciated.
P.S. I need the left and right side cables.
Old Mar 10, 2013 | 05:58 AM
jwirth's Avatar
Possible someone swapped out the rear end with a newer style?
PM me the VIN and I see what I can come up with.
Old Mar 10, 2013 | 10:30 AM
ricet07's Avatar
That is a swap for sure because there is it should have a drum brake setup. They could have done a disk conversion and rigged up the ebrake from something else or like said about it could be a transplant from something else.
Old Mar 10, 2013 | 04:08 PM
tiremann9669's Avatar
I'd start by lookin at brake cables for a newer Dodge with rear discs.
Old Mar 10, 2013 | 05:48 PM
Dallimjp's Avatar
Thanks for all the input, you guys are f**cking awesome.I'm going to start looking at dodges with rear disk like tiremann suggested. By the way could the rear discs be the reason that the brake pedal feels soft and weak?
Old Mar 10, 2013 | 08:21 PM
ricet07's Avatar
Yes. I would just double check and make sure they are bled good but they will feel softer than if it had the original drums, it takes alot more fluid to fill the area in a caliper vs the little piston on the drum setup.
Old Mar 10, 2013 | 11:30 PM
Dallimjp's Avatar
Looks like it is an axle off of a 3rd gen 3/4 ton dodge. Thanks to everyone that helped out now to see if swapping a 3rd gen master bake cylinder will improve the feel of the brake pedal.
Old Mar 11, 2013 | 01:38 AM
Do you possibly have air in the lines ?
Turbo67
Jul 25, 2015 02:26 PM
Rcracer78
Audio Equipment/Electrical
Apr 20, 2015 12:49 AM
rwurbanwildlife
Mar 6, 2015 01:03 PM
Mat Zimmerman
Dec 8, 2014 11:37 PM
yams
Nov 29, 2014 09:25 PM
