Throttle Response???
Old Jan 17, 2013 | 07:01 PM
Smcdirtbike's Avatar
Default Throttle Response???
I'm looking to get a little more throttle response out of my 94 dodge cummins i have 90 hp injectors #0 fuel plate and timing adjusted and of course pump turned up.
i have heard of guys cutting a foot feeding stop bolt out and getting to higher rpms??? this would be nice cause right now rev limiter is at about 2400 rpm.
also the gas pedal has a lil slop in it as i can pull it up with my foot whats the problem there or can i adjust the linkage to pull that slop out and get a little more response that way??
thanks for your help guys all info is appreciated.
Old Jan 17, 2013 | 07:18 PM
daveO's Avatar
Put in 3k or 4k governor springs. Will wake it right up.
Old Jan 17, 2013 | 09:25 PM
olsmokey's Avatar
x2^^ i like my 4k
Old Jan 18, 2013 | 04:18 PM
JBearSVT's Avatar
Fill out your sig. Is it an auto? If so, and it's stock, then that's where 90% or your throttle response is getting pissed away.
Old Jan 20, 2013 | 12:30 PM
96blackcloud's Avatar
4gsk with 60lb valve springs and a electric lift/transfer pump will wake it right up
Old Jan 20, 2013 | 07:11 PM
BADJUJU95 12V's Avatar
whoa whao pull it over slick with all that if it is an auto you might as well **** in the ocean to rise the tide, HIGHLY suggest a upgraded torgue convertor, AND a valve body to go with it, for a manual take a good look at you clutch make sure it ain't burned or slipping. and higher rpms might as well it in burlap to catch all the pieces as they come out! but its your truck
Old Jan 24, 2013 | 07:00 PM
Thanks everyone it is a manual with a south bend extreme street clutch about about two months old
Old Jan 24, 2013 | 08:21 PM
JBearSVT's Avatar
Hm... a manual with throttle response issues... I'm out.
Old Jan 24, 2013 | 09:53 PM
coors_man_2005's Avatar
i put 4k's in mine and it made a huge difference
jeremiah1
May 19, 2016 04:58 PM
Blair@BD
BD-Power
Sep 10, 2015 12:29 PM
jeremiah1
Jun 18, 2015 05:01 PM
rusty 6.5
Jun 13, 2015 05:45 PM
1stgenswap
Nov 3, 2014 09:45 PM
