got to be a way cummins lift HELP HELP!!
Old Dec 20, 2012 | 04:50 PM
horsetranscummins's Avatar
Default got to be a way cummins lift HELP HELP!!
Okay i have talked to 13 people and 7 4x4 shops that do body lifts and all i get is no no no it can't be done...
i am one who thinks if there is a will theres a way so that being said, tell me how and what i will need to do.. the truck is a 1997 dodge 2wh 3500 cummins i lifted the cab 3'' over the weekend nothing went wrong and then i lowered back down, the intercooler will have to be worked with but THAT IS ALL I CAN SEE .
everyone says can't be done there has got to be a way to do this please help with any ideas
Old Dec 20, 2012 | 05:05 PM
Farmboy 2.0's Avatar
Why are you looking at doing a body lift?
Old Dec 20, 2012 | 05:11 PM
i am thinking of hauling a trailer weekly from fl to ky and i found this truck low low miles on it and one owner it just sits to low and to trailer towers over it i really would like to be up higher in the cab
What about leveling the front?
Old Dec 20, 2012 | 05:17 PM
i had just read up online where some guy had mover his fan up 3'' on his block the cummins had bolt holes a bit higher on the front on there blocks and add a longer 3'' pipe to intercooler and i just can't see how this can't be done??
i did but it got me maybe 1.5 higher not much
check this out
3 inch body lift with stock fan. - Competition Diesel.Com - Bringing The BEST Together
Last edited by horsetranscummins; Dec 20, 2012 at 05:17 PM. Reason: Automerged Doublepost
Old Dec 20, 2012 | 06:24 PM
RAW's Avatar
RAW
My leveling kit got me 2.5", and with air bags in the back I can haul my trailer with the truck at it's normal height.
Old Dec 21, 2012 | 11:34 AM
Truck Guy99's Avatar
I would go with RAWwilliam's setup. RAWilliams, where did you get your air bags and leveling kit? How much did it run you?
Old Dec 21, 2012 | 11:36 AM
His truck is a 2 wheel drive vs. 4 so the suspension and everything is different
Old Dec 21, 2012 | 12:34 PM
tiremann9669's Avatar
I wouldnt run a body lift on anything unless it was made by raising the steel mounts on the frame and was solid with stock thickness bushings
Old Dec 23, 2012 | 09:54 AM
are those 22.5 wheels safe to run and pull hevy trailers with
