rough running then sputters and dies
Old Dec 24, 2012 | 11:05 AM
Smcdirtbike's Avatar
Default rough running then sputters and dies
my buddy has a 96 dodge cummins and his truck is acting like it is starving for fuel and then sputters and dies we changed the fuel filter and when we changed the filter the truck started up ran rough for a second and then idled fine i was wondering if this meant it was the lift pump because we did fill up the new filter with fuel before putting on. didn't no if truck ran smooth awhile cause it had fuel in filter and after it used that it was starving or what??????
Old Dec 25, 2012 | 01:50 AM
12v15004x4's Avatar
Any time you replace fuel filter you normally get air in system. The less air you get in the better. When I replace the fuel filter I only fill new filter with what I get out of old filter and that leaves enough air to test lift pump. I start truck and let it run at 1200 rpm's. it will run smooth then rough and if it has a good lift pump smooth again. I have found a couple bad lift pumps this way!!! One on my truck and one on a customers.. After fuel filter you weren't clear on how it runs, still rough?
Old Dec 25, 2012 | 04:45 PM
sorry yes it still runs rough and we changed out lift pump and it is running fine now for time being
Old Dec 25, 2012 | 05:12 PM
BramanteCummins's Avatar
If its fine now you're set. Sometimes the preheater fails and lets air in it. Most bypass it.
