block heater ??????
Old Feb 2, 2013 | 07:14 PM
94cummin12v's Avatar
Default block heater ??????
i have a 12v in a pick up and when i plug it and i stick my head in the wheel welland i hear like a boiling nosie. from the block heater. it works well but i was wondering if its working to much haha i was courious if this was a normal sound ???? any input thanks guys
Old Feb 2, 2013 | 08:47 PM
Red_Rattler's Avatar
High Tech Redneck
Mine will make a couple gurgles when I plug it in then it goes away
Old Feb 3, 2013 | 09:16 AM
JBearSVT's Avatar
I wish mine gurgled when I plug it in. All I get is a faint little "click" somewhere up inside there. I know it's doing something, because when I forget to plug it in it's 10X grumpier when I go to start it again, but it's not doing much. There's definitely not any gurgling. And that makes me a little bit sad.
Thank God for heated seats
Old Feb 23, 2013 | 07:46 PM
Billy D's Avatar
Mine makes noise
Old Mar 4, 2013 | 12:37 AM
NEWBIE 98's Avatar
from a plumbing perspective it should have a hissing sound similar to plugging in a water heater when you first plug it in or you need to test the element. you can do it by testing the resistance through the element. and you may have to knock the scale of it for it to heat better.
Old Mar 4, 2013 | 06:54 AM
olsmokey's Avatar
a good working block heater will click and gurgle and make all types of noises. i wish mine worked that well it does just enough to make it start a little better. i think its getting worn out it had been in maine for for 17 years so shes been used hard.
Old Mar 4, 2013 | 05:10 PM
JBearSVT's Avatar
I think mine shorted out the other day, plugged it in and it sparked. Everything looks fine in the plugs and all, but it's definitely dead.
Old Mar 4, 2013 | 05:22 PM
High Tech Redneck
Got a multi meter? Set it to tone/ohms and one probe on the hot and one on the neutral it should make a tone if its still good
ramrunner01
Feb 25, 2015 11:14 PM
94_12v
Jan 4, 2015 10:37 PM
bikernut
Audio Equipment/Electrical
Dec 18, 2014 03:30 AM
TheBeattie
Dec 4, 2014 07:53 AM
Low_Life_Style
16
Nov 29, 2014 06:28 PM
