transgo shift kit has me pullin out my hair!! HELP!!
Old Jan 2, 2013 | 06:14 PM
cummins_guy89's Avatar
Beer transgo shift kit has me pullin out my hair!! HELP!!
Hey guys this is my first post here and I am really hoping this forum is better than the last one I tried. I filled out my signature with my truck and my Mods. So here is the prob... I installed a transgo shift kit and after adjusting my tv cable I was able to get 1st thru 3rd and lockup kicks in as it should but it will not engage into overdrive. The trans feels great it pulls a MILLION times harder than it did and has good firm shifts. I'm lost here guys. I have pulled the valve body out twice and triple checked every including check *****, line pressure, and all the springs. So please let me know and i look forward to talking to everyone.
P.s. sorry for the long post just wanted to get the whole story out there. Lol
Old Jan 2, 2013 | 06:20 PM
turbo2332's Avatar
OD is electronic. is the shift soleinoid in good working order?
Old Jan 2, 2013 | 06:26 PM
It was before the shift kit was installed. The trans operated normal before the install just went with the shift kit to get firmer shifts and higher line pressure to support my Mods
Old Jan 2, 2013 | 06:39 PM
turbo2332's Avatar
ok whats a fully built DTT trans consist of and why the hell would you need a shift kit on top of that? ALL built trans have a shift kit of some sort installed in them. could you have made something a little to big?
Old Jan 2, 2013 | 07:05 PM
mysterync's Avatar
I would check tps voltages before i did anything. Probably use a scan tool to command lockup and determine if the solenoid is being energized and has adequate ground. Often the throttle shaft and bell crank will become loose and cause rapid glitches that cant be seen with a dvom only a dso. The glitches can cause erratic operation of functions such as lockup.
Old Jan 2, 2013 | 08:01 PM
The PO had the trans rebuilt. It only has about 7,500 miles on it. I have the repeipt that shows DTT stage 3 master rebuild along with a billet input shaft and triple disc TC plus labor and everything. I believe that the factory valve body was used or it was a mildly built one since all the holes in the seperator plate had not been enlarged like transgo says for firmer shifts.
