Changed Solenoid now No Power
Old Dec 16, 2012 | 04:39 PM
roanokerivermud's Avatar
Default Changed Solenoid now No Power
Changed Solenoid now No Power on 1997 / ides fine / very weak pickup when accelerating / it appears the solenoid is picking all the way up / measured 2 7/8 roughly from pin to bottom of mounting bracket. I have pink eye so bad I can hardly see how to work on it. What should I look for?
Thanks
Really could use some help
Last edited by roanokerivermud; Dec 16, 2012 at 04:39 PM. Reason: Automerged Doublepost
Old Dec 16, 2012 | 04:44 PM
RAW's Avatar
RAW
Why was the solenoid changed? Did it not pull all the way, or at all?
Old Dec 16, 2012 | 04:56 PM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
did this part come from ebay china. my son bought one for his 96 and it wasnt worth 13 cents. i keep telling him to fix his shut down cable. you dont have to see if its going all the way, you can feel if it is back all the way
Old Dec 16, 2012 | 06:24 PM
relay stuck and burned solenoid / got solenoid, relay, fuseable link and starter diode from Larry B's
starts fine, idles fine, revs up / no power on road
Old Dec 16, 2012 | 07:11 PM
diesel pap's Avatar
you can take it back off and work the shut off by hand to open up all the way.
Old Dec 16, 2012 | 11:39 PM
tiremann9669's Avatar
Check your OFV, do you have a fuel pressure guage ? Clamp off the return line from the IP if that helps it's the OFV.
Old Dec 19, 2012 | 11:57 AM
got it fixed
Thanks
May 10, 2015 10:57 PM
explorer197143
Dec 28, 2014 01:14 PM
