help with making power and smoke without buying injectors or turb
Old Jan 15, 2013 | 11:45 AM
mr.diesel24's Avatar
Default help with making power and smoke without buying injectors or turb
I got a 95 12valve 4x4 and its my mudd truck i just wanna make a little motlre power and be able to smoke just for fun when out muddin. I already took out fuel plate and adjusted star wheel. Wat else can i do. Im at the power i want but no smoke. Pleade help.
Old Jan 15, 2013 | 12:03 PM
turbo2332's Avatar
these threads always get harsh responses man. partially cover the air filter to get more smoke. take away air or add more fuel. a little raw fuel is fun, not many of us can or will deny it but asking for just that in a diesel forum will get the haters swarming. these old trucks smoke when you start messing with them, its the nature of the beast, but a properly tuned truck wont smoke at WOT or just maybe a little. focus on making usable power and making a properly functioning system. if you are hapy with your current HP then by adding fuel and no more air you will loose noticable performance. look into a
-boost elbow
-some govoner springs
-A FUEL PLATE! come on plateless..... run an aggressive plate but tune the entire AFC not just destroying the factory tune by turning the starwheel. there are many ways to tinker with the afc.
-possible a rack plug put this will most likely gain you very little if nothing power wise at your level but it will get you a noticable amount more over fuel at WOT
-some type of intake
-a 4 inch exhaust or hell a hood stack if its an offroader LOL
thats a decent start but a bag over the air filter cant be beat for smoke output.
Greg
Old Jan 15, 2013 | 12:14 PM
Thanx and yeah i have seen hater but my point to haters is its not a street truck i use it for muddin and smokeis i guess fun . But i am just trying tobget it to smoke stock for now. Im gettin injectors eventually just wanna be able to smoke when im playin around. And i just got a fuel plate so im not running without one anykore
Old Jan 15, 2013 | 12:50 PM
turbo2332's Avatar
you will be very very happy with some 3k govoner springs and a boost elbow to allow you to run in the 30+psi range. cost you under $200 and you will be drive a %100 different truck. i wouldnt recommend any injector other than stock size if you are bashing the truck off road. way to much excessive heat. stockers will be just fine.
Old Jan 15, 2013 | 12:55 PM
Where do u get ur parts i get mine from purediesel power.com usually.
Old Jan 15, 2013 | 06:27 PM
turbo2332's Avatar
from all over but those guys do me well.
Old Jan 16, 2013 | 03:55 PM
Wats the best fuel plate
Timglow546
8
Jun 3, 2015 10:13 PM
wiremanWelder357
May 25, 2015 09:10 PM
shawnecarter
May 11, 2015 02:47 AM
