Delivery valves leaking
Old Dec 22, 2012 | 12:51 AM
slowboogy's Avatar
Default Delivery valves leaking
95 dodge 12 valve auto trans the delivery valves are leaking right around the top where the lines go into it is there like o rings suppose to be right there it's hard to explain its like right were the lines go into the top part... Any help??? Please
Old Dec 25, 2012 | 01:35 AM
12v15004x4's Avatar
Take all 6 lines completely off clean all sealing connections with compressed air, reinstall lines. This happened to me at the injector side and no matter how tight I got it it still leaked. It's just a compression fitting like a brake line...
Old Dec 27, 2012 | 07:45 PM
slowboogy's Avatar
so there aint no o ring or anything in there so clean them real good
Old Dec 27, 2012 | 08:32 PM
daveO's Avatar
There are o-rings down in the holders, but none up top where the lines come out. Like was said before, just take them off, clean them off and try again. Also while you have it apart, make sure the lines aren't nicked or anything.
Old Dec 31, 2012 | 11:44 AM
slowboogy's Avatar
do i need a special socket to fit them? and should i have any problems with air in lines or anything like that?
Old Dec 31, 2012 | 02:10 PM
daveO's Avatar
You need a special socket to get the holders off, but not the injection lines themselves. You will get some air in the lines, but not a terrible ordeal. When you're done, just crack the lines at the injectors one at a time to bleed the air out.
Old Jan 2, 2013 | 08:16 PM
cummins_guy89's Avatar
Agreed. It took me a couple times to get mine all sealed up after I did my head gasket.
Hutch58
Mar 21, 2015 12:13 AM
bryan0702
Mar 18, 2015 05:03 PM
countryboy040993
13
Mar 5, 2015 08:58 PM
Feb 18, 2015 01:00 PM
Stox5225
Nov 18, 2014 01:04 PM
