Fuel upgrades with stock auto 47RE
Old Feb 4, 2013 | 09:07 PM
Cumminsman1's Avatar
Default Fuel upgrades with stock auto 47RE
I have a 1998 12 Valve with a stock automatic transmission (with about 45k on rebuild). Its been taken very good care of, but I am not sure what the trans can take beyond my 4" straight pipe, and K&N intake. I put a set of 305's on it and lost some torque, and would like to make it up with some mild fueling adjustments, but a transmission upgrade is not in the budget for a little while yet. Anyone know if it can handle the stock fuel plate slid forward? I do have boost, EGT, and tranny temp gauges also, and dont drive too aggressively with it. Any insight would be great, thanks.
Old Feb 5, 2013 | 09:15 AM
olsmokey's Avatar
these trannys are lucky to handle stock power. you might be ok with a little added power. i wouldnt try much. my trans is built minus billet shafts and i still have to drive it easy with a fuel plate pump tuned 4 inch exhaust and 90hp injectors.
Old Feb 5, 2013 | 09:42 AM
turbo2332's Avatar
install a shift kit into your valve body. it will cost you $100 for the kit and the price of fluid. you will still need to stay out of OD when playing but you holding/clamping force will be much higher so you can bomb it a little more. and govoner springs are hands down the best $150 you will spend performance wise for a mildly build truck. it will make a different truck out of the old girl.
Dbleo351
Nov 20, 2016 09:34 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
moneypitk5
Feb 12, 2015 11:01 AM
