lift pump
Old Jan 12, 2013 | 09:09 PM
codycatract's Avatar
Default lift pump
I have a 1998 12v 5 speed with 0 fuel plate intake exhaust and star wheel in a tad. Wide open after going through couple gears just gets gutless like lift pump can keep up. Some people say they don't do intank pump till 04, and also if I pump starter I should be able to here it run. I can and don't see it. When I go to part store and ask for 98 replacement pump its a tank one. And I look for a 97 one and its mechanical but don't know where it would be, like my old dodge it was mid block on back driver side any info? I don't wanna burn up injection pump
I plan on doing air dog eventually but I need replacement now who has done this before the truck was made in the end on 97 supposovly considered 1998
Last edited by codycatract; Jan 12, 2013 at 09:09 PM. Reason: Automerged Doublepost
Old Jan 12, 2013 | 10:12 PM
jake74's Avatar
It should have a mechanical lift pump on drivers side of block,my 98 12 valve does.Should have 40-50 psi at wide open throttle.
Old Jan 13, 2013 | 07:35 PM
Found it. Kinda a bugger to see does around 25 psi at idle and around 40 psi at 2 grand no load sound good
Old Jan 13, 2013 | 09:55 PM
turbo2332's Avatar
sounds much better than normal. idle is fine but psi generally from a mechanical pump falls off pretty bad at WOT. if those are your readings you have ABSOLUTLY no reason to replace you lift pump. it feels gutless because the injection pump is defuling around 2200rpms and thus you loose all your acceleration and become gutless. install some govoner springs and enjoy.
Old Jan 13, 2013 | 10:01 PM
jake74's Avatar
That is just where it should be.
Old Jan 15, 2013 | 07:43 AM
I don't have a fuel pressure gauge yet and ya I can feel defueling but when I'm wide open it like spudders. And won't speed up unless I let off a little then get back into its new rig to me to imma replace it anyway till I get air dog. But how is changing the government spring compared to the VE pump
Old Jan 15, 2013 | 09:35 AM
turbo2332's Avatar
its internal pump work and will take a newbie a couple hours to do. i feel you are wasting money by replacing you lift pump. the reason for the spudder has already been told to you, its your money and time but im done with this thread if you wont listen to the advice you ask for.
Old Jan 15, 2013 | 11:57 AM
I'm not new to wrenching there is a difference between refuel and what its doin thanks for the help I couldn't really explain what it was doin but the lift made it go away
HeavyChevy95
Dec 21, 2016 10:36 PM
twinturbo12v
5.9L CR Performance
Nov 26, 2015 02:06 AM
landon025
Sep 8, 2015 09:21 PM
Renteria1217
Apr 16, 2015 11:38 PM
klein444
Feb 21, 2015 10:33 AM
