Lift pump install
Old Dec 18, 2012 | 07:41 PM
lodal cummins's Avatar
Default Lift pump install
So I'm having a problem getting this bugger to line up. When I insert pump I got about 1/4 gap between block and pump. I know this pump has a different angle then my 92 as its just flat. Which made it a cake walk. I've tried baring the motor to find lowest spot on cam lobe.maybe just didn't find it!!! Will this pump snug up when tightening bolts to close that gap? Thanks so much!!!
Old Dec 18, 2012 | 09:00 PM
turbo2332's Avatar
what are you trying to do? install a 2nd gen pump on a 2nd gen or a 2nd gen pump on a 1st gen? check overall length of the pump and the plunger from the old to the new. ifthey are the same use 2 longer bolts to reach the block. snug them down so that the factory length bolts reach then swap them for factory one at a time. check lenght first.
Old Dec 18, 2012 | 09:29 PM
Yeah I'm doing a 2nd gen. I think my cam lobe is not in lowest point. The plunger shafts are the same length old one v.s. new one. Plus I've decided I'm going to use studs instead of factory bolts. Seems it will make it way easier to mount the pump. I was saying my 92 was a cake walk but different LP pumps.
Old Dec 18, 2012 | 09:54 PM
turbo2332's Avatar
2nd gens are easy 2. use a longer bolt/stud and you will get it.
Old Dec 18, 2012 | 10:07 PM
tiremann9669's Avatar
It will snug up I think even on the shortest part of the lobe there is some pressure on pump arm.
twinturbo12v
5.9L CR Performance
Nov 26, 2015 02:06 AM
landon025
Sep 8, 2015 09:21 PM
Renteria1217
Apr 16, 2015 11:38 PM
klein444
Feb 21, 2015 10:33 AM
moneypitk5
Feb 12, 2015 11:01 AM
