JUST NEED SUM HELP!!!
Old Jan 14, 2013 | 09:50 PM
12vlve_blackbetty's Avatar
Default JUST NEED SUM HELP!!!
ok ppl i am new to the diesel world, i have a 98 12 valve with 326xxx miles on it. i have straight exhaust 3 in with 8 in tip. i have taken the screw off the p pump and turned it up like that but heres the ? i want black smoke and lots of it and more hp. i mean i know bigger exhaust (4in), cold air intake, injectors (not sure what size i may need), turbo (thinking bd killer b, but not sure), not sure on what else to do to the pump, and i dont wanna change clutch. so any and all help would b greatful.
Old Jan 17, 2013 | 09:18 PM
Truck Guy99's Avatar
Before you say or do anything, tell us about it's life. What does it do? Do you make a living with it and drive it everyday? Do you tow with it often? Occasional mud toy? If you do tow, what are you hauling? Even if a 35 foot long fifth wheel rv with 2 slide outs may weigh the same as a gooseneck full of hay, how they pull are different. Also, you can only turn it up so far before you smoke a clutch. Also, your gonna get grilled like a steak for wanting black smoke. If you want black smoke, put a plastic bag over your air filter. Also, get yourself some gauges before you go tweaking it too far. Also, what are your power goals?
Old Jan 18, 2013 | 11:04 PM
It's life as of now it's jus a fixer upper 2wd doesn't pull a trailer. She has 326,263 miles on her. I would like some black smoke doesn't have to b a lot jus some. And power wise idk that's we're I need help
Old Jan 19, 2013 | 06:47 PM
I would suggest first an upgraded intake system. The intake horn is incredibly restrictive. I would suggest banks or afe. Upgraded air filter setup. Then get some injectors bigger than needed for some smoke.
Old Jan 19, 2013 | 06:52 PM
H.R.D's Avatar
So basically you want diesel rice, wanna know how I know that, because you have stock 3-3.5" pipe with an 8" tip and you want it to smoke.
Sorry, but my advice: sell it and buy a honda!! Another tip for you a 1998.5 is a 24v not a 12v
Old Jan 19, 2013 | 07:01 PM
CR9712v's Avatar
dang given em hell!
Old Jan 19, 2013 | 07:27 PM
Also, boost elbow, grind fuel plate, and remove the turbo silence ring. Silence ring doesn't add power. Just adds sound. I'll probably think of some other things later.
Old Jan 19, 2013 | 08:03 PM
H.R.D's Avatar
Originally Posted by CR9712v
dang given em hell!
Yeah, jackheads like the OP are the ones running our beloved sport. So I don't take it easy on them when all they want is smoke and a have an exhaust tip over 3 times the size of their piping. Because people like that don't love diesels they are just band wagon jumpers.
Old Jan 19, 2013 | 11:58 PM
I tried to warn him in my first reply. Remember? " Also, your gonna get grilled like a steak for wanting smoke". I figured he would get crap for it.
Old Jan 2, 2015 | 01:44 AM
kryz9903's Avatar
He deserves the backlash with comments like that. You don't buy a diesel because you want to blow black smoke "and lots of it" , you get one for the durability and versatility of being able to do more than a gasser can. Smoke is a by product of power, not the other way around
