KDP tab bolt important question
Old Feb 18, 2013 | 02:36 PM
DerekP129's Avatar
Default KDP tab bolt important question
While re installing my kdp retaining tab bolt I used some red loctite 262 and I'm now feeling like an idiot and worrying if I should have used something different?? Should I change it ASAP?
Old Feb 18, 2013 | 02:40 PM
H.R.D's Avatar
You should be good. What did the instructions say from your KDP kit?
Old Feb 18, 2013 | 02:42 PM
DerekP129's Avatar
I never had a kit, I ordered a fel pro gasket kit and made my own tab but I have read so many repair threads online that each say to use a different loctite. Thank you for the fast reply though I sure hope I didn't do the wrong thing
Old Feb 18, 2013 | 02:51 PM
H.R.D's Avatar
What type of loctite do they say to use and why?
Old Feb 19, 2013 | 04:21 PM
Luther Grimace's Avatar
I really don't see how it could hurt it. The bolt threads into the cast iron block. I might be worried if it were aluminum.
Old Feb 22, 2013 | 07:37 PM
mytrucksmokesmorethanme's Avatar
Your sound as a pound
Old Jan 2, 2015 | 01:04 AM
kryz9903's Avatar
No worries my friend, I used red loctite in mine, as did afew of my buddies. You should have no problems at all.
Old Jan 4, 2015 | 11:10 PM
dezeldoc's Avatar
Red will come off if you ever need to repair it, i know they say permanent but unless you weld it will come off when the time is needed.
Old Jan 9, 2015 | 11:53 PM
detroitdiesel idi's Avatar
Don't worry its fine I use blue on any bolt in that front cover but red should be OK considering torque is only 18ft lbs
51Hudson
10
Aug 5, 2015 12:32 AM
