cold weather sucks
Old Dec 18, 2012 | 10:40 PM
DieselObsession76's Avatar
Default cold weather sucks
I have a 97 12v.. mostly stock it has a #10 fuel plate and maybe some other pump work I honestly don't know since I haven't had time to dig into yet and find out. But it absolutely hates cold weather, anything under about 40* without plugging it in will all but kill the batteries before it decides to do something with its life, and after it starts it smokes like no other for about 2 minutes.. is this something I should be concerned with? And is there a way to deal with it?
Old Dec 19, 2012 | 07:37 AM
yfzrunner's Avatar
correct me if im wrong but check out the grid heater or block heater may not be working.
Old Dec 19, 2012 | 08:00 AM
RAW's Avatar
RAW
I've fired up my 24 valve at -7*F without it being plugged in. I would say you definitely have an issue if you can't fire yours up at 35*.
Does it just crank and crank with no results?
Old Dec 19, 2012 | 10:42 AM
Yessir, it cranks over quite a bit before anything happens. It starts fine when the truck is warm or in warm weather, actually through the fall I didn't even need to cycle the grid heater and it would fire on the second crank. A local "performance specialist" told me have g the starwheel cranked up to much would cause this.. but that doesn't make a lot of sense to me, then again this is the same guy that didn't know they made a 62mm Phatshaft turbo and had to ask me who the manufacturer was... performance specialist you see...
Old Dec 19, 2012 | 10:45 AM
tiremann9669's Avatar
Does it crank fast when you try and start it or are the batteries weak from the get go
1997silverado
Jan 23, 2015 05:06 PM
iMixDiesel&Gas
Dec 27, 2014 09:57 PM
robbyS
13
Dec 20, 2014 04:25 PM
custom7.3
Nov 23, 2014 10:44 PM
12vbomber
Nov 4, 2014 10:04 PM
