NV 5600 slave issues
Old Feb 1, 2013 | 09:49 AM
moneypitk5's Avatar
Default NV 5600 slave issues
I have a nv5600 behind my 98 12valve. I have about 250k on the slave cylinder assembly, trans is rebuilt.
For several years, I haven't had any issues.
Now, when I shift from neutral to reverse at a stop, i grind gears. If I shift to a forward gear before getting reverse, it wont grind. It seems like my slave cylinder isnt fully disengaging the clutch.
What say yall?
Also, I am putting a new South bend dual disk DD/towing clutch in with my new engine.
Should I be looking at heavier duty master/slave cylinders anyway?
Old Feb 1, 2013 | 10:44 AM
stodg73's Avatar
I just replaced my master and slave cylinder and it made a world of difference. Mine was bleeding down while pushing in the clutch.
My suggestion is to ask South Bend to see if you need a heavier master and slave cylinder, or if you can use a stock replacement.
Here is my write up about replacing the master and slave cylinder.
dwmeehan
Jan 29, 2025 12:13 PM
Apr 11, 2015 02:47 PM
ronstop
Feb 26, 2015 09:48 AM
Kennyw250
Jan 14, 2015 07:47 PM
Polaris04
Dec 1, 2014 08:27 AM
