Annoying headlight issue
Old Feb 23, 2013 | 01:48 PM
DieselObsession76's Avatar
Default Annoying headlight issue
My headlights decided they were sick of life and quit working the other day. Well my headlights switch was already junk and running off of a toggle switch so I replaced the whole unit today and hoped it would fix it... Nope definitely not, I still have no headlights.. But I have parking lights and cargo lights and whatnot, just no main headlights.. Is there a common problem point or anything I should check? I'm not too wire savvy so by all means talk to me like I'm an idiot..
Old Feb 23, 2013 | 03:18 PM
daveO's Avatar
Did you take a look at any fuses?
Old Feb 23, 2013 | 03:40 PM
yes sir. I checked my fuses and the relay and they seem to be fine
Old Feb 23, 2013 | 06:18 PM
daveO's Avatar
How did you test the relay? Did you try putting a known good relay in its place?
Old Feb 24, 2013 | 10:09 AM
Sturgeon County Diesel's Avatar
Check the relays like daveO said using a new relay. Also you can follow wiring and check for melted fuseable link. If your park lights worked before (also run off headlight switch) I'd say you may have forgot a ground somewhere. Most important part of any auto wiring isn't 12v power, it's a good ground. I had a similar issue and it was grounds from headlights to front fender/rad support
Old Feb 24, 2013 | 05:20 PM
i checked the relay by replacing it, put a new switch on and everything.. if i pull the high beam lever they will flash but i cant turn the low beams on. which makes me think that I am having a wire issue somewhere but honestly I have no idea where to look
Old Feb 25, 2013 | 10:23 AM
daveO's Avatar
Will your high beams stay on? Did you take a look at the bulbs, possible they just burnt out? Where at in PA are you?
Old Feb 26, 2013 | 01:04 PM
nope they just flashed... I got it fixed there was a broken wire in the dash.
Oh and im from Polk Pa.. its roughly half way between Pitts and erie in the middle of the woods
Dec 10, 2019 10:10 AM
dskewes14
Sep 14, 2015 09:19 AM
Cummins_Power_13
Feb 4, 2015 09:55 AM
Oct 23, 2014 08:10 AM
