- boost fitting question.
- In need of knowledge
- SDX Injectors 5 x 14 (weston specs)
- Limit of STOCK injectors
- Southbend possibly problem?
- what size tires are you guys runnin?
- Fuel Plate #10 or Bosch 300 Injectors
- quick question
- which transmission
- what clutch?
- 4K GSK Cruise Control Surge
- 3K GSK or just tighten stock springs 3 clicks???
- guages????
- HTT 62/71-13 SS
- rpm defueling
- Found a 1994 CTD 4x4 to tare up
- First timer, moderate mods...
- cummins 12 valve fuel plate
- Water/methanal
- smoke question
- smokems vs. ii
- why it shift like that after vb?
- drag racing
- IC Boots
- timing question.
- boost elbow
- Custom Valve Covers
- who makes a good traction bar setup?
- low boost excessive smoke
- hp rating
- looking for some advice from the experienced
- help now
- BHAF
- head studds
- Clutch/Fuel Plate
- I Got My Fuel Plate Dont Think Its A 5
- hx35 hotpipe to s400
- Debombing/Rebombing
- 843 p7100
- Citydiesel DV's and 370 marines!!!!!!!!
- What turbo??
- will it handle it easy?
- dv help.
- removing the fuel plate.
- power
- what fuel plate
- dtt tranny?
- 97 tranny Question
- a real billet tc?
- Need some help
- Sun Coast Loc-Up Controller
- how to switch vb?
- looking for a clutch
- B2 turbo under Hx35??
- 4 gsk with a auto trans???
- 3gsk how to install?
- timing chart
- #100 fuel plate
- with a t an vb how much more hp?
- Fuel Plate Diagram.. Thought some could find it useful
- s360 on top
- rack plug
- retarding timing
- ht3b twins
- 5X16 injectors? too big?
- egt?
- s300 turbo?
- What is the best "Out Of The Box" performance P-Pump?
- Another Turbo Thread
- studs vs studs+oring
- were can i buy a #100 fuel plate?
- turbo
- Injector Testing Today........
- 4wd shifter
- fiberwerx prerunner fenders
- TC Lockup Switch
- fuel plate question
- hood stack
- fuel plate specs
- turbo? lost please help....
- 12 valve Twin Ram Intake
- Hood Stack vs Stacks
- one piece headlights
- how to tell you gov spring are not tight enough
- help please
- 98 12v
- Auto Trans Upgrade
- Autometer EGT help
- need more power
- loping?
- Rack Plug
- #11 plate questions
- s300
- intake manifold elbow
- what can i do to get power?
- got the timing set to 15* and KDP done.
- HX55 DP?
- o ringing
- get money son
- wat now
- 6spd
- short shifter
- good cam
- increased EGTs/with new fuel plate
- turbo timer
- steering shaft
- yeehaw
- #100 PLATE IN STOCK LOC. OR SLID BACK A HAIR
- 5k rpm?
- gauges an my numbers
- exhaust manifold
- what fuel plate cut is best
- Aftermarket Radiator
- 12v fuel plate
- moving stock fuel plate forward
- what to set my timing at?
- turbo timer??
- cummins 12v
- KDP fixed?
- stacks lower egts?
- NEW TIP
- Silencer ring
- hx40
- Scotty II
- Exhaust mods
- turbo compressor housing thought
- WTHeck
- stock turbo mods
- 3000 or 4000 rpm p pump governor springs
- How do i tune the afc?
- trailer towing
- h40 style compressor outlet
- Transmission upgrade?
- Air Intake
- delivery valves
- Stock exhuast manifold vs. Aftermarket
- injectors
- would like more power
- chevy wheels
- biggy b will a turbo off of an 04 will fit 95
- Fuel Plate Question
- EBay parts
- intake horn
- hey guys i just got my first diesel
- Odd Application for a 12v
- more about fuel plates.
- 500 hp
- how can i make a downpipe
- fuel plate
- how much power can i expect to make
- injectors.
- Converting to a p7100
- intercooler pipes/boots
- Pulling Truck Fuel System.....
- #100 plate? will it hurt my drivability or mpg?
- boost elbow installation on a 1997 12v
- Umm more fuel.
- heres a new one
- 4k kit install
- Tranny won't shift right
- BHAF
- Valve Spring Replacement
- can anyone recomend a reputable diesel shop?
- what does lazer cut delivery valves do?
- help with gauges
- truck mods
- idea for filter skin?
- Cold Air Intake?
- best combo for 450 rwhp 850 ftlbs?
- wat fitting on the pyro
- fueling question
- ht3b switzer with 26cm undivided housing
- lowend power
- thanks
- Fuel plate description?
- turbo change
- 12V vacuum location?
- DTT
- any one know about 4 k gov kit?
- Which lift pump to buy?
- 3000 or 4000
- GSK spring kit question
- any one make intake heat shields?
- Fuel Plate
- twin turbo thought
- injector and DV valve questions
- Gov Spring Questions
- 12V programmer ??
- injectors
- propane or water/meth
- 4000 gov springkit
- pump identification?
- Banks Powerpak Kit
- water methanol
- Boost Elbow - where is the link?
- Injector and Fuel Plate ?
- home made 3000 gsk
- balanced
- turbo ?
- pressurizing coolant system
- 5 inch exhaust
- down pipe adapter
- Need some help please
- Going to the dyno
- turbo upgrade?
- 4000 gsk install ? with picture it is all apart
- 3000 to 4000 gsk ?
- New exhaust
- Head work?
- Gauge Kits
- blockin the waste gate.
- Down Pipe
- fuel plate
- Star wheel
- pyrometer question
- 370 marines vs 370 new eras
- is this a true 887 pump?
- Will these mods require a turbo?
- How much HP?
- injectors
- About the mack plug/rack plug?
- 550-600 Hp Goal
- 3000gsk vs.4000gsk
- what is this air filter
- 12v hp mods help
- 12 valve ez pulling mods
- Will These Housing Actually Help ?
- looking at the next upgrade...
- Fuel Plate
- School Me on Fuel Plates
- ATS 3 piece mainfold
- P7100 pump question
- not enough rpm's
- Drive pressure gauge
- tach?
- #11 fuel plate
- delivery valves
- gov kit & valvespring prob
- Anyone have a D-Tech Turbo?
- injectors
- dv desicions
- Detune?
- Springs and what not
- #6 plate
- gettin to the fuel plate
- Paranioa or not
- tst vs ebay
- Sticks? What Injectors do I have?
- ~*TRUCK SHOW*~
