PDA
View Full Version : Ford Powerstroke 03-07 6.0L
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18
  1. New to me 2006 6.0L. Help wanted.
  2. Do I really need a new turbo?
  3. 6.0L write up
  4. 2003 6.0 runs rought
  5. wheels and tires for my 2006 f250
  6. Diesel smell
  7. Code P0299
  8. Have you missed me yet?
  9. Need help. Trucks Tampon fell out. She's p!ssy
  10. New to 6.0 world: What do i need to do?
  11. Help: Died on freeway, No start, No throttle
  12. 6.4 PSD
  13. stock downpie size,
  14. Stiction or bad injectors????
  15. 6.0 problem help!!
  16. A funny problem
  17. And the hunt continues
  18. Turbo dumping
  19. What to do next??
  20. 04 6.0 turbo
  21. Auto ingineuity
  22. 5R110
  23. sinister coolant filter color change
  24. Code P2284???
  25. exhaust question
  26. Water pumps!!
  27. Which EGR Cooler upgrade
  28. Rev X
  29. Could this be coming from my turbo?
  30. fuel injectors
  31. 2007 Powerstroke 6.0 No Start
  32. trans cooler fitting tool for bottom of radi?
  33. Rough Idle
  34. 06 6.0 hot no start
  35. help!
  36. no.7 cyclinder blows o-rings on injectors
  37. Diablo Predator programmer for '05 6.0L
  38. Trouble codes
  39. 6.0 lovers might be interested
  40. Softly Surging Under Accelleration
  41. Oil temp-coolant temp
  42. where to buy delo nitrate free elc
  43. Vibration
  44. New 6.0 driver with problems
  45. 06' F-350. 6.0L blowing white smoke
  46. head gasket theory
  47. Fuel mileage with Powermax turbo
  48. dreaded inspection
  49. studs in the heads
  50. Mdub this is for you lol. and anyone else.
  51. 6.0l Injectors
  52. Gauges?
  53. horsepower and torque rating
  54. Need some advice. Getting irritated lol.
  55. coolant question
  56. Have code P0069?
  57. Sct x3 opinions
  58. Horrible fuel mileage
  59. 6.0l bent valve broken rocker
  60. On line manual
  61. Repairing FICM
  62. exhaust
  63. auto setting on lockouts not working
  64. how to change powerstroke 6.0 fuel filter
  65. 04 to 07 6.0 difference?
  66. Price of used engine
  67. FICM's wanted!
  68. Driving With Bad Head Gaskets
  69. removing 6.0 broken glow plug harness
  70. Should Anyone encounter this problem...
  71. 2005 6.0 problem!
  72. Oil analysis
  73. sct system error. need help
  74. powerstroke
  75. Just Thanks
  76. Purchase of an 06 F350 PSD...
  77. Head bolts
  78. 04 6.0L gutless until up to temp
  79. What year ?
  80. Gauges
  81. add a leaf that i dont need
  82. Temp Questions
  83. android app for powerstrokes???
  84. test results on best fuel additive pretty cool
  85. need opinions on an inventions in the making
  86. is this normal???
  87. Swapping early style hpop to later
  88. 4x4 light not coming on
  89. 6.0 question
  90. straight pipe exhaust question
  91. when considering HPOP replacement
  92. 03 turbo problem
  93. Ford 6.0L Cylinder Kill Test (G2 Hickok) Question
  94. ok got an 04 6.0 f250 fx4 wont rev over 2000 rpm
  95. Sct tuner
  96. SCT X3
  97. Plug in feature
  98. 2 questions
  99. Just saying Hi to everyone here! I also have a small prob.
  100. Misfire information
  101. Dome light
  102. F350 6.0 L FICM solder fix
  103. dealership problems
  104. 2005 F250 6.0L AC Switches to Defrost
  105. Aftermarket Stereo install FYI
  106. Diesel Bombers Newb
  107. need some help guys
  108. Barking turbo
  109. Lawsuit
  110. glowplug tutorial
  111. Transmission upgrade??
  112. 6.0 loses power
  113. dealership just called...
  114. lucas tranny fluid a no no????
  115. stock headlights?
  116. Tuners/Programmers
  117. Still lots off smoke... HELP!!!
  118. Glow Plug GPCM test verification
  119. FICM Test
  120. Loosing coolant
  121. CEL P2290 ?
  122. what oil to use
  123. lost in hawaii oahu
  124. how to remove a stock air filter?
  125. 6.0 what to do
  126. SCT 3015
  127. better mpg?
  128. new oil & egr cooler, new problems arise
  129. 2005 6.0L low power on T/O & other issues
  130. Deleting my EGR cooler
  131. Was It My FICM All Along?
  132. 2007 6.0 Purchase
  133. Do all 6.0 have oil cooler problems?
  134. to chip or not to chip????
  135. EGR Delete Questions
  136. Two newbie questions
  137. engine surging
  138. glow plugs
  139. 2005 F250 power steering oil cooler info!
  140. When at Idle Truck is Making New on 2 Way Radio
  141. 2005 ford powerstroke 6.0 bogging down
  142. new here soon to be owner of PSD few questions
  143. big fuel leak?????
  144. Update to 6.0 2004 no power low power
  145. HELP lots of white smoke
  146. Lost in the smoke
  147. stutter?
  148. 04 F350 motor cranking..cranking..cranking..no start
  149. Best placement for Pyro?
  150. Trans trouble.. URGENT
  151. Blocks or springs?
  152. ppe whats it worth
  153. got my egr delete done and out of the way
  154. water in fuel....now wont start
  155. Ever see a check engine light go off
  156. More HP!
  157. Please help!!!
  158. 2 stroke oil in fuel will it pass emissions?
  159. Edge cts
  160. 2006 f350 super duty 6.0 starting problems
  161. stock 05 wont start
  162. should i delete my egr
  163. ford4x4fan
  164. For Sale: SCT tuner with IDP custom tunes
  165. 6.0 wont start
  166. Fuel Milage out of 05-06 6.0l
  167. 03 6.0
  168. 5" turbo back
  169. Custom Bumpers
  170. Cabin filter?
  171. are 6.0 really that bad
  172. sluggish start
  173. Replacing head gasket on 6.0
  174. Code Readers
  175. What's the best fuel & oil filter for 2006 Powerstroke F-250
  176. Tire Size
  177. replaced film with a rebuilt
  178. Transmission Help
  179. heater box
  180. 04 6.0L bucking when in overdrive
  181. Help I have a problem
  182. Sinister EGR delete kit opinions good/bad
  183. Junk masterpro fuel filters! dont buy!
  184. Leveling Kits
  185. Strong smell of diesel after you get on it...
  186. surging and Idle
  187. Leveling kit
  188. 06 Powerstroke trouble code P0299?
  189. 6.0 Powerstroke Wont Start NEED HELP!!!
  190. Loss of oil pressure while driving
  191. stroken and a lot of smokin?????
  192. Any problems with turbo or EGR after removing muffler, and or cat???
  193. White smoke on cold start up
  194. Gauges
  195. surge and then dies ???
  196. early 03 6.0 powerstroke injectors bad?
  197. 2005 Ford F350 Crew Cab Wheels
  198. NEWEST RIMS THAT FIT 05 F350
  199. up grades for my 6.0/ lookin for opinions
  200. 2005 FORDF350 CREW CAB INTERIOR COLOR
  201. 2005 FORD F350 WHEEL OFFSET
  202. 6.0 problems
  203. Which tuner?
  204. mirror with marker lights
  205. EGR on 06 F250
  206. Batmo wheel, calling all 6.0 bombers
  207. Banks vs DPP vs Hypertech Intercooler
  208. p2286 Mind of its Own!
  209. 04 f350 6.0 EGR valve
  210. 6.0l HPOP
  211. No power 04 6.0 powerstroke
  212. Fuel filter change tricks and tips for the 6.0 powerstroke
  213. converter switch
  214. Cold weather fuel leak
  215. Bad injectors
  216. 2003 Ford F-250 Blown Fuse #22
  217. different turbos?
  218. berniebern
  219. High Idle Mod on 2005
  220. rough idle, no power when in drive
  221. please help! electrical problem!
  222. smoke, burns my eyes
  223. EGR went bad.
  224. 2010 E350 help
  225. Fuel bowl
  226. 2008 front clip conversion.
  227. Gauges
  228. what is the best alternator
  229. Ford F350 6.0 2004 low power or no power
  230. leaking oil base pan
  231. FICM test procedure
  232. Egr problems
  233. p0263 p0266 p0269 p115a
  234. Thinking of selling....
  235. Fuel Reg Kits
  236. B W gooseneck hitch??
  237. 6.0 Record
  238. Straight pipe question...
  239. 4x4 disengage?
  240. What kind of oil for winter?
  241. Turbo might be dying?
  242. Engine quits on highway
  243. Bad Fuel or Alge/Fungus??
  244. White smoke on Acceleration(only under load)
  245. Erratic engine speed and won't start after
  246. F250 FRONT AXLE TRUCK PULLS
  247. 6.0 programmers
  248. EGR Fan Issue
  249. Trailer brake controller
  250. 6.0 exhaust valve failure
