- A518 TC Lockup Switch?
- HX35W Swap
- Leaking Fuel
- Cruise Control
- Part Number For Door Clips....
- Amsoil Air Filter
- Need Front End/ Engine Bay Pics
- A/C Blower Motor And Or Switch
- Parts Help
- Dually Tire Question
- Truck Engines Used As Industrial Engines
- Fuel Pressure Question
- NP 205
- You May Have Seen This Truck In The TDR Calendar
- Part Numbers For Lift Pump
- Whats Kind Of HP Numbers Are You Guys Getting With A Rotary
- VE Pump Videos......
- New To Site
- THE VE PUMP AND YOU.......
- Shifter Assembly
- Step By Step Injection Pump Install
- Heater Problems
- More 1st Gen Part Numbers.....
- Dana 61 Info
- Where To Buy
- Head Gasket Under Boost
- Fuel Pressure Problem
- Battery/Volt Guage
- Cleaning Injectors
- 1st Gen Rearends
- IIIINNTRODUUUUUCINGGG......
- Need Some Advice
- Lift Pumps
- 16x12 Or 15x14 Steel Wheels
- How Long Will It Last
- New Injectors, I Think?
- Trans. Temp Gauge
- Reflective Rear Window
- Fuel Economy
- Killer Dowel Pin...In 1st Gens.
- Jumpy Speedo
- Hotrod VE
- Veg Oil
- New Tiny Tach!
- Tranny Fluid Change
- Door Panel Clips
- Where Are All The 1st Genners???
- Grid heater?
- Help needed near S.A. tweaking a VE pump
- Headlight Rewire With Relays
- How Are Water Pumps controlled?
- VE Pump
- what is up with this thing
- Online Manual
- What Turbo Is This?
- Overdrive Systems for the 727
- What Guage Pod is this?
- Need bigger exhaust
- Selectro Hubs
- I NEED A DRIVERS SIDE DOOR
- HELP! Truck rides like a rock
- spacer and trac-bar ???
- Fuse Box Pics Please
- Need some advice
- Which Exhaust Housing Do I Have?
- Cruise control
- red seats
- What brand of ATF
- So, my neighbor has this 89.......
- I See Some Familiar Faces Here!
- another place to talk first gens
- Smoke/Performance
- The Other Forums???
- Show Us Your First Gen
