- Heater core hell
- rear diff
- Death Wobble
- headliner
- TOO LOUD!!!
- are they serious?!?!?!
- Got a wierd noise.
- Miss through the RPM range
- Turning up 8.3 Cummins?
- 5sp to 6spd?
- killing your rear tires
- Rpms?
- 1997 12 valve broke the sensor above crank shaft
- too much power!!
- injector problem
- Think it's bad?
- T-case Problems.....
- DAMPER on way out,where to get new one?
- bolt up turbos?
- switch from auto to 5 speed
- Great Power loss....
- bed lined rockers
- John Deere Turbo
- White smoke/skipping?
- Super singles on a dually
- smoke
- Hello there
- idling her up!
- its about damn time
- Third Gen. Mirrors.
- Oil Leak
- track bar problem
- 4th gear acceleration vid
- stock EGTs
- Parking BRAKE BROKE cant change crank pulley?
- filter relocate
- help abs
- dodge cummins 1994 12 valve
- Advanced timing caused high idle
- lift pump rebuild?
- STUCK INJECTORS!!!!!
- specs
- 1410 slip yoke
- rookie questions?
- low on power?
- advice for p pump
- just wondering
- No power and lots of white/gray smoke
- 96 dodge 2500 4x4 wheel bearing noise?
- really starting to make me mad now
- future upgrades
- Dyno Results
- Overfull on Transmission Fluid.
- 12v questions
- painting the trim factory color
- 10 plate to a 0 plate?
- High beam issues
- HT3B turbo
- killer dowel pin
- water meth
- Wheel Hub Bluessss???
- fuel leak
- breakin?
- 90 horse injectors
- Heater cord plug replacement
- steering wheel play
- Rebuilding the 12v ......What would you do?
- power steering
- It's been asked b4 but I got another ?
- Heater Problems
- chewed up serpentine
- high idle
- rebuild
- 4wd Gear
- dignostic connector
- knock
- Steering
- Timing
- 4wd problems
- need advice on a 95 3500
- twins
- cant adjust gov. arm!!
- Window seals
- Injection pump install
- 48RE in 12v?
- Smoke
- Gov. Spring Question
- cold air intake
- Fuel Lines
- oil filter
- Modifications
- towing question.
- Front U-Joint Help
- P7100 injector pump timing help
- 1995 5.9 engine keep running after ingnition stop
- Glow Shift Gauges
- Rear brake question.
- trans
- Hey guys I need help modifying my 12v pusher motorhome
- 12 valve fuel plate question
- Do P-Pumps Knock When Going Out
- Starting issues in the cold.
- Speedo Gear
- difrence in 12 and 24 valve trannys
- Where to buy an oil dipstick
- p pump power ratings question
- Fuel guage trouble
- lost power and cant hear turbo
- Loud intake or filter
- Truck geling up
- Boost pressure
- Engine lopes after load
- Whats the Dimensions of a 12V Engine ??
- Hard start after #100
- 12 valve intermittent power & throttle response loss
- Turbo time
- mpg
- Fuel Problem
- head.
- oil pressure Q's
- cant someone explain how to use the auto tranny lock mod?
- Need pics
- Warming up Probs.
- PART NUMBER CHECK IT OUT!!! IT HELP ME OUT. MAYBE IT WILL YOU TOO
- Holset hx40 wheel and housing p/n's , if you care
- Bad Injector?????
- Gov. Spring Adjustment????????????????
- no plate and gutted afc to plate and tuned afc?
- P7100 injector pump shut off question
- Track Bar Question
- Headliner Woes
- KDP?
- Fuel gauge
- 47re tv cable concern.
- volt meter
- afc plastic hose boost line?
- Intake Horns vs Flow
- 1995 trans lines and cheap paper clip fittings
- dual exhaust
- Transmission computer maybe?
- tranny swap
- 47re Won't shift at wot
- strange noises (engine)
- What do I do?
- Tranny Problems Maybe ???
- Trim
- NV4500 questions
- 12 valve
- '94 F350 knuckles & hubs on '97 2500?
- I'm assuming starter?
- Tires
- Oil in water?
- Fuel Plate effect on Auto trans life
- 12V diagrams
- Gutting your AFC?
- $150 solenoid or $1500 P pump?
- Best place for freeze plugs
- Blowby oil screen?
- trans problems
- Tranny swap ??
- lift kit/stacks advice
- Thermostat Problems
- Good deal?
- Replacing motor mounts sucks
- help Hard starting 96
- Good Deal?...or keep lookin kid...?
- Wiring Harness
- Super B
- Vaccum diagram
- Missing at 2200rpm?
- Gauge Question
- coolant on the ground.
- Starter Hits my New SBC DD Clutch Flywheel
- Sway Bar Links=Death Wobble?S
- AfterMarket 47rh
- Front Driveshaft
- I Think My P Pump Took a Dump
- poping at 2000 rpm or more
- Dash Light?
- grid heater delete
- band adjustment
- a couple questions
- trans issues
- Lift Pump Question
- Air horn bolts
- Batteries Suggestion?
- mopar paint jobs
- Grid heater ground?
- trans help
- ok here it goes
- which ones?
- obd2
- 12v LP bypass plate
- fuel plate
- Heat Shield BHAF
- 4x4 help
- 4x4 slips in and out.
- Adjusting Idle RPM
- 12 Valve help
- new trans
- Dodge!!!!!!!
- how low can i turn my idle down
- waterboy system
- wastegate
- track bar
- turbo shaft play
- about had a heart attack yesterday
- overhead display
- fuel pin
- head
- P7100 pump numbers.
- pull cable for fuel shut off
- egts
- Stock 12 Valve going for 400-500hp. Any suggestions?
- still leaking oil
- blow by
- thermostat
- 60lb valve spring installation help
- tune up
- fuel plates
- converter lock up
- 6-speed
- Why wont my truck warm up
- power steering
- Idle Adjustment P-7100
- timing
- block heater
- got a bad hi/low idel miss, any ideas???
- 5.9 vs turbo 400 with gearvender
- nonwastegated turbo
- 12 valve
- fuel plates
- thottle position sensor
- sliding the fuel plate?
- bed toppers
- weird
- just a few auto meter gauge questions
- valve body and tc
- tire clearance
- ABS
- best 12v
- Trans cooler lines
- i think this is the last issue
- more issues
- 12 volt block heater????
- rpm
- Intake heater
- stack
- Looking at 60lb valve spring how do I install myself ? and what brand would recommend
- do they make chips or programmers for me?
