View Full Version : 6.7L Performance
Pages : [1] 2 3
  1. 6.7 turbo mods
  2. overhead reading filter is full
  3. Custom Wastegate Install
  4. Pypes Exhaust
  5. egr delete kits
  6. New Desiel
  7. torque converters ?????
  8. Trying to let my 6.7 breath....
  9. Intake horns?
  10. Duraflex SRT10 hood???
  11. Aftermarket tow mirrors
  12. dpf delete on 07 cabandchassis
  13. Mini Maxx Update Request Thread
  14. Replace the 68rfe Tranny and Turbo with???
  15. just bought an mp8
  16. Deletes and what they do?
  17. New Aero D-60 installed!!. writeup and pics
  18. 07.5 question
  19. Stealth DPF delete pass emissions test?
  20. downpipe
  21. Aurora Plus 7500 Compound Turbo System
  22. Deletes done but wont smoke
  23. 68rfe converter lockup when cold
  24. new to 6.7, have deletes and mini max curious on what else to do ?
  25. MPG!!!!!!! READ
  26. DPF FULL??
  27. are they reliable
  28. 2008 6.7 Waranty
  29. 2012 upgrade wish list
  30. Aftermarket advice
  31. Spedo and Gear Calibration
  32. P0132 With DPF delete.. HELP!!
  33. Adding Wastegate next
  34. Valair Dual Disc
  35. What tune you run
  36. fuel rail pressure low
  37. best tranny fluid for g56
  38. Exhaust systems
  39. Dual cp3's who makes the best kit?
  40. dpf delete sims need some help
  41. Safe levels for smarty jr.
  42. Clutch
  43. deletes
  44. H&S Does It Need Help
  45. anyone running afe blade runner
  46. gauge pod
  47. Top speed governor
  48. dpf delete advice
  49. Rev Limiter
  50. Question for someone with a Co-Pilot
  51. Bolt on Twins
  52. Low fuel rail pressure codes
  53. Quadzilla Boost Fooler
  54. Need Help
  55. Well, I was too late
  56. RIP OFF
  57. Wcc Intake Horn and Dual Cp3 kit
  58. thinkin about trading my 08 for 11
  59. help?
  60. 68RFE mods for strength
  61. silver 66 or simular prices
  62. Now what on a programmer
  63. Which head studs???
  64. turbo,nozzles,copilot, ect installed
  65. h&s is awesome!
  66. she went pop
  67. who all is running twins
  68. smoke switch negative effects
  69. g-56 Spec clutch stage 3+ with billet flywheel, $1000, installed May 10
  70. High capacity fuel tanks
  71. 4 inch or 5 inch
  72. Deleted
  73. Good ideas for torque converter upgrade on 2010 6.7
  74. Headstuds
  75. Silver Bullet Turbo
  76. New tuner/New truck 2008
  77. cold weather delete troubles
  78. 2011 Smarty
  79. Taking out the muffler
  80. Intake
  81. Smoke Switch
  82. egr delete question 07.5 6.7
  83. 2011 Dodge 2500
  84. I need a few recommendations
  85. What happens if I put a tuner on and dont change the stock exhaust?
  86. MAP Sensor
  87. rims and tires
  88. 6.7 w/dpf delete randomly smoking
  89. turbo swap
  90. Which 6.7 Bombs?????
  91. 6.7 w/dpf delete randomly smoking
  92. Turbosmart Boost Controller??
  93. Which air filter
  94. clutch
  95. Transmission or torque converter problem?
  96. transmissons
  97. injectors
  98. S&B intake?? hood switch
  99. Exhaust tips
  100. New intake elbow/now codes
  101. cross over heat sheild for my stacks
  102. best settings for best mpgs
  103. anyone having mp8 troubles?
  104. 2008 6.7L DPF delete
  105. 2007.5 3500 Low Fuel Mileage?
  106. Turbo upgrade
  107. Injectors
  108. intercooler question
  109. smoke
  110. cold air intake
  111. Yanked my Muffler off
  112. looking for winch bumper
  113. 5.9 and 6.7 Ehaust manifold side by side
  114. 6.7 cummins starts, sputters, dies
  115. 800ft/lbs cummins
  116. heres my new 5 valve head
  117. heres my new 5 valve head
  118. set of twins HX40 HT3B
  119. crank case filter delete
  120. Cold air intake
  121. changing injectors help
  122. 2004.5-07 exhaust
  123. prototype head gasket installed
  124. 2 stroke oil
  125. suggestions for 12 sec. 1/4
  126. A new piece of hardware for your diesel
  127. 6.7 strait pipe
  128. safe smarty levels
  129. The More advice the better.
  130. Torque Gain
  131. A good bang for your buck?
  132. different noise
  133. You can swap an 07.5 up body front end to a 05 down
  134. Turbo
  135. FS 2500 bypass oil filter
  136. XRT Pro Q&A
  137. solving the head gasket problems with the 6.7
  138. H&S overdrive
  139. Nozzles
  140. Smoke?
  141. Can you delete the exhaust brake and swap turbo?
  142. Intake?
  143. Smarty Trace
  144. Looking to Lower
  145. just a little more...
  146. Multiple fuel tanks
  147. Aftermarket elbow
  148. boost tube
  149. best cold air intake?
  150. Road armor front bumper
  151. studs
  152. Diesel Greenhorn
  153. tuners? which one for my truck
  154. engine install problems need help
  155. how do you install a smoke switch on a 6.7 cummins
  156. H&S Blackmaxx question
  157. Smarty Jr
  158. H&S XRT
  159. Diesel Mod Shop - Manhattan, KS
  160. Bigger Injectors, What Other Mods Do I Need ??
  161. Advise on new Torque Converter
  162. Funny noise?
  163. dpf egr deletes
  164. Any dually's out there?
  165. New Intake Horn
  166. '08 Deleted last night!
  167. Mini Maxx Question
  168. smarty problems
  169. Quick Question
  170. Edge Juice + DPF Delete?
  171. 2011 delete
  172. Smarty jr for dodge 6.7..... wont smoke!!!!!!!
  173. Stock Turbo and hp
  174. Need opinion on Airdog 150
  175. will they fit?
  176. 6.7 exhaust
  177. EGR cooler
  178. Airdog II
  179. dpf delete without tuner?
  180. What to do?
  181. Upgrading
  182. 2010 smoke switch
  183. Black Ops Diesel
  184. H&S
  185. Need some Stacking Advice.
  186. S & B dry or oiled filter?
  187. Dr. Performance
  188. Edge Insight
  189. CEL light with mini max
  190. DPF delete question
  191. Xrt question
  192. Need Help!
  193. xrt
  194. Cold air intake?
  195. Lazarsmith
  196. Installed mini max and 5"turbo back exh!!!
  197. FINNALY BOMBED
  198. Injectors
  199. Tip question.
  200. Cheapest Flo Pro
  201. smoke
  202. H&S XRT with "0" is no longer useable?
  203. xx-fuel, airdog, fass
  204. Programmers
  205. Mods with automatic Tranny?
  206. MINI MAXX LESS THAN $950? Anyone cheaper? Taking bids!
  207. Biggest Tires with Stock ride height?
  208. any advise
  209. finally bobmbing need advice
  210. 09 6.7 tuner info
  211. DPF delete and the check engine lights comes on
  212. DPF delete kit help
  213. 6.7 tranny
  214. exhaust
  215. Head Gasket leak - I'm going to BOMB it.
  216. 08 6.7 egr/ chip questions
  217. cummins 6.7
  218. boost gauge install
  219. Programming smarty while edge is on?
  220. Straight Pipe-Power and Fuel Economy Gain?
  221. 6.7 Build
  222. H&S Performance Intake Elbow Install
  223. Maxx Flow Intake
  224. Quadzilla Adrenaline
  225. H&S tuner
  226. butterfly valve
  227. Need some advice
  228. coolant
  229. Arson Jr. II
  230. Is a EGR delete necessary?
  231. Throttle Valve delete
  232. need advice
  233. What can the dealer see about tuners
  234. Question about Quadzilla Boost Foolers?
  235. Where to go??
  236. 6.7 Edge/Smarty Stack
  237. whats a safe egt for the 6.7
  238. fuel mileage
  239. 6 speed manual noise
  240. 2009 Just deleted
  241. DPF delete?
  242. DPF & EGR Stealth Removal Theory Questions
  243. s67 smarty
  244. 4-09 build date and programmer
  245. Guages
  246. tranny oil?
  247. in need of a used DPF
  248. Bluetec Exhaust after delete
  249. Excessive smoke
  250. DPF deleted but have some questions.
