- wiring schematic
- KOJO tune
- Mind of it's own
- Newbie to turbo diesel and needs help.
- 1994 6.5 Turbo repair/upgrades?
- 2002 C3500 HD 6.5 noise.
- Easy performance upgrades
- 97 6.5 losing boost under throttle
- FAN CLUTCH ON 6.5L
- Just scored a Banks 6.2 Turbo What else to Pull
- 1995 6.5 turbo silencer
- Harmonic Balancer Help!!!
- performance
- Changing head gaskets with engine still in truck - any tips/how to info. Head studs??
- 6.5 studders at acceleration
- If you were getting your ECM programed would you send in yours from your truck or...
- Head studs and gasket
- Proformance injectors
- fuel problem?
- Tuning
- coolant leak
- #9 resistor
- Body lift?
- 6.5 diesel smoke
- wheel nut torque
- kojo tune question
- 1999 turbo D
- Consider, Buy, Or Run like Hell?
- Heath review
- Experienced 6.5L mechanic in Phoenix
- 2000 Chevy 6.5L Injection Pump
- Turbo choice and a possible Injection Pump upgrade
- 95 6.5 2500 vs 91.5 5.9 Cummins 250?
- breaking starter bolts
- Custom Crossover Pipe
- FUEL MPG'S.. I KNOW I KNOW I KNOW....
- Turboing a 6.2, have questions
- so i bought an hx35 and have a few questions
- Helping a buddy with his 1994 K2500 Suburban
- K-Loops 1994 chev 6.5 turbo probs
- 97 Chev with 6.5
- First time head gaskets
- DUAL THERMOSTATS UPGRADE?
- Best headgaskets
- #9 resistor
- Exhaust
- 6.5 turbo diesel exhaust down pipe upgrade
- ATS plenum
- 6.5 spec questions
- Lookin at a used 94 6.5TD
- combo gauges
- lp upgrade
- SSdiesel chip
- 6.5 hardly runs. idle goes up and down
- 6.5 looking for more jam !!
- Please read 6.2 smoking no power need help
- 6.2/6.5 TD project
- One is not like the other
- turbo
- 6.5 diesel power and mpg
- best ways to get better mgg?
- Advice on A1 Customs boost and fuel controls
- body lift on 6.5, can i put one on with no modification?
- Buy 94 6.5 w/130k or 99 w/160k?
- White smoke
- should i use a amp fuse on high idle mod for 95td
- New Exhaust
- 93 chevy 6.5turbo
- effect of fuel temperature on efficiency/performance
- 1998 2500 6.5 turbo
- 94 6.5l cross-over pipe
- High idle for a/c
- I.P timing
- 1993 HO waterpump W/O dual tstats
- performance module
- Bigger Injectors for 6.2l?
- More power torck
- Aftermarket Fuel Gage?
- 6.5 turbo upgrades
- cummins conversion
- tranny or comp. problem
- 5spd swap help?
- A few ?'s on performance...
- Any Way To Stop Defueling?
- Clutch help....1994 6.5 5sp Dual Mass? etc
- 6.5 tps help
- New Guy Injector Question
- Is there a kit or good way to replace fuel line?
- Share dyno results
- surging issue
- Diesel Rx 00050 Glow plug
- Is there much gain doing an electric fan mod?
- 1985 Chevy K30 CC build
- 98 Chevy 2500 6.5 Diesel
- 6.5L swap
- Ds4 to db2 questions
- Wiring help needed
- waste vegetable oil & kerosene problem
- Vapor line
- Need Help Bad,
- 6.2 k10 repair manual
- injector upgrade for a 6.2
- 1995 6.5L, looking to add some muscle
- Tail Light Issue
- Installing a Circulating Block Heater..?
- Chip or programmer for 99 duramax?
- hard start and rough running 6.5
- help with codes
- 6.5 head gasket
- 1996 silverado 2500 6.5 turbo, Where are glow plugs?
- exhaust setups
- EGR delete for 6.2 diesel
- Cummins swap??
- dmax lift pump
- injector rebuild questions
- Need some suggestions
- 6.5 VGT
- torque converter
- Trans conversion
- 6.5 vaccum diagram
- 4bt cummins
- Parts for a 6.2
- MIRRORS
- 6.5 injector pump
- K47 Air Box versus homemade air box
- water/methanol injection vs intercooler
- boost controler
- Q's about setting timing
- Bigger Tires
- Delete stock Fuel Housing
- 6.5 Turbo engine swap
- 4L80E Shift Enhancer
- obdi to obdii
- 6.5 exhaust brake?
- 6.5 heads
- Hotrod Magazine on Heath Diesel Build
- 6.2 Performance
- 6.2 school
- 6.5 stalling
- dual idler gear set
- 6.5 lifting head
- snorkle mod??
- intercooler??
- 6.5td five speed swap
- Dually Conversion
- Where to put gauges in 86 chevy
- 94 6.5 stalling
- 92 and 93 6.5 diesel owners
- KOJO Tune Review
- caddy conversion for 94 silverado
- Twin Turbo set up?
- PROBLEM!!!! NEED HELP
- damn old chevy beat a dodge
- TH400HD Inspection Cover and Support Rods
- question
- bring it ON!! ATT VS HX35
- Power Screw Adjustment
- 1992 chevy k1500 6.5ltd HELP!!!
- Turbo Replacement
- Gauges
- need turbo help immediatly
- 6.5 mods
- 6.2 pre chamber
- Smokes white on driver side
- 6.2 non turbo EGT probe?
- poorly running 6.5 turbo diesel
- H/O vs stock injectors
- 6.5 cutting out
- Allison Gearbox?
- lope?
- 700r4 questions
- 6.5 diesel chip tuner
- EGR delete question.
- turbo'n a 6.2
- 6.5 rebuild ideas
- EXHAUST POLL
- transfer case swap
- Riggin up a fuel mod
- Th350 behind 6.2
- Oil pump interchangeablility (is that a word?)
- hx 35 turbo
- injectors
- Arp Headstuds
- electronic injection to manual injection?
- looking for noise
- got a brush guard
- New Guy Looking for advise on current preoject
- Do I "need" a pyro?
- 6.5 Performance CHips
- Exhaust?
- 96 6.5 turbo diesel more performace any suggestions>?
- ARP Head Studs
- Real power for the 6.2 Your best ideas and advice
- 95 CHY turbo Diesel 6.5 Lift Kit Help
- Project No 3 93' 1/2 on 85' 6.2 4wd frame. Any advice, help?
- Time To Bomb The Tool Truck
- Boost?? Who What Where and How Much?
- LOCKERS LSD'S WHAT ARE YOUS RUNNING??
- 6.5 power
- body lift ?
- turbo swap
- 8 inch stack
- Aussy Supercharger
- Cam and Injectors for 6.5
- Disappearing coolant
- Parts Vehicle
- 6.2 Injector Pump
- 6.2/6.5L Performance Parts
- Project TURBO 6.2
- FASS 95 And An 82 6.2L Diesel
- NEED MOTOR For 95 K2500 P/U!
- BADGES
- 6.5 Turbo
- 14 Bolt Disk Brake Swap
