- Lope
- Idle
- First time cummins owner
- Boost not reading right??
- Smoke at idle got worse
- Not starting!!!!!
- Led headlights for 07 2500
- Exhaust question
- Tire size questions
- Auto trans fluid
- What next?
- Help, what the hell is this wire
- truck jolts from park to drive and reverse
- 47RE valve body into a 48RE.??
- Battery Drain after engine rebuild
- need some help please.
- 2wd/4wd motor mounts different???
- 2005 Cummins Valve body and harness??
- Low fuel pump voltage code P0628?????
- Wheel bearing replacement 03 2500
- Where to start...?
- Billet fly wheel or stock?
- Engine rebuild question
- Injectors
- Center dump manifold?
- 4wd Driveshaft U Joints
- Suspension
- 7.3 to a 5.9 new to the site.
- 5.9 fresh rebuild...ticking at 1500 rpm
- Loud Idle but quites down at 1300RPM
- 2003-2006 motor parts interchangeability
- Cranks won't stary
- 03 47re trans trouble question.
- HELP!!! 2005 turbo oil drain
- AUTO TO MANUAL TRANS SWAP
- no heat
- Upgrade Advice
- NEED HELP ASAP! wiring an APPS
- No Torque Converter Lockup
- FOR SALE: 2005 Dodge quad cab 4x4 - must see!!!
- 03 1 ton dually 6 speed from hell
- Hard start
- Steering setup
- Fuel Leak above tank
- No throttle response after ECM swap!???
- New 5.9 install what is going on!!!! Please help
- Installed new motor having issues......
- Stumble of idle....
- BD or ATS transmission
- Just got my first cummins, need info.
- Not building boost until 2500-3000 RPM
- What oil are you running ?
- Cummins compatability question! Please help
- GET OUT OF HERE SMOKE!!!
- Vibration felt in the cab but no rough idle
- Rough idle
- 03 dodge cummins 6 speed rpm spikes
- New 2 me 03 5.9 with a couple issues need help!
- 03 Gauges going nuts
- Catalytic Converter Years???
- Damn inspections...
- A/c line freezing?
- 2006 cummins ecm cleaning help
- fuel filter- change how often?
- Bully dog triple pup out..smarty 06 in????
- Upper front ball joint
- trashed injector?
- New to diesels, I'm thinking Cummins
- newb, slight loss of power, black smoke
- High And Random EGTs
- Bleeding Air From PS Pump on 2004
- Cheap Mods
- horsepower
- Efi live
- Watching Gauges
- Hard or no start mornigs
- 04, 5.9 Stall and surge problem
- Shift Problem
- 2003 5.9 3500
- New 03
- 2004 Gear Housing Gasket
- 5.9 shutting down
- 2005 CUMMINS H.O. LOCK UP PROBLEMS
- A/c suction and return line install difficulty
- transmission
- 2006 3500 5.9 Performance Parts
- how to run piping for DD
- hood stack piping help
- 2003 5.9 tuning with smarty tssr
- 5.9 Turbo oil return line
- Transmission randomly overheated today... Now running hot.
- Rear diff/pinion squealing loud under acceleration...?
- Help! Help! 48RE making squealing noise, then overheated!
- p1223 with wait to start
- What to look forward to, as well what not to look forward to.
- squealing noise
- TROUBLE CODE P1755 ?
- Steering problems
- 2004.5 stalling out while driving
- A/C blows warm
- Fuel Problems
- Dually tire questions
- G56 fluid change
- Deciding on what year to buy
- bringing cummins out of storage.
- problem with new reman cp3
- Help New Rebuild Not Cranking
- Whining noise help..
- BBI for the masses
- transmission hose leak
- turbo swap
- Miss, white smoke, already replaced injector ... Need help
- Blow by problem
- Replaced injectors crank no start diesel coming out of exaust pipe
- greasing balljoints
- pulling to the right constantly
- Bad MPG, injector light keeps coming on.
- 2005 5.9
- hard miss an loud poping in neutral 2500 rpm
- Extremely Hard to Shift Lever from Park to a Drive Gear
- New to me '07 5.9
- d tech cp3
- 05's?
- No start no click sos
- weird transmission issue
- cannot find injectors
- Future add ons help!!!!
- 2004.5 cummins rough idle
- need help asap rouph idle
- Need 2005 6 Speed Floor console
- 5.9 High Egts
- Jacobs brake
- Need replacement 24 valve CR block
- AMP power step?
- Wheel studs
- 06 24v cummins oil level rising fast.
- p1223 and p0148 codes
- 05 alternator problem
- Help!?
- exhaust
- abnormal revving
- Help
- 2006 cummins injectors
- No Start/cold start issues 2004 5.9 HPCR
- cold start problem
- front problems balljoint
- no start
- INJECTOR ISSUES?
- is this a good deal?
- Edge CTS Monitor
- 06 5.9 Overheating & High Idle
- truck cranks hard, will not start
- No power to cluster, interior lights,door locks
- Looking to buy my first diesel
- 2006 3500 won't run properly, then dies
- 04 single cab 4x4 169k on it auto whats it worth?
- how to know if rail fuel pressure sensor is bad
- 2006 white smoke.
- 2004 motor swap to 2004.5 truck.
- MAF AND IAT SENSOR LOCATION
- Tranny
- Bad gas mileage no other problems
- 05 dodge diesel 5.9
- edge juice problems
- 04 idle
- Multiple Issues - HELP!
- 06 3500 dead pedals under harsh acceleration
- transmission tips
- Mod/Preventative Maintenance
- Transmission help needed
- Real Borge Warner
- Rear Main Seal
- need some insight
- rolling coal questions i have a smarty
- Transmission ?s
- looking at buying a cummins
- vibration in 4wheel drive.
- Another P0148 questions...looking for ideas
- New to the diesel world.
- Is my truck dying? Please help
- Need help... P0088 /P0251
- oil Filter threads
- 2003 Cummins 3/4 ton
- T-Case linkage replacement
- Transfer case linkage
- 03 3500 SHIFTER WILL NOT MOVE FROM PARK
- Really need help have p0088 and p0251 codes need advice
- Bad Flex Plate or Torque Convert? Rough Idle and Tinny Sounds
- Fuel leak can't find it
- chirp and sometimes squeal, surp belt??
- head swap
- Brown
- marvel mystery oil
- 2005 5.9 with 143,000 miles causing SO MUCH TROUBLE
- straight piping my diesel
- 06 Cummins fuel problems...
- Where to have 2004 Cummins ECM Programmed?
- Drag link
- 6.7 head on a 05 5.9 block?
- belt squealing
- Led headlights
- fass or airdog
- Wiper
- 05 Cummins Fuel in oil and revv problems????
- 2006 dodge 3500
- Np271 how do you take this thing apart!?
- Update on: Rough Idle, but not when off idle
- may be buying a 03
- How can I get edge juice with attitude out of 2008 cummins too workin my 2004
- Edge juice problems
- Injector
- Cummins fuel economy
- FASS Titanium
- Boost Pressure
- 2004 5.9 No start
- Stock clutch replacement
- 03 04 05 ram 3500 2wd leveling kit install
- Edge w. Attitude EGT Probe Sleeve replacement
- Crossover Tube O-Ring
- 03 3500 automatic tranny options?
- newbe looking for help, 03 dodge no start
- 2003 RAM 2500 TD HO water pump types
- Transmission cooler line pressure
- Fox shocks
- i need injectors for 07 5.9 cummins
- black friday sale?
- head gasket tech?
- Rough Idle, but not when off idle
- Diesel leak above transmission?
- New FCA, still misses
- Upgrades
- Hard Shifting NV5600 Help Needed
- Stacking
- what coolant is best?
- Stacking
- 2005 dodge
- block heater not working?
- High idle in cold weather
- Tc won't unlock sometimes
- TIPM problems
- Trimming for 37in tires
- Air intake
- Manual to Auto swap
- new here, sort of
- input on inputs
- Rough idle
- stummped by this
- 03 2500 Ram 5.9 code
- Injectors
- Removed insrument cluster - now won't start
