- Garrett GT37R
- Can't get my idle down
- wheels
- Injector prob. Need help
- Cracked block?
- garret turbo?
- Excessive fuel Consumption
- 727 trans question?
- Rotary pump
- 1990 p pump conversion upgrade questions
- need help front end vibration when i hit a bump
- hx40
- 1992 dodge w250 cab bushings
- a518 2nd to 3rd shift problem
- first gen cooling issues
- Let's see yall's Flatbed's!!!!!!
- egt too high?
- 92 5speed turbo housing?
- Rancho shock upgrade??
- blown headgasket
- what does it take to rebuild a tranfer case
- tranny coolant line
- hx35 oil return line gasket
- Aftermarket Taillights
- Any Ideas: Truck problems
- A Newbie Looking To Modify
- solve the transmission mystery
- 91 4x4 auto can't seem to fix overdrive!
- gauge cluster????
- Won't warm up?
- can I run a open thermostat
- i need a cummins mechanic. oh & sum 1 to go racing with
- Brake problem after lift/kingpins/steering/37's
- will these fit my truck
- AFC Spring missing
- Removin a powersteering pump
- Baldwin filter part numbers?
- smoke ??
- truck running hotter and oil pressure suddenly higher
- High Idle switch for 92 12 valve help please
- Diff in intercooled&non intercooled vepumps
- voltmeter surging
- Hx 40 hybrid or 7 blade wheel
- 1st gen frame
- options for new brakes...
- TPS Delete Problems!!!
- Reality versus Fantasy
- hx35 crossover pipe???
- vepump info needed
- tranny temp?
- New to site
- engine wiring
- New Injection Pump
- hx35 swap
- Need to find a good vepump to build
- after market wheels
- Fuel Screw
- 2nd gen inter cooler swap?
- Found a sorce for aftermarket fuel tank sending units. Cheap aswell.
- Headlight conversion
- Fuel Getting In AFC
- piston lift pump?
- adding a intercooler to my 90' cummins
- need crossover tube dimentions please
- is 40lbs boost to much for stock headgasket and studs?
- Diesel filter?
- how can i tell if my truck is lifted?
- ATF's
- full fuel screw bottomed
- What got done on your truck today?
- A-518 transmission questions and concerns
- Getting mod ideas
- Pulling the cab
- What does is this wire supposed to be connected to?
- Draw straw cherry
- Always wanted a cummins. Now I've got one.
- boosting issues
- Nv4500 swap and driveshafts
- corporate 14 bolt
- Twin turbos on a 1993 cummins
- 6 speed swap
- No Cruise
- AFC Banjo Bolt
- What would I need to swap?
- 1991.5 First Gen Cummins
- ID this part please!
- truck meet (cummins mainly)
- 1st gen died and won't start back
- Get Rag still grinds!!! ahhhh!! help!
- performance upgrades
- Turbo Sizing Question
- Keeps Jumping in and out of overdrive
- broke speedo???
- Turbo Upgrade question
- Stock tach problem
- drive pressure
- Dash lights
- weird issue....
- any dana 71 locker options?
- denny t?
- Tips on buying a used 93' 5.9L engine
- Fuel shut off solenoid shorted to ground..
- A Different Idea
- 518 problem has me baffled
- My ball joint is bad now what?
- common problems
- hello
- 06 turbo on 93?
- Body Swap
- Throttle rod end.
- 89 ve pump help
- first mod advice
- Dyno March 25th
- Need VE Pump Top/Parts
- Denny T AFC Delete Top
- Some questions, Fuel lift pump/vacuum/timing
- Procharger build
- 89 Bosch VE Service Manual
- 2nd gen power steering pump on a 1st gen?
- New here and looking for some advice
- What kinda power? What to look for?
- parking brake cable collar
- non intercooled vacumm pump seal kit
- How big of gains can I see with a different I/C?
- dash cluster rebuild
- 91 cummins 12v info
- Installing injectors
- HC1 Upgrades???
- Will it hold up?
- Powerstroke intercooler
- New Truck, New Problems.
- 1993 W250
- Paint
- dyno problems
- How do I get rid of the smoke?
- needing info
- Body lift!!
- TPS specs
- EGTS too low
- 1991 cummins 2wd dually auto.
- charging problem
- 91 2 wheel drive long wheelbase for sale
- Broken turbo, H1C
- Show Me Your Exhaust!!!
- heatercore removal problems
- Confusion with rear driveshaft center bearing
- Pic of where the injection lines go?
- ve pump banjo fix?
- 1st gen tps
- POT in place of TPS
- well known truck forsale!!
- NV4500 Conversion
- 500 ft-lbs from pump tuning?
- 91 Intercooled wont charge!
- Low Voltage
- tach instal kits
- need a performance lift pump
- Timing Spacer
- positive battery cable and end needed.
- Hello
- custom decals
- Starting issues
- thinking i need a heater core....
- Factory lift pump
- Injection Pump Issues Again...
- steering shaft
- steering issues.
- steering box
- steering box
- Heater fan doesn't work, on heat but it does on others.
- Auto to NV4500 Conversion
- Looking for performance mods advice
- Replacing headgasket
- Help Identify Injectors
- Emissions Failure 2
- Help with anyone looking for banjo bolts
- 89 VE pump Rebuild Help
- had a wreck need parts
- Factory Grill
- putting exhaust brake on
- 93 terrible brake pedal
- Cross Oversteering?
- Full power screw won't turn in
- Truck may be up for adoption
- overdrive
- 4K Gov spring?
- Egt's
- Should I buy this truck??
- Part Priority Help!!
- KBB Says
- pyro install
- New injectors
- Timing spacer
- O.D. whining
- 1st gen. 12v to chevy swap
- anoyone know if this visor will fit?
- will these lugs work?
- transmission parts
- full power screw?
- will reg cab doors fit onto a ext cab body.
- 1991 CUMMINS W250 LIFT????
- 4wd conversion
- 93 First Gen mods??
- What do you guys think about this?
- Fuel Gauge
- Denny T Pin
- Fuel Pin problems
- Eaton Fuller 10 Speed?
- New to this 1st gen's, need some help.
- drum brakes to disc brakes?
- Roll Pans
- not your usual OD question
- controling over drive and lockup
- 1st gen with 303k should i buy it?
- H1c compressor outlet
- 1992 d350 powerhouse!
- LAST DAY
- Cracked window
- Falls on it's face in 2nd gear?
- Silencer Ring
- PUSH ROD COVER GASKET
- DIY Upgrades?
- Governor Spring swap problems
- What you got for shifters guys?
- volt gauge and lights
- Leveling kit
- my first post i want 350hp
- he351 vs hx35
- slipped timing???
- 12 Valve lope..?
- kdp advice
- Runs away for what reason???
- where to find a getrag 360 speedo wire
- 95 dana 70 into a first gen
- nv5600 install
- cruis control wiring?
- trans temp port
- S300
- No start
- Opinions on Twins
- Newbie gear question...
- running out of options
- Value of an HT3B???
- ve to p-pump conversion
- Powersteering pump...
- Electronic add-ons
- Injectors
- Air Bags
- 1991 I/C 5.9L Head gasket failure?
- 1989 6bt piston ring gap???
