View Full Version : 5.9 Liter CR Dodge Cummins 03-07
Pages : 1 2 3 4 5 6 7 8 [9] 10
  1. Driveshaft Question
  2. ? on plugging in
  3. Aftermarket Gauge Questions
  4. do i have to worry about the airbag?
  5. oil pressure?
  6. 03 hard start only when it is cold
  7. Smarty Junior now with Power on Demand
  8. OBDII codes
  9. stock vs. aftermarket lift pump
  10. quadzilla xillirater II
  11. new guy needs help
  12. "Door's Open" horn warning
  13. 04 1/2 boost/ turbo question
  14. Blow-by
  15. New smarty Jr
  16. truck died
  17. Slip Yoke
  18. lowest mileage 04 in the country!
  19. High EGT Range
  20. twin trubo ?s
  21. 2006 fuel pressure and gauge
  22. Smarty jr
  23. dialbosport predator
  24. 2004.5 - 2007 cummins
  25. Question on fuel pressure
  26. Road walk
  27. DOH!
  28. 30000km with no second gear
  29. Quadzilla commander update....HELP!
  30. Power guesses?
  31. P0524,0148,2123,2121??
  32. Will these lights really go in the factory location?
  33. Stuck in second at full throttle
  34. Stacking Quadzilla Xzillarider 2 w/ Rokk
  35. code problem
  36. Cold Starts
  37. EDGE JUICE WITH ATT.
  38. Noisy 4 wheel drive
  39. 06 dodge front end help
  40. BullyDog PPE STACK
  41. EFIlive for cummins !
  42. Install Thermocoupler or not???
  43. axle wrap
  44. Key cycling question
  45. obd2 codes/problems
  46. 07' 5.9l stock injectors layin around?
  47. 03 5.9/ 100% stock drivetrain. what to do first?
  48. Manual shifting question
  49. Intake options?
  50. Bigger injectors
  51. Twin Turbos
  52. Diagnostic Codes
  53. 03/04 Intercooler vs 05/08 Intercooler
  54. Bullydog Torque Management
  55. Any head porting out there?
  56. ISB guy looking into a CR
  57. Injector Failure
  58. fuse question
  59. P-O483 CODE ANYONE ELSE HAVE THIS HAPPEN
  60. tranny
  61. Code P0573... Is it something to worry about?
  62. 2004.5 CTD No power and code P0148
  63. Power Puck, Boost Fooler??
  64. Pyrometer install
  65. CHECK YOUR COOLANT
  66. Intake Question
  67. fuse #35
  68. relay box
  69. NEW MOTOR OBTAINED! (PIX)
  70. a few questions
  71. HELP
  72. difference in CR injectors
  73. Texas laws exhaust
  74. 6.7 injection pump
  75. whats the best synthetic motor oil
  76. methanol injection install.
  77. T/C and valve body???
  78. bad mileage and slight smoke all the time
  79. Need Pics
  80. Personal Fuel Economy with EZ
  81. Help Plz!!!
  82. Any difference in the 06/07 motors or tranny on the 5.9L
  83. Which fuel filter to buy?
  84. Best place to read fuel pressure?
  85. wanted steel head ache rack
  86. Oil report for Amsoil 5w30 HDD
  87. Trans Decision Help
  88. Check Engine Light came on
  89. F-1 24v Sportsman Springs
  90. S&B?
  91. what is this.??
  92. good injectors for 06 megacab
  93. Oil pre filters?
  94. Need help with bumper
  95. Tranny fluid change question ?
  96. Double Deep Tranny pan
  97. Confused and Need an Expert - Exhaust Question
  98. Should I Be Worried?
  99. What Should I Look For In A Truck?
  100. Smarty Vs. Stock Clutch
  101. Banks 6 Gun DEAD
  102. Where Did You Mount Your Brake Controller
  103. Factory Brake Controller Hook Up
  104. Looking For An Axle
  105. Check Engine Light Keeps Coming On
  106. Looking To Buy An 04 CR
  107. Make More Smoke?
  108. Thinking I Need To Send My Cylinder Head In
  109. Automatic To Manual?
  110. 12 To 24 Valve
  111. Idle Stalling
  112. Bumper Or Bully Dog Programmer?
  113. Quick Question
  114. Rough Idle
  115. Rail Pressure Relief
  116. Boost Leaks ?
  117. What Exactly Does This Do??????
  118. Missing Problems
  119. The Never Ending Code
  120. CODE QUESTION
  121. Exhaust Manifold Port Temps
  122. Waitin' On Gustav
  123. Quadzilla Max Mileage
  124. Boost Codes
  125. 3rd Gen 1/2 Ton Frame Vs 3/4 Difference? Helper Air Bag Question
  126. Popping Through Exhaust Running 1400-1800 RPM
  127. Fuel Filter Question
  128. Battery Question
  129. P2609 Issue, Any Ideas Why? 2006
  130. Any Suggestions
  131. Driveshaft Question.....
  132. Common Rail Help.....
  133. Cleaning Head
  134. Free Wrecked Dodge/Cummins
  135. Losing Coolant
  136. 2006 Dodge Ram 3500 - 766HP Sleeper
  137. Lift Pump??
  138. Stacks
  139. Banks Six Gun
  140. Tranny Conversion
  141. Tuner
  142. Fuel Pressure
  143. DTC P2121 And P2127
  144. New Trans. Rebuilt
  145. Halo Headlights ?
  146. Stock HORSEPOWER Specification For The 2004.5 / 5.9L HO Cummins
  147. APPS Adjustment 3rd Gen
  148. What Would Be A Good Exhaust For My Truck?
  149. White Smoke From The Exhaust?
  150. Holley Black Or Carter
  151. Oil analysis Q's
  152. Level10 Transmissions
  153. #1 Injector Line Felt Something Like A Tapping????
  154. Death Of R Front Steer Tire By Bottle In Road!!
  155. 3rd Gen Wheels
  156. Cluster Error Codes
  157. Lap Top Programs?
  158. Map
  159. Overhead Console
  160. IAT, MAT Or Whatever the Sensor Is Called
  161. can't seem to find it
  162. Aftermarket Knowledge
  163. DIY
  164. Fass 150/150 kit question?
  165. What Is This???
  166. Fuel
  167. School Me On 3rd Gens
  168. 2 Cycle Oil In Fuel?
  169. P0069 & P0073?
  170. Resealed CP3
  171. Cupholder?
  172. P0111
  173. 05 2500 Problem
  174. Freak'n Truck!!!
  175. A/C Question
  176. Shocks
  177. Idle Problem
  178. exhaust brake
  179. stock lift pump
  180. Brakes
  181. Blackstone report
  182. Valve Bridges
  183. Key Counts
  184. Lowrider
  185. The More I Tow.....
  186. Clutch Popping noise
  187. What yall think about biodiesel?
  188. I'm Breaking Things Again.... G56 Bites The Dust.
  189. CP3 And The FCA........
  190. Code Won't Go Away
  191. Mileage Flash From The Dealer
  192. Going To Track, Would Like Advice...
  193. HELP!!!
  194. High Beams/ Washer Fluid
  195. Anyone Know?
  196. Normal Cold Start??
  197. 5" Straight Pipe 3rd Gen
  198. Seeking MPG W/ Gear Vendor Overdrive...
  199. Brake Question?
  200. New Engine Go BANG BANG RATTLE RATTLE
  201. Code ?
  202. Changing Trans Fluid?
  203. P2509
  204. Xzillaraider 2 XZT (60hp) And Rokk Timing Sensor
  205. PacBrake Issues
  206. 48RE Bands ?
  207. Pop Testing Injectors
  208. Confused-Performance Question
  209. Worth It Or Not?
  210. G56 Spring Center
  211. Dodge Transmission
  212. Optimum Rail Pressure
  213. Stock 4wd Parts 03 2500
  214. In Need Of A Motor Bad
  215. 5 Speed?
  216. How Big Should I Go
  217. Rear & Front Axle Capacity
  218. 2nd Oil Analysis Results....
  219. Begging For Answers!
  220. Impossibly Hard To Shift NV5600, Other Times Shifts Fine
  221. Cool Email
  222. CP3 Is Leaking
  223. Rear Axle Seal
  224. Wierd Problem-Maybe
  225. Yet Another And Hopefully My Last Clutch Question
  226. 3500 Rear Spring Pack
  227. ATS Gauge Install
  228. Smarty Software
  229. Can't Powerbrake Anymore?
  230. G56 Cooler
  231. Codes, Help Please.
  232. Tow/Haul Button
  233. Disconnecting Lockup By Brake Pedal?
  234. Who Here Has Actually Broken A 48re Input?
  235. Need Advice!!!
  236. Van Aaken Performance Module?
  237. Fuel Additives And Miles Per Gallon - Newbee
  238. Leaking CP3, 2 Injectors Going And Turbo # 2
  239. '03 New To Me
  240. Smarty Question
  241. Door Locks
  242. TC Lockup Switch
  243. 2 Trouble Codes, Need Some Help Before I Go To The Stealership
  244. Looking For A Trans 48RE
  245. Factory CAT Questions
  246. Smarty Help
  247. Ball Joints For An 04?
  248. What Could Have Happened To My Stock Turbo? It's New!!
  249. Injectors
  250. Clutch Help
