- Please HELP!!! POO93 code
- Power Mirrors Not Working
- replace fog light assembly 01 2500HD
- Balance rate question
- Which Tranny Upgrade
- Injector help
- ABS and E brake lights
- Need some info for Dyno app on phone.
- new injectors smooth 3 mi. then rough???
- 03 allison overheating
- Single Stack
- Duramax injector changing more questions
- fass makes p0089
- Difficulty of Water pump swap?
- dimmer switch wire
- hard starting @ about 10 above and lower
- 01 duramax 190k problems
- Transgo Shift KIT-500HP???
- Mechanic Needed
- stock turbo needs to go!!!!!
- some times hard to start
- Sending unit help!!!
- white smoke at start up
- Stock duramax injector size?
- Coolant leak????
- some info from the dmax guys please!
- Dead truck
- frame and body rust...
- lb7 acting goofy, please help
- LB7 injectors-Cups
- 03 Duramax
- Front axle leaking k3500
- Question on Injectors and Mods.
- 2002 Duramax White smoke Help!!
- 03 lb7 no 4x4!!
- 03 duramax check engine light emission control
- balance rate?
- horn issue
- clean oil
- loss of throttle
- Edge or Quadzilla???
- change oil message?
- Fuel in the oil
- suction sound when turbo builds boost
- Limp mode is scary!!!....I think
- edge & PPE
- OBO reader
- efi live
- 02 Converter lock up
- Need help.
- 03 Duramax Injector Replacement
- no more open diffs
- Thumping in front end
- Broken rockerarm
- Ticking 04
- 04 duramax lb7
- 01 Transfer Case Model???
- Problems with Steering wheel Controls
- exhaust poping through air intake
- six gun
- Sierra 2500 HD rear axle bearing/seal help!
- exhaust brake for LB7- worth it?
- 2003 lb7 white smoke
- 04 duramax with power surg
- Help me with this Duramax belt please. I have a video!
- Injectors maybe???
- ECM plug not working.
- Fuel in oil question
- torque spec question
- raynjoseph
- just curious
- wheels
- performance upgrades advice
- exhaust
- programmers
- new dtcs need some help
- Service 4WD light
- lb7 smoke switch?
- California Emission code P0380
- P0093 code
- '02 Making some rattle noise under load ONLY!!
- Ordering Parts
- 2005 Duramax Code
- Location of TCM 01 silverado
- engine code p1781
- EGR Valve Delete?????
- the search is on!!!!!
- lb7 not shifting?
- Performance Enhancers
- Stealership says truck needs all new injectors.
- Hi
- LB7 truck died
- service 4 wheel drive light
- Help with injector replacement
- Torque Specs Head Bolts on LB7
- '01 California Glow Plugs
- Front Fender Liner Push-Lock Fasteners
- Multiple Problems - any thoughts?
- Any Sugg. Low Coolant Problem
- Not Bad for Trans Fluid Change
- 02 truck for sale
- Need pointed to some info on putting lbz pump on lb7
- truck is runnin bad and dtc are coming up
- Smoking and skipping
- better mpgs
- lb7
- BD auxillary fuel filter..
- 18 rbp wheels for sale
- CP3 Question Please explain
- FPRV shimmed on LB7
- Lb7 injector longevity?
- Bad smoking on vacation, need advice
- cheap mods
- I need specific answers on 0093 code.
- Tools for replacing steering components
- what next?
- Lift Pump
- Another Californa guy looking for a cat
- HELP! Was idling then just quit!!
- 4X4 ATC problem
- Security light
- injectors
- Change Front Hub
- P2227 and P1404 Code help
- Passenger window stuck.
- computer issues?
- LB7 Electrical problem
- change seats??
- Duramax S366 turbo help
- 02 duramax P1621
- LB7 Help? Injector Cup
- adding brake fluid to oil
- 01 GMC Duramax LB7 LOSS of Prime
- balance rates
- 02 LB7 falls on its face
- 2002 front axle seal
- Fuel Line Plumbing
- truck wont start
- chevy duramax 6.6 engine codes
- LB7 Overheating, Codes
- stock injectors
- P0089 Fuel Pressure Regulator Performance
- adding cruse to a 01 ???
- lb7 head stud torque???
- lb7 injectors
- 02 durmax coolent leaking
- need a CP3 pump
- Another 01 Question
- 2002 Duramax quit
- 2002 6.6 liter qiut running??
- 01 Question
- LB7 injectors?
- CP3 pump
- allison transmissions
- snow plow package?
- need your guys helpp!
- Bullydog products?
- LB7 Head Gaskets
- P0088 code?
- LB7 Head Gaskets
- additional fuel filter
- injector removal
- picture please?
- cp3?
- Tranny code question
- Fuel pump relay and fuel demand LB7
- gruge race
- Injector help please
- diesel in the ER
- Terrible surge at hard throttle
- No power in the top end
- lb7 tuned
- limped then wouldnt move..
- Knocking louder then normal really bad when I get on it?
- Bilstein Shocks
- Water leak
- lb7 surging at idle
- 0090 code help please, loping and clacking
- 2004 duramax?
- Looking at a Duramax
- 02 6.6 help
- LB7 Transmission Advice
- Oil Pressure Sensor
- changed injectors now i have a PO236 code?
- help poo93 on a pull
- Throttling up issues
- Glow Plugs
- Temp gauge going crazy
- Tranny Leak
- SERVICE BRAKE SYSTEM LIGHT???
- surge!
- engine shake
- removing valve cover???
- torque spec. for LB7
- Coolant in air filter
- Vibration under hard accel.
- Injector?? I am conf!
- I'm BAACK - 03 Chevy DMax this time!
- Black smoke
- 2003 Duramax will not start engine is hot without prime.
- injector warranty
- Fuel System Diagnosis - High Pressure Side
- repost - sounds like a Huey
- dvrjak
- Fan & Clutch Cross reference years/engines?
- help please
- Is a steering damper kit a good thing??
- Winter Diesel vs Summer Diesel
- 02 duramax help
- how much power loss????
- My drunk buddy and his window
- LB7 Fuel Pressure drops after 15K
- Low MPG
- what is the 2 stroke oil for in a diesel?
- Help on troubleshooting the pump or regulator
- Injector regulator on a LB7
- Help! Im sellin my ford 6.0 for a 2001 duramax is it worth it?
- How to tell if injectors are going out?
- trouble starting/ long cranks
- Rear axle seal replacement
- Torque spec for fuel injection lines
- Repair Manual
- HELP: LB7 Mysterious Coolant Leak
- Rear axle hub problems...
- RPM limits
- LB7 Tranny Swap
- My buddy truck goes clunk or is it a clank?
- 2 stroke oil in fuel
- chevy and dodge bolt pattern
- limited slip?
- fuel gauge
- 03 3/4 w/6spd
- What makes an LB7 go BANG?
- LB7 question
- 4wd light
- Speedo Off
- turbo question
- Same old injector problem/questions
- electrical/injector problem
- 2002 dmax limited slip?
- 2003 Duramax Starting Problem
- won't start cause of cold
- Tie Rods..
- Questions about the lb7 duramax!!!!!!!
- no power
- Where to purchase replacement FICM?
- exhaust leak
- vibration
- Thinking bout buying a duramax
