- fuel issues....
- Possible injection pump trouble
- powerstroke rods and pistons?
- diode for 7.3
- Trans acting up
- More performance questions...
- Increase boost on a 92 f250 7.3 IDI
- Turbo and Intercooler
- 6.9 with a 7.3 IP?
- 84 6.9 idi power
- 7.3 IDI boggling problems?
- Third time's a charm??
- more turbo questions
- Need help
- What can I do?
- Cheap college student looking to make some performance upgrades
- drain back o-ring
- Looking at used turbos
- Ahhhhhh
- Holset on the cheap
- Moose and dps stuff.
- 7.3 IDI Turbo Question
- Bunch of questions for 7.3 idi
- set screw on pump
- 85 f250 6.9L glow plug wiring diagram
- Hard Shifting '88 5spd 7.3-Newbie needs help
- Put a factory turbo off a 95 idi on a 1990 7.3 n/a
- Dyno Videos
- remote mount junkyard turbo 86 idi
- Adding a turbo to my 92 7.3idi
- 1990 f250 7.3 idi zfs-542 cummins swap
- 1986 6.9 what to look for
- '94 IDI 7.3 Inj. pump ?
- Oil leak
- need some more hp for the old 7.3 idi!
- turbo idi airbox subsitute...
- 7.3 idi n/a to turbo charge help/pointers anyone?
- Timing spec's?
- digital odometer and sppedometer stopped working
- air intake setup with spectra filter
- 1994 f250 7.3l idi turbo
- performance output?
- New ip now loss of power
- Ip replacement help!
- new project
- 1993 ford 7.3 idi need help
- Can't hear the turbo?
- which turbo to get
- 4 Link build?
- no black smoke
- Air to air intercooler for my IDI
- Programmer? Can you program an IDI?
- 1989 7.3L IDI wiring issues
- 88 7.3 idi
- how to black smoke
- adding a turbo to my 94
- water meth plus nitrous on a n/a engine
- Add two small turbos to IDI
- tach questions????
- new to 6.9's
- 6.9l longtubes??
- 6.9l with ats turbo kit
- Custom Cam Grind
- Which is better?
- intercooler
- 94 F250 reg cab 4x4 7.3 turbo idi 5spd
- Egt timer
- timing
- injection pump question
- Istalling pyro in idi turbo
- idi Boost gauge
- Downpipe?
- 6.9 tach sender
- onboard trickle charger
- 93 7.3 idi exhaust question
- starting issues
- lift pump
- Intercooler piping problem
- buying truck this weekend help.
- question/idea
- Injector's
- f550 and idi 7.3
- engine issues
- advance fuel pump timing for more power
- glow plug issues
- head gaskets done but now massive oil leak
- what mufflers on a 7.3 idi
- performance
- Aftermarket Gauges
- Running warmer
- defueling?
- Electric fans install
- Intercooler for the 94 factory turbo
- bypass filter
- question
- factory turbo full out?
- Intercooler More Power?
- how to turn up the wastegate on my 94 7.3l idi
- can it be done?
- Transmissiom Interchange
- question????
- Pics?
- 99ford rims swaped to a 86 will it work
- injectors
- what mufflers?
- 94.5 factory turbo diesel non powerstroke
- thinking about doing a 4x4 conversion
- exhaust opinions
- 7.3 idi parallel turbo
- Extra Capacity Fuel Tank
- 4X4 conversion?
- idi performance
- Thrush Mufflers
- 6.9 fuel question
- need to roll some coal
- performance for 94 f250 idi turbo
- best programmer/ chip for black smoke (97 powerstroke)
- 6.9 usable parts to transfer from 7.3
- Turbo 7.3
- lift
- value of parts
- guages
- trans trouble. please tell me no
- new guy old truck 2
- 6.9 L EXHAUST SYSTEM
- electric fans
- help me !
- Transmission Upgrade
- transmission upgrade
- stock or aftermarket
- How strong is a 86' 6.9L with banks first gen turbo
- 86 ford f-250 with first gen banks turbo kit
- Need a used 7.3 setup for a 1990 extended cab w/ 5 speed manual trans.
- 85' Dually..need new tires..help
- 7.3 Dies When Pushed
- 94 FORD 7.3 IDI OIL COOLER END HEADERS
- Intake (just ram air)
- Looking for performance
- Aftermarket Turbo
- roll a little smoke
- cold air
- intake
- truck wont start
- need info
- Turbo Kits
- Low Oil Pressure and White Smoke, 6.9
- Wiring Diagram '86 f350
- this truck needs help...7.3 IDI
- Diesel Tach, What makes 'em tick?
- While Looking At The Front Of My Truck.....
- Can I Blow SMOKE?
