- 6.0 build or trade in for a 6.4
- 6.4 roll call
- spartan tuned tranny problem
- Used 6.4 from dealer with dpf delete...
- won't go into low range and rotational knoch in high range
- new grille needed
- 35x12.50x18 on factory rims
- 6.4 DPF Delete
- tuner question
- Xrt Pro or SCT Livewire
- Performance shop
- SCT Livewire EGR/DPF delete code problems
- 6.4edge evolution
- mileage
- 6.4?
- F-250 check air filter HELP!
- Picking a new truck
- need some expert advice
- looking for interest.
- AirDog lift pump bypass
- 6.4 problem HELP!!!!
- Cruise Control stopped working
- High pressure fuel pump
- cylinder locations
- What parts for upper/lower radiator hose replacement
- Can I use regular diesel on 2010 Ford F-250 Powerstroke?
- high pressure turbo isn't sure if it wants to work all the time
- 2009 6.4 f250 dpf?
- Look at 2008 F250 Carfax
- PMF Bars finally came in!!!
- HELP asap! should i buy 08 f250 or not?
- Power loss
- 6.4 oil pressure gauge
- 6.4 filters
- trans fluid
- 2008 F-250 Cross Country Trip with travel trailer
- boost pressure? where did it go?
- mp8
- HELP!!
- Is the Ford Dealer Avoiding Warranty? I Cant Believe This
- truck useing fuel like no other need help!!!
- Draining the water out of the fuel on the 6.4
- using coolant
- POWERSTROKE DOWN!
- battery light with codes
- 2008 6.4 sounds like a jet
- How many miles you have on your 6.4 PSD
- AM LOOKING INTO BUYING AN 08 6.4
- Test drove 09 6.4 with 50,000 miles
- NEED ADVICE on 2008 6.4L F350
- 08 has had cab off 6 times
- Steering wheel temp control not working
- Diagnostic Code p252f
- Looking into getting a 6.4
- Blacked out a few more things.
- Frustated Ford Diesel Owner
- looking at a 6.4
- some advice and knowledge please!
- finally got my new rims
- Everything works but truck wont crank
- Source for used DPF
- Front End Rubbing Noise
- What kind of mpgs you guys getting
- Need help with this annoying voice
- new truck delima
- BOUGHT THE fuel filters & oil filter DID i GET A DEAL
- New Tranny
- mpgs
- Exhaust manifold, header?? Differences
- TOW/HAUL MODE
- HELP!!!
- It's Gone!!!
- Pull Over Safely and Stop
- What brand/type of oil do run in your 6.4?
- Ticked Off @ Dealership
- Diesel Particulate Filter guide...
- 6.4 Oil Leaks
- 6.4l won't start
- 2008 F350 FX4 Just sold $7800
- Has Ford sent y'all something in the mail?
- Cab coming off, engine opened up,,,any suggestions
- Radiator woes,,,
- fuel millage
- Engine Block Heater
- Won't start
- Locking hubs ?
- gray smoke out of exhaust???
- 09 King Ranch Power Stoke 6.4L bucking
- sound system
- thinking about trading duramax for F450?
- check engine light
- No Power.. No Boost.. Loud Rattle.... Please help..
- Need some advice for buying my first DIESEL.
- dpf mileage
- '10 6.4l missing at idle
- Help Please..need an answer tonight!!!
- WTF
- Houston Tx
- Hows the reliability?
- Dad's looking at a 6.4 PSD
- WANTED - DPF/CAT DELETE PIPE 4" - used
- Climate Control
- wheel hop
- More smoke,less mpg
- At idle I feel vibrations on the steering wheel
- ford 6.7
- Intercooler?
- 5R110W and Idling for long periods
- New member with an issue. HELP!!!
- 2010 terrible mpg
- 2008 Ford F-450 motor
- 2008 6.4 Diesel Problems
- Just got back into A PSD....here it is
- dam,dam,dam
- low tire pressure light
- age old ?
- Whats this?
- What up guys/gals
- Friends problems
- reduced engine power & overheat
- 6.4 or 6.7 what to do?????
- Still bucking
- Get R'Done
- 6.4 Questions
- 6.4 powerstroke
- Who has ripped an I/C boot?
- Blue smoke when taking off from park.
- Dead 6.4 Help
- UNPLUG EGR???
- Who has a JOB 1 truck, early build 08 withOUT TPMS?
- regular diesel for the 6.4L powerstroke
- 6.4 inconsistancy
- I've decided on a 6.4 PSD. man/auto 3.55 or 3.73 OPINIONS!!
- Ratchet noise from 09 SD
- 6.4 Problems.
- 6.4's Future
- Gas station was closed, ran out of fuel?
- Any resources out there on 6.4 liter buy backs?
- 6.4 Diagnostic Trouble Codes
- Loss of power when towing/ engine brake probs
- '09 Tapping noise
- knocking noise
- 6.4 l low pressure lift pump
- WHY WOULD FORD DO THIS ?????
- Fuel line connectors
- 6.4l info + mpg
- Update on 2008 Ford F350
- Ford F350, 6.4
- Upcoming Purchase 6.0 vs 6.4!?
- 6.4 Owners - IN HERE - Injector Replacement Customer Satisfaction Program
- what size socket to change oil-filter on 6.4 ???
- power loss 6.4l powerstroke
- 6.4L powerstroke engine specs
- Update on 08 6.4 problems
- FORD manuel say 6.4 PSD oil change at 10,000 miles??
- 08 6.4 engine light on ...
- Info On Buy Backs
- 2008 Ford Recall 08C04
- 2008 Ford F250 Super Duty - A Contractor's Dream Truck
- 6.4 Fuel Economy
- Codes?
- 2008 Ford F350 - Wild Wide Boy
- Regen Functional Characteristics - TSB
- 2008 6.4L Ford Superduty Overview
- Track Day - Great Lakes Dragaway, T/T
- Love Your 6.4?
- 2008 Ford F250 - Build A Better Super Duty
- F-450
- New Edge Juice For 6.4L
- 6.4L Van???
- MPG
- Dual exhuast systems
- 6.4PSD Info Please
- Traded In The Old Dodge
- How Differant Is The 6.4 To The 6.0?
- Aftermarket Performance Goodies
- 150k Miles In 131 Days, 08 F450○
- 6.4 PSD Performance So Far
- New Stroker Forum
