- 93 high egts
- Will 98.5-02 vacuum/powersteering pump fit?
- My first...(1st gen)
- low pop pressure prevent startup
- 1989 Vacuum pump woes
- Chevy brake drums on 1st gen. Dodge?
- Need Help!
- Ve Fuel injector pump problems
- On my way to 12v swapping
- Stumbling
- Performance and fuel mileage need advice
- blower fan issues, need some help.
- 1990 1st gen cummins questions
- Injector Pump Settings/Black Smoke
- Lower Control Arm Bolts
- HE341 on my 1st gen?
- Speedometer problems
- Need Some Help Guys
- 1990 d250 rebuild kit
- keep it simple stupid
- 85 d350 (project blackie)
- Interior Parts
- 75w-140 f. Synthetic g. Oil question
- frig sakes need diff help
- AC & OD wiring help needed
- rear seat in '93 club cab
- 1991 Dodge w250 cummins turbo diesel
- Understanding the KSB
- What to do?
- 93 Cummins won't start!!!!
- weird knocking noise 1991.5 cummins
- Help! KDP pins too short to locate timing cover
- Fuel Mileage
- 2 wd to 4 wd swap?
- best 100hp injectors
- Very odd electrical problem on first gen
- Ve pump problems please help
- Smoke Screw
- 92 cummins not charging, no tach, or odometer
- Add a leaf???? Help
- d350 rear end swap help
- anyone use dcp diesel engine kits?
- Best floor mats for 1st gen
- first cummins, maintenance, and other questions
- Hx-35 & intercooler problems
- cummins build
- ran out of fuel and now wont start
- Led cab lights
- needed hub 1993 ram w 350 dually
- Won't crank
- 93 250 tranny question
- custom first gen grille
- 12 Valve Pulling Question
- Fuel leak help-- crossposted
- 1990 running hot need some help...
- looking to buy a 89-93 cummins
- gas to diesel conversion
- questions on external regulator for a cummins swap
- 1991 dodge w250 wont start
- 91' cummins horrible grinding noise and dies.
- 2 u joint steering shaft and steering box
- voltage regulator problems??? need help!
- Turbo/ EGT question
- 93 fan clutch bracket
- Radiator question
- lose.control of throttle and power.loss
- 93 d250 grid heater not working.
- 89 Cummings auto tranny
- first gen front spring mounts
- Pcm bypass/ ac
- Tuning VE pump with upgraded fuel pin
- Failure to boost/fuel climbing grade from dead stop.
- will second gen lift pump hold up
- Substructure Front End Swap
- Heater core replacement
- 93 CTD won't turn over..
- Skyjacker 4in lift
- popular upgrades in the mid 90's
- Turbo exhaust housing
- Clutch is going out, new or auto?
- He351cw turbo upgrade on 1st gen dodge
- Upgrading lug studs?
- Cummins conversion brakes
- low oil pressure
- just bought my first diesel. need help.
- Marine 370 pros and cons
- inner fenders
- need help with lift kit on my 89 D250
- Please help with od problem!
- wiring burn out from fuel shut off
- 91 replaced fuel pump, wont start...
- Industrial injection hx35/40 hybrid turbo
- headlights turn off while driving on 93 CTD Automatic
- Jim
- Hx35 or h1c upgrade????
- Application of VE pump
- New turbo
- How much horsepower?
- Overdrive
- Diesel fuel line quick disconnect
- Fuel issues
- Half rhino-lined truck
- Help!!! Clutch?? Slave Cylinder??
- Transmission Confusion
- Replacing turn signal switch trouble
- Transmission ID
- Don't know what to make of this
- need 92 wiring diagram
- no power
- NEED HELP PLEASE
- slow cranking and now no start
- Build up of clean 92 cummins
- Build of 1992 Cummins!
- 93 cummins low power...weird shifts
- need alternator pulley
- Odometer doesn't work?
- A518 weak from a stop
- loss of power, fueling issue?
- ENGINE WONT START !?!?
- 1st Gen wheels!!
- VE pump will NOT adjust!!!
- Power steering?
- 2wd SRW to DRW conversion ?'s
- Problems shifting into overdrive
- Injection Pump Gear Interchange
- Automatic to nv4500 conversion
- injector nozzles and pintle
- 93 1st gen cummins
- How wide of a rim can I run on my 89 w250
- 1st gen and 4l80e
- ve pump leak?
- 1989 12v
- 89 wiring diagram request
- throttle linkage
- heater core?
- I NEED TRANSMISSION HELP RIGHT NOW!!! NV4500 TRANSMISSION INSTALLATION
- 91.5 w250 3 questions
- removing the high idle screw
- getrage clutch opinion and brands
- 93 w250 VE or P pump stock?
- TC flex plate problem
- idle question
- idle with blue haze
- my truck goes to a idle at half throttle until I release the throttle
- 93 bolt on turbo upgrade
- Looking for 89 style core support
- Fuel leak at pump?
- Ideas since rebuilding
- Floor pan
- TPS Replaced
- Large Secondary Cable
- Transfer case over filled
- First Gen paths
- Transmission type
- 5th gear vibration.
- Transmission advice
- Lift pump ?
- help.. Truck pulls to the right hard
- rims and tires
- What turbo should I run ?
- Bed issues
- I need a new 5spd transmission
- 1st Gen & 2nd Gen Leaf Spring Compatibility
- Hot side housings
- Intake plate torque specs?
- Fuel Line Removal?
- Battery...check engine???
- HELP!! Parasitic Battery Draw
- General maintanence
- Getrag bellhousing
- Clutch
- 366 gov spring
- What Should I Do?
- 1st gen upgrade help!!!
- how much is it worth
- Timing question
- Banjo seals
- star wheel adjustment what is everyone running
- Rebuild kit recomendations
- pre bost smoke new fuel pin?
- injector o-ring size
- Worries on mileage.
- he351ve controller
- 84 dodge d350 crew cab for sale in indiana
- Can I use my 92 Cummins tranny when I swap to Chevy?
- charging issues
- fuel pin opinion and injector question
- trans overdrive
- LED taillights, headlights
- 1st gen to chevy nv4500
- need help!!!
- VE pump leak through breathing hole
- Looking for..
- FL: The UNcommon build (low and slow cruiser)
- Jerky Steerin
- turbo questions
- Tires sizes vs. 3.07 gearing question
- Head Gasket Job
- 1993 cummins speedometer and charging system and overdrive not working
- Getrag removal
- A few trans questions...
- Temperature Sensor
- Where can i find a tachometer for my first gen?
- What's a fair price for a 1st Gen
- Starting and Overdrive issue related?
- 1989 W250 Project! Help Needed!
- he351
- bed swap
- 1991 Dodge W250 Power Steering
- Oil problem
- Low boost!!!
- Tach for 1st gen
- Wheel Spacers?
- Has any body orderd or know any thing about shs diesel
- Air getting in fuel AFTER the lift pump
- Interior Trim?
- TURBO???
- Falling out of 5th gear?
- Getrag swap
- Issue with throttle sticking
- New! Need Help!
- 91 1/2 D250 TRW Tie Rods cross reference?
- 91-93 first gen 12 valve dodge wonted
- Thrust washer lost, replacement needed
- what to look for in a 1st gen
- In need of getrag parts in a bad way
- Biggest tire on stock 4x4 and speedo recalibration
- Manual shut off leaking
- Propane?
- Need Help
- bed differances
- turbo question
- 1989 turbo swap
- no start??? need help
- 5.9 Conversion speedo & guages ?
- Replace PCM... or start bypassing electronics?
- 12 v cummins just put pod injectors in sounds kinda defferent at idle ?
- governor spring again
- Need help*** Big 1st gen build, need info and knowledge
- KNOWN PROBLEMS 1st gen???
- Getrag hp limits
- 93 cummins cruise control problem
- ac lines
- Would it be hard?
- governor spring
- Quick question.
- 2,3 inch Lift
