PDA
View Full Version : Dodge Truck and Cummins Turbo Diesel Forum
Pages : [1] 2 3 4
  1. 07 3500 reliability help
  2. Diesel Smoke
  3. Oil standards
  4. Cummins Tech Article: BD Intercooler Boots install
  5. Strait pipe or muffler
  6. Duals or Stacks
  7. dodge lifts and stacks
  8. 5.9CR or 6.7 for fuel economy
  9. Taking door off - second gen
  10. P0243 Turbocharger Wastegate Solenoid A Malfunction
  11. Front Ends
  12. Manhattan ? anyone close ?
  13. 24v commin rail to 12v head and pump swap
  14. 6 or 7 inch stacks
  15. which one airdog 100 of airdog 150?
  16. Question about quadzilla xzt tuning files?
  17. Twin turbo question!
  18. transfer cases
  19. John Deer injectors in a second gen 24V?
  20. Wondering if I could fab up an injector puller.
  21. Interchangability of 1st gen and 2nd gen parts
  22. Mud Flaps
  23. At A Cross Roads
  24. Cores
  25. opinions...
  26. Introducing the 2010 Dodge Ram HD
  27. 2002 cummins question
  28. good deal?
  29. Mirror Upgrade
  30. Question About Exhaust?
  31. Local site did a profile on my truck
  32. Production Numbers breakdown
  33. Custom Dodges
  34. what kind of metal is this 5 inch made of?
  35. fuel pressure sensor for 2004 5.9
  36. question about edge truck years?
  37. Question about fass ddrp lift pump?
  38. dually rear question
  39. *Turbo sizing, CFM, HP rating
  40. Torquing ARP headstuds
  41. 03 to 07 #4 injector line part number
  42. At Every Fuel Stop......
  43. Damaged Fuel Sender pictures
  44. 2006 dually bed fit a 2001 ?
  45. Building a custom bumper???
  46. make your truck a power wagon!
  47. cracked dash
  48. What's it worth?
  49. 2010 Ram HDs
  50. crossing over!!
  51. Rear Brakes Hardly Work
  52. 6.7 head swap with 03 common rail
  53. fuel filter specs
  54. new upgrade tech.???
  55. p-pumping a rotary pump cummins
  56. Engine driven air compressors
  57. Clean Diesel: For College Speech Class
  58. cab mounts?
  59. hybrid 60/16 nonwastegated
  60. brake problem
  61. 3rd Gen Tech: Mag Hytec Transmission pan
  62. 3rd Gen Tech: Mag-Hytec Rear Differential Cover
  63. Steering wheel
  64. U Joint Question
  65. Towing Question
  66. BED SIZE ?
  67. rear drive shaft
  68. Dodge 6.7 A/C broke??
  69. Nobody seems to know what to do with my tranny...
  70. Anti-freeze
  71. drop fuel tank or pull the bed?
  72. fire ringing in MN
  73. 12V Cummins Ratrod
  74. WHICH TRUCK WOULD YOU BUY!?!?!
  75. MAKING A 2500 RAM A DUALLY
  76. Are Clutches Evil?
  77. Quick Question???
  78. EGR and Turbo Question!
  79. Paint and chrome removal?
  80. 98 dodge lift kit
  81. overheat under load
  82. tapping at 2000rpm and up
  83. tires
  84. NOOB lookin for suggestions
  85. CUMMINS OIL CHANGE FOR ONLY $32 !!! Advance Auto Loop Hole READ ME !
  86. custom billet emblem
  87. abs brakes
  88. 6.7 disaster
  89. Converter Lock and Unlock Fix
  90. sunvisors
  91. 8.3 250 cummins mods
  92. Abs problems 1997 3500 4x4
  93. cummins
  94. Exhaust information
  95. Boost Gauge vs Mass Air Flow Sensor
  96. Plugging Off Fuel Return Line
  97. towing mirrors
  98. dodge/cummins stuff
  99. 2002 Dodge cummins
  100. 2nd gen lightbar
  101. 97 12 Valve
  102. cyl head 93 to 97
  103. can some one run a carfax for me?
  104. 2005 5.9 Cummins valve ratle need help
  105. I'm a diesel dummy, help
  106. 5.9 Liter, burned valve, cylinder and scored cylinder walls
  107. Warranty deductible?
  108. overhead not working.
  109. Turbo swap missing part
  110. 2nd gen steering box adjustments
  111. AC Temp
  112. Halo Projector Headlamps
  113. please help temp sending unit destroyed
  114. 99 dodge codes?
  115. "Cheap" 12 sec Cummins
  116. Dtc P0393
  117. ranchhand "legend" series
  118. Rear shackle busted
  119. All Cummins Music Video GET IN ON THIS! - Smoke Show
  120. Boiling passenger side battery on 07 5.9 dodge
  121. coated pistons
  122. Fellow Dodge family, please read
  123. keyless entry
  124. Spray On or Roll On Liners for Body Project
  125. Urgent Urgent
  126. The Stealership strikes again...WOW!
  127. Vacuum Question
  128. 3rd Gen Cracked Dash
  129. 3Rd Generation door speakers.
  130. Anyone running a fifth wheel with a lifted truck?
  131. they just wont die
  132. Fass fuel priming
  133. HX30, HX32, HX35, HX40 Service Repair Manual
  134. How limiting is the short bed
  135. 3rd Gen Tech: Colder AC in under 25
  136. 2wd Lo
  137. KDP - Killer Dowel Pin
  138. Chrysler Cancels Dodge Ram 1500 Light Duty Diesel Engine
  139. Back glass
  140. Rear Driveline FYI
  141. CRANK CASE VENT
  142. Really Good Read On Turbo Chargers - Everyone Should Read
  143. triple disk clutch?
  144. 3rd gen CTD seat foam propblems
  145. Which one is louder?
  146. EMS FREE SPIN KIT INSTALLED......FINALLY!!!!!
  147. Need more air!!
  148. cummins t shirts
  149. 2004...what do you guys think?
  150. Chrysler cancels Cummins diesel for the light-duty Dodge Ram
  151. 2001 rear leaf spring
  152. silicone hoses
  153. Smarty ME download help - please
  154. '06 front clip on an '03
  155. Rear swap
  156. Behind the competition
  157. Lighted Mirrors
  158. tires?
  159. After Market Spedo needed
  160. The new guy with 3 dodge pics inside!
  161. who has a 4 to 5 in lift on a 2nd gen dodge??
  162. Waste Gate Settings
  163. Ok heres a good one!
  164. dash cracks
  165. Starter Issues
  166. whatttt? fog lights
  167. edge ez
  168. 03-07 Dodge Ram Towing Mirrors on a 98
  169. vacuum issue
  170. Adjusted the APPS
  171. In memory of Boyd Coddington. 2003 dodge ram 2500 diesel
  172. Payload 01 3500
  173. BADP :mad3:
  174. suncoast got killed
  175. turbo wrap
  176. fan question
  177. rear sway bar
  178. Truck Advice
  179. 1st 2nd or 3d 12v or 24v!
  180. T Case all brokey...again!
  181. Stack opinions
  182. need some help from dodge guys
  183. Need ECM for 01
  184. a/c lines
  185. Some Turbos On Ebay
  186. tow mirrors
  187. Gauges
  188. Ford guy drove a cummins
  189. 2010 ram
  190. anyone ever mess with C ENGINE
  191. Boost Bolt Carnage
  192. Transmission pans: Double Deep or Single deep?
  193. Auto or Manual
  194. Royal Purple or Amsoil?
  195. cummins burnouts
  196. Feeler NV4500
  197. Need some ideas
  198. Dana Axle Service Manuals
  199. Temp problems
  200. cooling fan
  201. Complete front end rebuild kit
  202. spring
  203. dynomat? or something else
  204. Need Help
  205. What headlight should i go with in need a vote to help thanks
  206. heat shield dimensions
  207. Where is the best deal on a arb air locker?
  208. truck bed
  209. 12V Cummins corvette
  210. 2wd lift spindles
  211. any opinions?
  212. 4BT LTD 55 MPH Question?
  213. I Either Popped The Head Gasket Or I Have A Bad Injector
  214. Is my Edge Juice w/Att dead or is it the PCM/ECM
  215. anyone in Forsyth, Mt???
  216. 35s on a 3rd gen .....
  217. Muffler Delete, with a twist
  218. tranny temp, whats too hot??
  219. vp 44 pump
  220. Traction Bars
  221. Dual, Dual Exhaust... Bed Exit Idea... Photoshop Pic Inside.
  222. Re:Smoke
  223. mufflers
  224. Fusion Bumpers?
  225. cummins swap
  226. No Reprogramming The 2009 Cummins
  227. Headliner
  228. Im doin a Cummins company profile for a project
  229. Dodge Cummins Check Engine Error Codes List
  230. Want to See my Latest adventure?
  231. 2004 cap on a 2002?
  232. 1996 dodge 2500 cummins
  233. Injector Spray Pattern
  234. Couple Warranty questions?
  235. Cheap Gauges that are great
  236. What's Different ?? 02 to 00 engine swap - HELP
  237. Cummins Literature
  238. You know you're a "diesel head" if....
  239. headiner
  240. wheel fitment for a 2nd gen ram what will fit?
  241. what trans is it?
  242. I like 'em stacked
  243. Boost Leak
  244. New to DB. Need an answer on Diffs
  245. Swap question
  246. Power seat owners - WARNING!!!!
  247. title
  248. Bed Liner?
  249. TC brokey
  250. My new shafts......
