- Oil Changing Procedure
- Engine Running Hot Towing?? Check Here.
- Front Driveshaft Grease Fitting
- My Bibles
- Fluid Capacities and Types
- another killer dowel pin fix on the cheap
- 2wheel drive low range*
- Turbo Swap Done With Pics*
- Replace Your Camshaft, Lifters 'n Stuff*
- Installing a 5.9 Cummins New Rear Main Seal*
- Turn Signals and Wipers Gone Crazy!?!*
- Dana 70
- Fuel pin pics
- torque converter install
- the inside of the getrag
- home built cold air intake
- dana 70 rearend is shot
- Injectors
- Cummins Tech Article: BD Intercooler Boots install
- Turbo shaft play help!!!
- valvebody and torque converter install
- Automatic Transmission Manual
- why it shift like that after vb?
- 48RE A/T Trouble Codes (Diesel)
- Pictures of an Air Dog installation/tank drop*
- Turbo sizing, CFM, HP rating*
- Torquing ARP headstuds
- tranny codes i need help ASAP!!!
- Instructional videos on how to "tweak" the VE injection pump,
- Grid Heater Relay Repair
- timing chart
- 1st Gen Intake Manifold Heater Operation And Diagnostics (Grid Heater)
- 1st Gen ABS Operation And Diagnostic
- Recall Notice Mopar Steering Linkage
- One Way to Install A Powerstroke Intercooler
- All about a 48RE*
- more about fuel plates.
- Really Good Read On Turbo Chargers - Everyone Should Read
- STEERING ISSUES
- testing your CPS*
- FASS vs AirDog.....You Decide!
- EMS FREE SPIN KIT INSTALLED......FINALLY!!!!!
- ATS or BD.....you decide.
- Air Box
- Anti Freeze Flush and Thermostat Replacment
- 3rd gen front brakes on 2nd gen*
- For More Information About Your Truck
- Walbro 392 Electric Fuel Pump And 3/8" Fuel Line Install
- TV/Kickdown Cable Adjustment*
- Dodge Cummins Error Codes List
- Reprogram A Key FOB
- Bullet proof the NV 4500 5 speed???
- Death Wobble ELIMINATED!!!! Finally!
- VP44 - P7100 conversion
- Anyone installed a mechanical air compressor on a 5.9?
- 48RE front band adjustment*
- ABS issues
- Fuel Lines
- Tech: Cummins Racing Stripe Installation
- Install/Remove a 48RE
- Grinding fuel plate
- Bottom Feed Fuel Supply Line
- Lets Talk Turbo inducers and Exducers
- Cummins Catalog - PDF part numbers
- After Market Tach Install and In Dash Gauge Mount
- cummins boost elbow
- Quadzilla Adrenaline with Pulse Custom Tuning Parameters, Varibles, Settings
- High Idle Kicker
- Denny T Stage II Fuel Pin Review
- Dash R&R
- 47RH A618 - O/D not working
- HELP NEED TO SMOKE
- Radiator Cleaning And Coolant Flush
- 12V Cummins Cleaning Prescrean and Fuelbowl
- Gear Swap/ Pump Mods
- 47RE Limp Mode , 3rd Gear Starts , No Down Shift to 1st Gear FIX
- 47RE Dowel Pin & Flex Plate Inspection
- 47RE 94-98 12v and 98-up 24v Transmission Fluid Cooling Tips
- Ram Tough Rebuild - Cummins Engine Specs/Brief History
- Capping A Fuel Rail
- Need Help With Codes
- Squeak On Shut Down?
- Installation of Lukes Links
- KDP Fix home video
- Turbo Silencer Ring
- Dual Lift Pump Install
- Quad Cab Back Door Latch
- Advice On What To Do
- Okay Guys Which One To Go With
- Boost Pressure Tester Build Instructions
- Headlight/Clearance/Turnsignal Lamp Change-How To
- Cummins Front Hub Removal Tip
- Dropping The Fuel Tank The Easy Way
- Dipricol Optix Gauge Install
- My Truck Is Eating Serpentine Belts
- Some Homemade Air Intake Tech....*
- Super B Turbo Charger Install
- How TO: Proper Clutch Installation
- Air Dog Install With Pics
- Grease Front Drive Shaft (CV Joint)
- Front End Rebuild
- Quadzilla Adrenaline In Route
- How To Install Stacks!
- turbos
- silencer ring
- Cummins Bolt Chart
- Cummins Starter Part Numbers
- New Venture Gear T-Case Info
- The Peski Coolant Leak, Rear Bypass.....
- Evolution Of Our Transmission And Its Variants.....
- NV4500 Breakdown
- Truck Won't Run
- Transfer Case Application Info
- Fitting 2002 Aluminum Rims On A 1996 Truck
- 5.9L Piston Specifications
- Mystery Switch Instructions For 47RH trans.
- MAP Sensor Voltage Data
- 5.9L Injectors Tech Specs
- 5.9L Fan Removal
- 5.9L Diesel Filter Water/Sediment Drain
- CAD (AUTO 4WD Hubs) & All About 4WD
- Holset Identification
- How To Get Low Range 2WD
- Holset INFO
- OIL Fill Cap / Breather Vent Mod
- Auto Tranny Manual Lockup
- Fuel Flow Improvement For Cheapskates!
- Carter To Walbro Pump...
- "Roll Yer Own" Fuel Regulators And Bypass Valves!*
- Manual Tranny Cooler/Filter
- Dodge Website Check Yer Vin #
- Injector Return Flow Test
- Dodge Recalls?? Check Your VIN #*
- High Idle & 3 Cylinder Idle*
- Power Door Lock Fix
- Engine Data Plate
- Just Enabled The High Idle On My 6spd
- Cummins ISB 53 Block*
- How Do I Check My CPL Number?
- HD Valve Spring Replacment
- Synthetic Differential Oil
- ECM And Its Functions
- Block Heater Cord
- Pad And Rotor Bedding Procedure
- DENSO 130AMP ALTERNATOR
- Replacing Crankshaft Position Sensor
- Gauge install tips*
- Cummins H.P Ratings
- Blowby Test*
- Twin Turbo / Supercharger System
- 40mm Internal Wastegate???
- Auto To Manual Conversion Notes
- Auto Transmissions Explained
- NP241 & NV241 Transfer Cases
- Brake upgrade
- Upgrade The OEM Lift Pump
- Automatic To Manual Conversion
- Engine CPL Number
- Cleaning the IAT sensor
- Fuel Pressure Gauge Install
- Port And Polishing HTT Exhaust Manifold*
- Gutted Torque Tube
