PDA
View Full Version : Chevy/GMC Duramax 01-04 LB7
  1. Rough running 02 Help!!!!!
  2. need advice on a 01 lb7 worth it?
  3. Chip Suggestions
  4. balance rates
  5. Road Armor Bumper HELP
  6. 2001 LB7.. This thing has issues.
  7. how hard could it be??
  8. oil filter leak?
  9. PPE torque level???
  10. Air filter
  11. Head Gaskets
  12. Low Coolant Problem
  13. Exhaust Question
  14. 2003 duramax has a intermittent no start
  15. Boken heater core hose
  16. 2001 DURAMAX LB7
  17. Engine Oil Life
  18. chip?
  19. Looking at buying an '02 LB7 Pro/cons
  20. Exhaust and Noise?
  21. Spare key and alarm system
  22. Need DURAMAX repair in Detroit area???????
  23. 2001 Duramax smokes
  24. 03 blows white?
  25. FUEL PSI GAUGE VS RAIL PSI
  26. $1000.00 (That is correct, one thousand dollars) 03 Duramax
  27. transmision msg?
  28. 04 Duramax power loss
  29. injector problems
  30. Buying an 01.
  31. Power reduced while brake is applied?
  32. boost gauge
  33. how do you test the glowplug relay
  34. manifolds cooldown cracking noise after shutting down
  35. Bilstein 5100 Shocks
  36. replacing ball joints
  37. Tire and Wheel size
  38. annoying vibration
  39. DURAMAX IDLE PROBLEM
  40. oil pressure
  41. water in cab
  42. Changing a Fuel Filter
  43. 2003 Duramax Diesel WaterPump R&R
  44. engine limping
  45. Duramax Repair Manuel
  46. turbo upgrade
  47. dmax valve lash
  48. Fuel Flow/ Leaky Rail
  49. loss of power?
  50. turbo
  51. Pulled Injector cups / Injector sleeves
  52. nitrous
  53. injectors
  54. duramax vs cadillac ctsv
  55. Diagnostic Code P0236
  56. Racing a 6cyl. mustang
  57. Help Speedo jumping, ABS & Brake light on
  58. bad injector vs particulate filter
  59. Changes?
  60. New LB7 Duramax Power Tee Shirt
  61. Cold Air Intake
  62. o2 duramax nocking sounds
  63. "Service Engine Soon" light & fault code
  64. Limped tranny ???
  65. DIY rebuilt injectors?
  66. Question about Edge Juice
  67. oil pressure.
  68. Balancer bolt
  69. Leaky Injectors.
  70. 03 duramax
  71. Injection pump replacement instructions
  72. WasteGate Blockoff
  73. EGR causes hazing?
  74. Time for a change.
  75. 04 Duramax with ZF6 speed manual.
  76. Trouble code P0380
  77. Topkick smoking!!!
  78. top speed
  79. false oil pressure signals
  80. '03 duramax studdering
  81. vibration
  82. Trans. Temperature
  83. Is this a truck i should look at or steer clear?
  84. efi live
  85. DPF Delete?
  86. Sell me a Chevy
  87. programmers
  88. What Boost valve
  89. Duramax
  90. Sudden Boost Drop.
  91. adding boost valve with tuner?
  92. Cycling noise...???
  93. 2002 LB7 HP upper???
  94. Straight pipe exhaust or aftermarket muffler??
  95. Boost Pressure at 65mph
  96. puff while cranking
  97. Weird Rail PSI
  98. proper pyrometer install?
  99. hypertech? vs CD head unit
  100. I'm Back
  101. Black Smoke, No Power
  102. Removing the Harmonic Balancer
  103. 2003 LB7 duramax Low fuel pressure
  104. trailer wiring no, blinker or brake
  105. replacing the t stats
  106. unusual rattle in engine
  107. SCIV
  108. WTB: LB7 injectors
  109. Air Dog or Fass?
  110. exhaust question
  111. Aftermarket or GM or Reman injectors
  112. Hitachi Starter any good?
  113. adjusting torsion bars
  114. efi live smoke
  115. Rear Rotors
  116. Changing injectors on a LB7
  117. Busted CV Shaft
  118. water/meth injection
  119. propane
  120. 03 transmission - Help
  121. blew up turbo...suggestions
  122. weird noise
  123. MBRP Single Stack
  124. Lost on this.
  125. EFI Live... need Help
  126. racing tips
  127. Am I "limping out"
  128. 2001 Duramax
  129. service engine soon
  130. Reset or quick learn the allison transmission
  131. Dmax Leaking ATF
  132. tranny options?
  133. lookin at truck
  134. Opinion on Edge programmer...
  135. Danny's no help, need transmission suggestions
  136. suncoast transmissions
  137. high idle
  138. Headlights
  139. pulling a bumper
  140. No power steering or brakes
  141. Knocking and black smoke...
  142. Annoying sound
  143. Funny surging idle...
  144. new truck hopefully
  145. Fuel leak in oil crankcase?
  146. Tire Size
  147. Transgo on lb7
  148. something loose in the front end
  149. need opinion
  150. bad injectors ?
  151. ppe mp8 stackable
  152. truck wont smoke
  153. remote start?
  154. gear/axle ratio question
  155. Blue Smoke
  156. upgrades?
  157. what's the better option?
  158. the truck
  159. burnout...
  160. My PPE Boost Increase Valve
  161. Did a little logging today
  162. Lb7 injectors in a lly?
  163. Injector replacement
  164. what's up with this?
  165. limpin' down the road
  166. tires?
  167. Looking at an 01 Duramax, 2WD, ext cab long bed.
  168. Looks or Performance?
  169. Intake air temp.
  170. NEW TRUCK!!
  171. GEAR OIL
  172. Weird Acting Duramax
  173. Anyone Ever Had This Problem???
  174. Lift Kits...
  175. My "New" Hauling Rig...
  176. Chug??
  177. Transfer Case?
  178. DTC Question
  179. LB7 Oil Change DIY
  180. Water Pump Leaking
  181. Injector Options?
  182. Any Suggestions?
  183. Starter?
  184. Blue Smoke At Idle
  185. Takeoff
  186. New Truck
  187. Looking For Some Answers About The Best Programmer For An LB7
  188. Cabin Air filter
  189. Need Some Help
  190. Will Removing Cat Throw Codes?
  191. Help My Truck Won't Start
  192. ZF S6-650 vs Allison
  193. PPE
  194. Juncion Block Body - No Power
  195. Bad FPR
  196. 04 Dmax 4X4 6spd
  197. p0089
  198. 2004 Chevy Silverado Duramax - Worked Truck
  199. Is This Right
  200. I Want Smoke
  201. Duramax LB7
  202. Good Clutch To Hold A 6-Speed?
  203. How Hard To Change A Fuel Filter?
  204. U1800 DTC Code
  205. Looking For A New Truck
  206. Sliding Rear Window?
  207. Power Steering Leak
  208. The AMSOIL Dealer Said.....
  209. Synthetic Oil...?
  210. New Duramax owner w/ question, please.
  211. Yup....I Did It.
  212. Disableing MAP
  213. 03 Dmax Stock Guage Cluster Not Working Right?
  214. My Truck's First Load (Since I Got It)
  215. What Tranny Does The 03 Have
  216. Does Anyone Know If...
  217. Tires?????
  218. lb7 mpg
  219. "Death Mode" On A 2001 Duramax
  220. Coolant in Oil
  221. fuel pump
  222. OK ......Which one of you Chevy guys???
  223. 4x4 Gremlins
