- Schaeffer 167 75w140 and a G80?
- Banks SixGun with power PDA issues?
- 2004 Chevy 2500HD Duramax LWB
- Kodiak 4500
- Tuner advice READ!
- question on gear ratios
- Code P1721 & P1720
- I just bought an 05 duramax.
- How do the 2500HDs hold up?
- KONY 2012
- FS:1963 chevy lwb
- tires
- Radiator and Intercooler options - need help DMax guys
- 1990 chevy k1500 knocking noise
- WTB Duramax
- I am looking for a HX40 14cm turbine housing
- Cab Removal Video I Made.
- for all the chevy truck owners.
- Duramax Swap?
- SAS D-MAX
- Performance up Grades
- 04 GMC need help
- 6.0L VS Dmax - 2000 Silverado
- 1997 c3500HD with mitsubishi 6D31turbo
- What's it worth?
- HELP!!!! Tranny proplems P0700MIL
- New to duramax, need help
- Coolant Temp Sensor
- Hey Guys/Gals, Just a Friendly Suggestion
- 1983 ELECTRICAL FUEL SWTCH
- What's the MPG of DMAX??
- Very Strange sound from truck when coasting.
- Wheels
- Window repair
- 1998 z71 6.5
- Trying to locate a co. in tn
- For you single cab long bed guys.
- Integrated Trailer Brakes
- 12.01 at 111mph.
- Which motor?
- are chevy or gm diesels bad if there not a duramax?
- 2007 GMC Sierra 2500 Duramax LMM
- photoshop??
- first dyno soon need advice
- GAUGES
- Rough Idle and Smoke
- Diesel Conversion
- Who builds allison trans?
- Air horns on my Duramax
- 1996 Chevy 2500 silverado turbo fuel issue
- is this truck worth $1000?
- CRUISE CONTROL
- First Diesel 2005 Dmax.
- Cold Air Intake
- Chevy 2500hd Torsion keys and leveling kit question
- 12.2 @ 112MPH
- Diesel performance shop in NY?
- Fierce Attitude M/T tires?
- Own A 70's Or 80's Model Scottsdale?
- Fuel lines Duramax
- Question about tires
- which is best
- chevy and gmc whats diff?
- DRL Low Beam Mod
- diming of panel lights
- code p0401
- ID this aftermarket part?
- Thinking about buying a Duramax
- allison trans questions
- 93chevy
- 2003 gmc duramax
- FUEL LINES
- coolant hot engine over heating
- How many GM Duramax Owners on here?
- 4SPD. TO 5SPD/OD
- Question ????
- Allison Tranny,,NBSU or no???
- 84 wheels
- crapy mileage
- EFI Live tuning
- Duramax Fuel Pump fuse
- Crankshaft Position Sensor
- MAF and "silencer ring"
- Just Say HI !!! And Showing Off my LMM
- No fuel to injectors 6.5 turbo-1995 chevy
- 597HP 1156FT-lbs
- PPE stage 5 tranny??
- New trans??
- Want a free Rancho suspension system? Looking for a 2011 Chevy/GMC 4WD
- heating up diesel?
- New Trans Kit Special...
- Dropped Tranny case
- 100,000 miles +
- My Service Books (Documents attached)
- help our local ffa
- 05 Duramax Electrical issue
- Silencer Ring
- Lb7 smoke and lope tunes??
- Best exhaust and programmer for lmm?
- Which intake should I buy?
- QUESTION!
- just wanting some suggestions
- Dually wheels
- rocker panels
- Tires
- Is This The END?
- Which is louder?
- i need ideas
- Opinons on the LML
- Engine Knock please help
- Allison tranny
- Suncoast,which one???
- Went Dead Won't Start!!!!!HELP
- I need some help ASAP!!!!!!
- Silverado radio question
- longest lasting Duramax
- Hummer wheels
- Quad stealth 2 or PPE standard????
- When will I need injectors???
- Efi Live shop in PA???
- is there a way to upgrade power steering?
- Duramax
- LLY or LB7
- new duramax leaking fluid ?!?!?!
- please help
- engine swap which one
- HELP!! Need to remove Snapped plastic bleeder screw above fuel filter
- GM 4.5 Duramax
- Service 4wd Light
- new to the forum and have lots of questions
- Where's the 2011s at?
- change oil soon....
- 99 GM cam sensor????
- Differences between duramaxes?
- Front End Issues
- fuel filter change
- MPGs??
- 07.5 lmm "upgrades"
- Best Generation Of Duramax
- what more do you need???
- 04 Duramax Main and rod bearings?
- chevy cummins swap
- Chevrolet Volt Batteries Could Enable Renewable Energy Solutions
- clock spring?
- Looking at a new truck...
- rear locker?
- EGT?
- cam position sensor 05 d-max??
- Swap Small Block with a Detroit 4-71
- Saying good bye to the LBZ
- Development Simulator Speeds Validation of Future Infotainment Solutions
- GM Forum Addresses Reinvention of the Automotive Industry through Technology Innovati
- what D-max to choose
- LB7 prime issues
- 2001 allison 2000 temp probe
- Nice to see more action in the D-Max Threads
- OnStar Celebrates Patents During National Inventors Month
- Engine swap from 5.7l gas to ??
- Atlanta beware!! Dealer problems!
- DirtyMaxx or Cummins
- GM and Virginia Tech Create Advanced Tire Test Facility
- 01/02 Fog Lamp Solution?
- allison question
- 4cyl conversion
- Chevy, GMC Announce CNG and LPG Vans for Fleets
- NEW Diesel owner with questions
- injector problems
- aam 11.5 rear end carrier swap 3.42 to 4.10 gears.
- 01 to 03 front end swap
- 97 GMC 3500 2wd upgrade
- Air Dam?
- Wont start when hot
- Need Advice From The Chevy Guys
- LLY-LBZ
- Cold air?
- tire size?
- Sierra Denali HD Diesel
- General Motors Announces B20 Biofuel Capability For New, 2011 Duramax 6.6L Turbo Dies
- RUNNING WASTE OIL
- need opinions
- Truck shutdown and won't restart
- Banks Boost Tubes with Stock Intercooler?
- Turbo Stopped Working while towing
- Superchips Cortex ?
- 12 Chevrolet Models Offer Fuel-saving, Six-speed Automatic Transmissions for 2011 Mod
- Worlds First Compound Twin Turbo Duramax
- For the D-Max Guys
- 750k Mile Duramax
- No More GMC Trucks after 2011
- HIDs are in!!!
- HELP... 05 DURAMAX COOLANT PROBLEM!!!
- help it won't start 6.5 turbo
- Italian Duramax
- Dmax just died
- High Beam With Fogs..
- Ok I want one now
- 2011 Duramax Power #s
- !@#$% Plastic Air Bleeder Screw
- Tried Meguiars Gold Class
- lookin for info on lmm
- '04 tow mirror
- Need some help with codes
- Install time?
- Steering Problem 97 Chevy 6.5L
- LBZ smog question
- Smoke Switch.
- Fuel Filter
- EFI Uploaded!!
- Duramax diesel sticker!
- Need some advice
- 2011 LML Duramax Diesel Engine - Inside The 2011 LML Duramax
- NASA and GM Create Cutting Edge Robotic Technology
- lly intake resinator blockoff
- Injectors
- My DURAMAX COMPILATION VIDEO!!!!
- Best progammer/chip for Duramax?
- Squeaking from drivetrain? Haynes or Repair Manual?
- How do Duramax compare to Cummins and Powerstoke ?
- 04.5 Duramax LLY
- SAS duramax jump
- Questions about a lift...
- Calling out Dan-o the man-o part 2
- head gaskets
- Duramax Gauge Install
- rear axle strenght?
- NEW VIDEO!! Check It!!!
- pcv bypass on an lly
- pcv bypass ?
- New Guy needs info..
- Air Filter
- New Pics of the Truck w/Tow Mirrors
- EVEN THOUGH I OWN A FORD
- Duramax Diesel Fuel System - Fuel Injector Service
- Head Gasket and Studs install
- 4wd problem
- Cold Start Video!!
- General Duramax DIY, Codes and Specs.
- Speedometer
- worked on my buddys Dmax last night
- Danny i found it!
- Badass PPE Duramax Hummer
- brake problem
- Chasing a rattle
- WTF Napa?
- oem parts deals
- Cargo management toolboxes
- Mufflers and Performance
- injector codes
- rear sliding window in nbs
- Trucks loping when cold?
