plate issues
Old Feb 22, 2009 | 12:35 PM
94cummins12v's Avatar
Default plate issues
ok while i had the pump off the engine i figured no would be the time to go threw it top to bottom. i installed my new 0 fuel plate and noticed the governor arm was riht at the base of the plate, it looked like it had room to slide and not dive under, hopefully. i was wondering were the governow arm should be on the plate and how th adjust the arm, i forgot were the damn adjustments are made
Old Feb 22, 2009 | 02:02 PM
Cummins97's Avatar
IIRC you want to take the cover off and adjust the left screw. Not sure which way lifts or raises it tho.
But here's a pic of where you adjust it...
I need to do this while I got mine tore down also.
Hopefully someone that knows how to do this will post the full how to...
i found it! page 2 DM is explaining it
turning up a 12v
Old Feb 22, 2009 | 03:40 PM
MotorOilMcCall's Avatar
Yeah, its the back of the pump under the cover, there are 3 bolts there, make sure you get the right one ... But from the sounds of it, your arm is right where it should be. On a 0 plate as long as its not diving under you'll be fine. And if its the stock plate re-ground you shouldn't have to adjust it at all.
Old Feb 22, 2009 | 10:34 PM
i threw a 5 plate in way back when now im doing the 0 plate and it is a stock plate ground to a 0 profile
Old Feb 22, 2009 | 11:14 PM
xzaq103's Avatar
FormerVendor
As long as your not going under the plate its fine.
Old Feb 22, 2009 | 11:34 PM
the arm is flush with the bottom of the plate right now and when i pull the throttle lever it dont go under
Old Feb 22, 2009 | 11:59 PM
xzaq103's Avatar
FormerVendor
Do you have your shut off pulled up when you do this?
I read somewhere of a guys setting his with it running. He stated that the arm is higher when its running. Not sure if its true just what I heard.
Old Feb 23, 2009 | 12:18 AM
i did have the selinoid in the up/on position when i looked at it
Old Feb 23, 2009 | 08:52 AM
It will be higher when its running, the plate it attached to the Gov springs somehow, so as you get to higher RPM's it rides up the plate and adds more fuel. Of course, the other arm of the AFC is what the gov arm will hit first, but with the AFC cover off you don't see it.
Old Feb 23, 2009 | 11:23 AM
oh ya
dwmeehan
Jan 29, 2025 12:13 PM
ronstop
Feb 26, 2015 09:48 AM
Polaris04
Dec 1, 2014 08:27 AM
SMatyac
Nov 15, 2014 07:35 PM
JustAnother_cummins_guy
Nov 10, 2014 09:44 PM
