7.3 wont run in the mornings
Old Jul 24, 2010 | 11:15 AM
shutterbug's Avatar
Default 7.3 wont run in the mornings
I have an early 99 250 7.3. It is stock as far as i can tell. When we baught the truck it had 23k on the clocks. We drove it home from houston, bout a thousand miles one way. Didnt have an issue i thought other than takes about 3-7 seconds to fireoff and crank.batteries tested at 13v for one and 12.6 for the other with no load. oil is new and good level fuel is fresh. The problem i am having is that the truck runs fine in the evening, however when i get out early in the morning after a good warm up i leave the driveway and make it less than 1/2 a mile and start losing cylinders. Once i do get the truck re fired i have partial cylinders till i stumble home. i wait all day then get in the truck and it is like it is a different truck... IDK!.. Help me out if you can guys i really dig my truck but i want to work it...Thanks, Ric..
Old Jul 24, 2010 | 01:11 PM
gunman41mag's Avatar
Moderator
Have you checked the CPS ???
Old Jul 24, 2010 | 04:19 PM
shutterbug's Avatar
I haven't checked that no, i downloaded a shop manual, as far a clues I have none. I am new to the diesel world, i only checked my oil level(new) water at the bottom of the filter i might have had some which i drained and my batteries. As for the cps, i really dont know the procedure to check that.How and what is that procedure..? Thanks, Ric
Old Jul 25, 2010 | 06:41 PM
purcell87's Avatar
injectors?
Old Jul 25, 2010 | 08:08 PM
shutterbug's Avatar
Default 7.3
Originally Posted by purcell87
injectors?
the guy we baught the truck from said they had replaced all the injecters over the past year also a few of the sensors, they replaced the ecu and also cut the ccat on the truck, i have just replaced the oil today filled up and a filter change. the problem only happens after the truck sits all night, it also only started happening after i let the tank run almost completly empty of fuel, since then every morning the truck dies after a short stroll down the road! Fo figure , thanks Ric..
Browe347
Dec 11, 2016 02:59 PM
vin_diesel
Mar 1, 2016 01:43 PM
racinfast002
For Sale
Jan 7, 2015 12:46 PM
drivecumminsridered
Oct 24, 2014 02:10 AM
Browe347
Sep 30, 2014 11:35 PM
