problem with idle on 12v cummins
Old May 6, 2010 | 05:15 PM
patpat paul's Avatar
Default problem with idle on 12v cummins
got this problem on my 98 12v cummins have to idle it up to 900 then when put in gear drops to 650-700 falls on its face with ac on has new injection pump by industrial injection and cant figure out why it does this injectors replaced with 300hp ones and it still does this any ideas really starting to bug me is there some ajustment i dont know about also has 3000 gov spring in the pump help please??????
Old May 6, 2010 | 05:25 PM
DIRTYMAX2004's Avatar
there is a way to turn you idle up. i am no 12 valve tech but someone should be able to tell you exactly how to adjust it.
Old May 6, 2010 | 05:30 PM
Default re:
yeh i turned it up that how i get it to run but dont think i should have to turn it up that high to get it to idle in gear so yeh got me baffled
dont know what i typed to get6 that stupid little smiley face in there sorry
Last edited by patpat paul; May 6, 2010 at 05:30 PM. Reason: Automerged Doublepost
Old May 6, 2010 | 06:35 PM
daveO's Avatar
I've heard having your gov springs too loose will cause a low idle issue. Idle should be 750-800 in drive with the a/c on.
Old May 6, 2010 | 07:00 PM
D&J Precision's Avatar
FormerVendor
Loosen your governor springs a click and adjust your idle back up to compensate. That should help with light load responce. If it does not go another click, but do not go looser than three clicks in.
Old May 9, 2010 | 10:37 AM
ok is the governor spring the one with the nut on it on the back side of the anorod?
Old May 10, 2010 | 04:26 PM
daveO's Avatar
No, the governor springs can be accessed through the top of the pump if you pull out the fuel plate or through the plug on the side towards the bottom of the pump.
Old May 13, 2010 | 08:19 PM
FormerVendor
If you or some one you know have not messed with the governor DONT. One mistake and you buy a pump or worse an engine. I hate to see you with a pile of parts.
burndiesel
10
Feb 7, 2023 01:15 AM
Antwhite19
Mar 26, 2020 04:58 PM
Jonrarick
Oct 25, 2016 01:32 PM
jeremy01995
Sep 14, 2015 06:34 PM
Omingnome
Oct 20, 2014 12:25 PM
