99 7.3 Smoking
Old Apr 4, 2010 | 02:31 PM
Smoky Bear's Avatar
Default 99 7.3 Smoking
I bought a 7.3 turbo deisel and it smoked white a little when i got it. i was told by lots of people it was my injectors. so i changed them. And also my glow plugs and map sensor. But it still smokes. Some one please help me!!!!
Old Apr 4, 2010 | 06:22 PM
CSIPSD's Avatar
Got to stop throwing money at it... White smoke could be many things...
Have someone with a good nose drive behind you when its doing it. See if it smells of fuel or coolant.
I would guess its a turbo issue, the o rings are more then likely leaking oil past and into the exhaust. Most times this happens when under load. If you leave it idling for a long time see if it does it worse for a bit.
Old Apr 5, 2010 | 10:18 AM
big_stroker's Avatar
What he said ^^^^
Old Apr 5, 2010 | 11:27 AM
Smoky Bear's Avatar
I took it to 3 mechanics all of them said injectors. And it smells like fuel. its getting to much. and letting it sit al a idle it just sits there the same. I had one mechanic say it might be my harness.
Old Apr 7, 2010 | 08:16 AM
Did any of them hook it up to a scanner and look at anything?
If not then go find a real diesel shop that knows what they are doing.
Browe347
Dec 11, 2016 02:59 PM
tumble72
8
Nov 27, 2014 10:31 PM
CO TOM
Oct 24, 2014 11:33 PM
CO TOM
Oct 16, 2014 09:55 AM
Browe347
Sep 30, 2014 11:35 PM
