1990 7.3 hard starting cold
Old Nov 17, 2009 | 02:12 PM
twostroke80's Avatar
Default 1990 7.3 hard starting cold
I have a 1990 7.3 wait to start light comes on for about 2-3 seconds then goes out and the glow plug relay clicks a few times but it has to spin over a good many times before it cranks after first start up it will crank right up all 8 glow plugs checked fine with a test light any help i would be greatful
Thanks
Old Nov 21, 2009 | 02:19 PM
wildbill's Avatar
Sounds like a dead controller.
Old Nov 21, 2009 | 06:38 PM
Thanks.... i got one ordered i'm going to try that
just looked at the ip on the bottom driver side the plunger(when you move the throttle it goes in and out) is wet its not dripping just wet all around it would that be any cause to hard starting (cold)??? starts fine after it has been run thanks...
Last edited by twostroke80; Nov 21, 2009 at 10:36 PM. Reason: Automerged Doublepost
Old Nov 24, 2009 | 08:51 AM
93_Fummins's Avatar
A dead glow plug or two will make it short cycle too.
If the IP is losing prime, it will hard start.
Sorry, just saw that you checked the glowplugs So, yeah, controller is probably bad.
The dripping out of the plunger might be enough to cause it to lose prime over periods of time, but I'm not sure. Either way, a wet IP is usually not good...
Last edited by 93_Fummins; Nov 24, 2009 at 08:51 AM. Reason: Automerged Doublepost
Old Nov 25, 2009 | 03:58 PM
wildbill's Avatar
Updates??
Old Nov 25, 2009 | 06:30 PM
controller fixed it put it on today... truck fired right up
Old Nov 25, 2009 | 07:03 PM
wildbill's Avatar
Good deal.
Will close the thread, and if the problem should come back, you can reopen the thread, or start a new one.
Dcbb93
Nov 30, 2015 10:18 AM
Excursion73
Oct 27, 2015 05:21 PM
91 7three
Jan 7, 2015 09:37 AM
custom7.3
Nov 24, 2014 05:16 PM
7.3stroke
Oct 27, 2014 06:25 PM
