Weird Starting Issues
Old Nov 14, 2009 | 09:50 AM
Kens_PS's Avatar
Site Sponsor - Ken's Performance Solutions
Default Weird Starting Issues
Tempatures have been dropping lately so earlier in the week I thought the slower cranking was due to the cold. Two nights ago, when I went to leave work, I turned the key on, all the normal dash lights came on, went off, and then the check engine light and the low fuel light came back on and started flashing along with a weird click, click, click coming from under the dash and it would not crank over. I turned the key off, waited a bit, turned it back on and the instant I saw the check engine light go off the first time as normal I cranked it and it fired right off with no hesitation. Drove on home stopping at Safeway on the way and it re-started there just fine as well.
Then yesterday morning it was slow again but cranked over and off towork we went.
But then last night when I went to leave to come home again, dash lights came on and went off like norrmal, but the check engine and low fuel ight once again came on and stayed on, no flash, no crank nada. Several tries-no change.
I opened the door to see if I could hear anything happening outside and the dome light in the roof started flashing like a strobe light till I closed the door, I thought, what is going on here. Went back in the shop and grabbed battery and cables. I connected and as soon as I could get back in the cab, it fired right off with no hesitation at all. Drained batterys at this point I would think would still crank slow.
I'm flusterd, would dying batteries cause this strobelight and what sounds like a clicking relay sound to occur, and after starting and driving, it does not show excessive charging on the volt meter, that shows normal as well
Old Nov 18, 2009 | 03:45 AM
CSIPSD's Avatar
Check the connection of both your batterys... sounds like one or both are loose or have bad grounds.
Old Nov 20, 2009 | 11:27 PM
breeze400's Avatar
I suffered through slow starting problem on mine for 2 3 mts last winter. The starter finally quit! Sounds like the same thing I had going on with mine. Check the starter!
Sam
Old Feb 8, 2010 | 05:29 AM
jamsmith's Avatar
Same problem with mine. Turned out to be the battires.
Old Feb 8, 2010 | 11:12 AM
codiesel's Avatar
tif you have a chip it mess with it you have to have them tuned back down at times i had that happen to mine
dwmeehan
Jan 29, 2025 12:13 PM
hurriedcoyte
Jun 19, 2015 06:26 AM
ronstop
Feb 26, 2015 09:48 AM
rschriek
Feb 3, 2015 10:13 AM
Polaris04
Dec 1, 2014 08:27 AM
